Print
AR28/AR46系列路由器L2VPN-Kompella典型配置
2006-09-07 发表
AR28/AR46系列路由器L2VPNKompella典型配置
【需求】
CE-AS2/0/0CE-BS2/0/0之间建立一条本地的L2VPN连接CE-AS2/0/1CE-CS2/0/0建立一条远程的L2VPN连接。
【组网图】
【配置脚本】
CE-A配置脚本
sysname CE-A
radius scheme system
domain system
interface Serial2/0/0
link-protocol ppp
ip address 192.168.11.1 255.255.255.0
interface Serial2/0/1
link-protocol ppp
ip address 192.168.21.1 255.255.255.0
interface NULL0
user-interface con 0
user-interface vty 0 4
return
CE-B配置脚本
sysname CE-B
domain system
link-protocol ppp
ip address 192.168.11.2 255.255.255.0
interface NULL0
return
PE-A配置脚本
sysname PE-A
router id 1.1.1.1
mpls lsr-id 1.1.1.1
mpls l2vpn                                        /启用MPLS L2VPN/
mpls
mpls ldp
domain system
link-protocol ppp
link-protocol ppp
interface Serial2/0/2
link-protocol ppp
interface Serial2/0/3
link-protocol ppp
ip address 10.0.0.1 255.255.255.252
mpls
mpls ldp enable
interface NULL0
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
bgp 100
undo synchronization
group inter internal
peer 3.3.3.3 group inter                          /PE-B建立BGP邻居/
peer 3.3.3.3 connect-interface LoopBack0
l2vpn-family                                      /创建L2VPN地址族/
peer inter enable                                 /使能peer inter/
ospf 1
area 0.0.0.0
network 1.1.1.1 0.0.0.0
network 10.0.0.0 0.0.0.3
mpls l2vpn vpna encapsulation ppp                 /创建VPN实例“vpna”,封装为ppp/
route-distinguisher 100:1                         /RD=100:1/
vpn-target 100:1 import-extcommunity              /RT=100:1/
vpn-target 100:1 export-extcommunity
mtu 1500
ce ce-a id 1 range 10 default-offset 0            /创建cece-a/
connection ce-offset 3 interface Serial2/0/1
/配置和CE-C的远程连接/
connection ce-offset 2 interface Serial2/0/0
 /配置和CE-B的本地连接/
ce ce-b id 2 range 10 default-offset 0            /创建cece-b/
connection ce-offset 1 interface Serial2/0/2    /配置和CE-A的本地连接/
return
P配置脚本
sysname P
router id 2.2.2.2
mpls lsr-id 2.2.2.2
mpls
mpls ldp
domain system
link-protocol ppp
ip address 10.0.0.2 255.255.255.252
mpls
mpls ldp enable
link-protocol ppp
ip address 10.0.0.5 255.255.255.252
mpls
mpls ldp enable
interface NULL0
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
ospf 1
area 0.0.0.0
network 2.2.2.2 0.0.0.0
network 10.0.0.4 0.0.0.3
return
PE-B配置脚本
sysname PE-B
router id 3.3.3.3
mpls lsr-id 3.3.3.3
mpls
mpls ldp
domain system
link-protocol ppp
ip address 10.0.0.6 255.255.255.252
mpls
mpls ldp enable
link-protocol ppp
interface NULL0
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
bgp 100
peer 1.1.1.1 group inter                          /PE-A建立BGP邻居/
peer 1.1.1.1 connect-interface LoopBack0
ospf 1
area 0.0.0.0
network 3.3.3.3 0.0.0.0
mtu 1500
ce ce-c id 3 range 10 default-offset 0            /创建cece-c/
connection ce-offset 1 interface Serial2/0/1      /配置和CE-A的远程连接/
return
CE-C配置脚本
sysname CE-C
domain system
link-protocol ppp
ip address 192.168.21.2 255.255.255.0
interface NULL0
return
【验证】
查看PE-A的l2vpn连接状态:
<PE-A>disp mpls l2vpn connection
total connections: 3,
connections: 3 up, 0 down, 2 local, 1 remote, 0 unknown
VPN-Instance Name: vpna,
  CE Name: ce-a, id: 1,
  Rid type status peer-id         route-distinguisher   intf
  3   rmt  up     3.3.3.3         100:1                 Serial2/0/1
  2   loc  up     ---             ---                   Serial2/0/0
  CE Name: ce-b, id: 2,
  1   loc  up     ---             ---                   Serial2/0/2
查看PE-B的l2vpn连接状态:
<PE-B>disp mpls l2vpn connection
total connections: 1,
connections: 1 up, 0 down, 0 local, 1 remote, 0 unknown
  CE Name: ce-c, id: 3,
  1   rmt  up     1.1.1.1         100:1                 Serial2/0/1
【提示】
Kompella方式的VC标签由MP-BGP来发布。下图为二层标签示意图。
