Print
3COM 4007交换机更改三层VLAN IP地址小案例
2006-05-18发表
3COM 4007交换机已经停产,菜单式配置方式。
       4007交换机三层模块划分VLAN的方式有三种,基于端口的VLAN(Port based),基于协议的VLAN(Protocol based),基于网段的VLAN(Network based),这和我们目前常见的交换机是完全不同的。仅知道配置命令,但没有理解这三种VLAN划分的区别,会导致修改失败的。
以下是更改三层vlan IP地址的过程,关键处及注释用红色字体标出,一看就能明白,具有较强可操作性:
3com4007> show module all         //显示所有模块
Slot  Module      Status             Description
01.01 3CB9LG9MC   Up                 9 Port 1000BaseSX Layer 2 Switching Module
02.01 3CB9LG4     Managed by fabric  4 Port Gen I/O Module
03.01 3CB9RG4     Up                 4 Port GBIC Layer 3 Switching Module
07.01 3CB9FG24T   Primary            24 Port Gigabit Switching Fabric, 12 Trunks
08.01 3CB9EMC     Active             Enterprise Management Controller
08.02 3CB9EME     Primary            Enterprise Management Engine
3com4007> connect 3.1             //连接到三层交换模块
Menu options (Corebuilder 9000-52C243): ----------------------------------------
  module                   - Administer module-level functions
  ethernet                 - Administer Ethernet ports
  bridge                   - Administer bridging/VLANs
  ip                       - Administer IP
  ipx                      - Administer IPX
  appletalk                - Administer AppleTalk
  qos                      - Administer QoS
  snmp                     - Administer SNMP
  analyzer                 - Administer Roving Analysis
  disconnect               - Disconnect and return to Management Console
Type ? for help.
CB9000@slot3.1 [4-GEN-GBIC-L3] (): ip
  interface                - Administer interfaces
  route                    - Administer routes
  arp                      - Administer the ARP cache
  multicast                - Administer multicast routing
  dns                      - Administer DNS
  vrrp                     - Administer VRRP
  udpHelper                - Administer the UDP broadcast helper
  routing                  - Enable/disable IP routing
  ospf                     - Administer OSPF
  rip                      - Administer RIP
  ping                     - Send ICMP echo request
  advancedPing             - Send ICMP echo request with advanced options
  traceRoute               - Track the route of IP packet
  advancedTraceRoute       - Track the route of IP packet with advanced options
  statistics               - Display statistics
Type "q" to return to the previous menu or ? for help.
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip): rou
"rou" is ambiguous.
Did you want to select "route" (n,y) [y]: y
  display                  - Display the routing table
  static                   - Define a static route
  remove                   - Remove a route
  flush                    - Flush all learned routes
  default                  - Define the default route
  noDefault                - Remove the default route
  findRoute                - Find route in the routing table
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/route): display            //显示路由表信息
Enter IP Address [0.0.0.0]:
Enter mask [0.0.0.0]:
IP routing is enabled
There are 9 of 25600-51200 possible Routing Table entries.
Destination     Subnet mask    Metric Gateway         Status              TTL
Default Route    --                -- 10.10.1.253     Static               --
10.10.1.0       255.255.255.0      --  --             Direct               --
10.10.1.254     255.255.255.255    --  --             Local                --
10.10.3.0       255.255.255.0      --  --             Direct               --
10.10.3.254     255.255.255.255    --  --             Local                --
10.10.4.0       255.255.255.0      --  --             Direct               --
10.10.4.254     255.255.255.255    --  --             Local                --
192.168.0.0     255.255.0.0        --  --             Direct               --
192.168.0.254   255.255.255.255    --  --             Local                --
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/route): q
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip): interface
  summary                  - Display summary information
  detail                   - Display detail information
  define                   - Define a new interface
  modify                   - Modify an existing interface
  remove                   - Remove an interface
  arpProxy                 - Enable/disable ARP proxy
  broadcastAddress         - Define broadcast address
  directedBroadcast        - Enable/disable forwarding of directed broadcasts
  icmpRedirect             - Enable/disable ICMP redirects
  icmpRouterDiscovery      - Enable/disable ICMP router discovery
  statistics               - Display interface statistics
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/interface): sum
Select IP interfaces (1-3,8|all|?): all
Index  IP address       Subnet mask      State  Type  ID
    1  10.10.1.254      255.255.255.0    Up     VLAN  1    (VID: 1)
    2  192.168.0.254    255.255.0.0      Up     VLAN  2    (VID: 2)
    3  10.10.3.254      255.255.255.0    Up     VLAN  3    (VID: 3)
    8  10.10.4.254      255.255.255.0    Up     VLAN  8    (VID: 8)
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/interface): remove       //去除VLAN 2三层接口地址,注意:直接在此改IP地址会提示不成功。
Select IP interfaces (1-3,8|all|?) [1-3,8]: 2
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/interface): summary
Select IP interfaces (1,3,8|all|?): all
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/interface): q
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip): q
  ip                       - Administer IP
Type ? for help.
CB9000@slot3.1 [4-GEN-GBIC-L3] (): bridge
  display                  - Display bridge information
  ipFragmentation          - Enable/Disable IP Fragmentation
  ipxSnapTranslation       - Enable/Disable IPX 802.3-FDDI SNAP Translation
  addressThreshold         - Set the bridge address threshold
  agingTime                - Set the bridge address aging time
  spanningTree             - Administer spanning tree
  gvrpState                - Enable/disable GVRP
  port                     - Administer bridge ports
  packetFilter             - Administer packet filters
  vlan                     - Administer VLANs
  trunk                    - Administer trunks
CB9000@slot3.1 [4-GEN-GBIC-L3] (bridge): vlan
  define                   - Define a VLAN
  modify                   - Modify a VLAN
  remove                   - Remove a VLAN
  mode                     - Configure VLAN mode
  vlanAwareMode            - Configure VLAN-aware mode
CB9000@slot3.1 [4-GEN-GBIC-L3] (bridge/vlan): remove                  //去除VLAN 2
Select VLAN interface indexes (1-3,6,8|all|?): 2
CB9000@slot3.1 [4-GEN-GBIC-L3] (bridge/vlan): define             //重新定义VLAN 2
Enter VID (2-4094) [2]: 2
Select bridge ports (1-5|all|?): 5
Enter protocol suite
 (IP,IPX,Apple,XNS,DECnet,SNA,Vines,X25,NetBEUI,unspecified,IPX-II,IPX-802.2,
IPX-802.3,IPX-802.2-SNAP): ip
Enter protocol suite ('q' to quit)
 (IPX,Apple,XNS,DECnet,SNA,Vines,X25,NetBEUI,IPX-II,IPX-802.2,IPX-802.3,
IPX-802.2-SNAP): q
Configure layer 3 address? (n,y) [y]: n
Configure per-port tagging? (n,y) [y]: y
Enter port 5-8 tag type (none,802.1Q) [none]: 802.1Q
Enter VLAN Name {?} []: vlan-2
CB9000@slot3.1 [4-GEN-GBIC-L3] (bridge/vlan): summary
Select VLAN interface index(s) (1-3,6,8|all|?): 2
VLAN summary
VLAN Mode: allOpen
VLAN-aware mode: allPorts
Index                              VID                 Type               Origin
2                                    2                 open               static
Index                             Name                Ports
2                               vlan-2                  5-8
CB9000@slot3.1 [4-GEN-GBIC-L3] (bridge/vlan): q
CB9000@slot3.1 [4-GEN-GBIC-L3] (bridge): q
  ip                       - Administer IP
Type ? for help.
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/interface): define    //重新定义VLAN 2三层接口地址
Enter IP address: 172.16.0.254
Enter subnet mask [255.255.0.0]: 255.255.0.0
Enter interface type (vlan,port) [vlan]: vlan
Enter VLAN interface index {2,6|?}: 2
CB9000@slot3.1 [4-GEN-GBIC-L3] (ip/interface): summary              //更改成功
Select IP interfaces (1-3,8|all|?) [1,3,8]: 2
    2  172.16.0.254    255.255.0.0      Up     VLAN  2    (VID: 2)
"rou" is ambiguous.
172.16.0.0     255.255.0.0        --  --             Direct               --
172.16.0.254   255.255.255.255    --  --             Local                --
--Enter <CR> to continue--
Disconnected from module 3.1.
Terminal timeout - login session terminated.
Good-Bye
