Print
MSR路由器IS-IS下的基本路由互通功能的配置
2006-09-07 发表
 MSR路由器
ISIS路由协议基本功能的配置
          关键字: MSR;IPv6;ISIS;路由
一、组网需求
通过运行IS-IS协议实现中间系统到中间系统的域内路由信息交换
        试验设备RTA(MSR20-21),RTB(MSR20-20),RTC(MSR30-20)
  适用版本Version 5.20, Beta 1105
二、组网图
1 IS-IS路由协议组网图
三、配置步骤
RTA配置
[RTA]ipv6                           //全局视图下使能Ipv6
[RTA]isis 1
[RTA-isis-1]network-entity 86.0001.0000.0000.0006.00
[RTA-isis-1]ipv6 enable
[RTA-isis-1]quit
[RTA]interface Ethernet 0/0
[RTA-Ethernet0/0]ipv6 address 2::1/64
[RTA-Ethernet0/0]isis ipv6 enable 1
[RTA-Ethernet0/0]quit
RTB配置
[RTB]ipv6                             //全局视图下使能Ipv6
[RTB] isis 1                            //创建进程号为1isis实例
[RTB-isis-1]ipv6 enable                  //使能isisIpv6功能
[RTB-isis-1]network-entity 86.0001.0000.0000.0005.00 //设置该实例的网络
实体字
[RTB-isis-1]quit
[RTB]interface Ethernet 0/0
[RTB-Ethernet0/0]ipv6 address 3::2/64
[RTB-Ethernet0/0]isis ipv6 enable 1         //接口下使能isis ipv6功能
[RTB-Ethernet0/0]quit
RTC配置
[RTC]ipv6
[RTC]isis 1
[RTC-isis-1]ipv6 enable
[RTC-isis-1]network-entity 86.0001.0000.0000.0007.00
[RTC-isis-1]quit
[RTC]interface GigabitEthernet 0/0
[RTC-GigabitEthernet0/0]ipv6 address 2::2/64
[RTC-GigabitEthernet0/0]isis ipv6 enable 100
[RTC-GigabitEthernet0/0]quit
[RTC]interface GigabitEthernet 0/1
[RTC-GigabitEthernet0/1]ipv6 address 3::1/64
[RTC-GigabitEthernet0/1]isis ipv6 enable 100
[RTC-GigabitEthernet0/1]quit
四、配置关键点
1.              network-entity 值不要重复
2.              在每个接口下都使能ISIS IPv6 enable
五、试验分析
配置完成后通过RTA ping RTB能够ping通,结果显示如下:
<RTA>ping ipv6 3::2
  PING 3::2 : 56  data bytes, press CTRL_C to break
    Reply from 3::2
    bytes=56 Sequence=1 hop limit=63  time = 3 ms
    Reply from 3::2
    bytes=56 Sequence=2 hop limit=63  time = 3 ms
    Reply from 3::2
    bytes=56 Sequence=3 hop limit=63  time = 3 ms
    Reply from 3::2
    bytes=56 Sequence=4 hop limit=63  time = 3 ms
    Reply from 3::2
    bytes=56 Sequence=5 hop limit=63  time = 3 ms
  --- 3::2 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
查看RTBIPv6路由表显示有到RTAISIS路由显示如下
[RTB]dis ipv routing-table
Routing Table :
        Destinations : 5        Routes : 5
Destination: ::1/128                         Protocol  : Direct
NextHop                                  Preference: 0
Interface : InLoop0                         Cost      : 0
Destination: 2::/64                          Protocol  : ISISv6
NextHop : FE80::20F:E2FF:FE30:C235         Preference: 15
Interface : Eth0/0                           Cost      : 20
Destination: 3::/64                           Protocol  : Direct
NextHop : 3::2                              Preference: 0
Interface: Eth0/0                            Cost      : 0
Destination: 3::2/128                         Protocol  : Direct
NextHop : ::1                               Preference: 0
Destination: FE80::/10                        Protocol  : Direct
NextHop : ::                                Preference: 0
Interface : NULL0                           Cost      : 0
