Print
S6500系列交换机RSPAN的配置
2006-09-08 发表
S6500系列交换机RSPAN的配置
一、组网需求:
1) Switch A通过GigabitEthernet 1/0/2和数据检测设备相连;
2) Switch ATrunk端口GigabitEthernet 1/0/1Switch BTrunk端口GigabitEthernet 1/0/1相连;
3) Switch BTrunk端口GigabitEthernet 1/0/2Switch CTrunk端口GigabitEthernet 1/0/1相连;
4) Switch C的端口GigabitEthernet 1/0/2PC相连;
5) 需求为通过数据检测设备对PC发送的报文进行监控和分析。
二、组网图:
1. 组网图
1) VLAN 10Remote-probe VLAN
2) Switch A为目的交换机,连接数据监控设备的端口GigabitEthernet 1/0/2为镜像目的端口。GigabitEthernet 1/0/2必须为Access端口,并且不能使能STPLACP
3) Switch B为中间交换机
4) Switch C为源交换机,GigabitEthernet 1/0/2为镜像源端口,定义GigabitEthernet 1/0/3为反射端口。GigabitEthernet 1/0/3必须为Access端口,并且不能使能STPLACP
三、配置步骤:
1.   Switch C上的配置
1) 定义VLAN 10Remote-probe Vlan
[SwitchC] vlan 10
[SwitchC-vlan10] remote-probe vlan enable
[SwitchC-vlan10] quit
2) 配置与中间交换机Switch B相连的端口为Trunk类型,并允许VLAN 10通过
[SwitchC] interface GigabitEthernet 1/0/1
[SwitchC-GigabitEthernet1/0/1] port link-type trunk
[SwitchC-GigabitEthernet1/0/1] port trunk permit vlan 10
[SwitchC-GigabitEthernet1/0/1] quit
3) 配置远程镜像组
[SwitchC] mirroring-group 1 remote-source
4) 定义远程镜像组源端口
[SwitchC] mirroring-group 1 mirroring-port GigabitEthernet 1/0/2 inbound
5) 定义远程镜像组反射端口
[SwitchC] mirroring-group 1 reflector-port GigabitEthernet 1/0/3
6) 定义远程镜像组Remote-probe Vlan
[SwitchC] mirroring-group 1 remote-probe vlan 10
7) 显示远程镜像源组配置信息
[SwitchC] display mirroring-group remote-source
mirroring-group 1:
    type: remote-source
    status: active
    mirroring port:
        GigabitEthernet1/0/2  inbound
    reflector port: GigabitEthernet1/0/3
    remote-probe vlan: 10
2.   Switch B上的配置
[SwitchB] vlan 10
[SwitchB-vlan10] remote-probe vlan enable
[SwitchB-vlan10] quit
2) 定义与源交换机SwitchC相连的端口为Trunk类型,并允许VLAN 10通过
[SwitchB] interface GigabitEthernet 1/0/1
[SwitchB-GigabitEthernet1/0/1] port link-type trunk
[SwitchB-GigabitEthernet1/0/1] port trunk permit vlan 10
3) 定义与目的交换机SwitchC相连的端口为Trunk类型,并允许VLAN 10通过
[SwitchB] interface GigabitEthernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port link-type trunk
[SwitchB-GigabitEthernet1/0/2] port trunk permit vlan 10
3.   Switch A上的配置
[SwitchA] vlan 10
[SwitchA-vlan10] remote-probe vlan enable
[SwitchA-vlan10] quit
2) 定义与中间交换机SwitchC相连的端口为Trunk类型,并允许VLAN 10通过
[SwitchA] interface GigabitEthernet 1/0/1
[SwitchA-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 10
[SwitchA-GigabitEthernet1/0/1] quit
3) 定义远程镜像组目的端口
[SwitchA] mirroring-group 1 remote-destination
[SwitchA] mirroring-group 1 monitor-port GigabitEthernet 1/0/2
4) 定义远程镜像组Remote-probe Vlan
[SwitchA] mirroring-group 1 remote-probe vlan 10
5) 显示远程镜像源组配置信息
[SwitchA] display mirroring-group remote-destination
mirroring-group 1:
    type: remote-destination
    status: active
    monitor port: GigabitEthernet1/0/2
四、配置关键点
1)    反射端口无法作为正常的端口转发流量,所以建议用户将没有使用的处于DOWN状态的端口配置为反射端口,且不要在该端口上添加其它配置;
2)    不要在与中间交换机或目的交换机相连的端口上配置镜像源端口,否则可能引起网络内的流量混乱;
3)    不要将镜像源端口配置到本镜像组所使用的Remote-probe VLAN中;
4)    不要配置Remote-probe VLAN的三层接口;
5)    Remote-probe VLAN不要运行其他协议报文,承载其他的业务报文;
6)    不要将Remote-probe VLAN用作其他特殊类型的VLAN,如voice VLAN、协议VLAN
