Print
SecPath防火墙分片报文攻击防范典型配置
2006-09-25 发表
一、组网需求
部署SecPath防火墙,对IP分片报文攻击进行防范,以保护FTP Server 11.0.0.1/24。
二、组网图
    软件版本如下:
    SecPath10FVRP 3.40 ESS 1604
三、配置步骤
[DOWN] dis cur
 sysname DOWN
 firewall packet-filter enable
 firewall packet-filter default permit
 undo connection-limit enable
 connection-limit default deny
 connection-limit default amount upper-limit 50 lower-limit 20
 firewall statistic system enable
radius scheme system
domain system
local-user admin
 password cipher .]@USE=B,53Q=^Q`MAF4<1!!
 service-type telnet terminal
 level 3
 service-type ftp
acl number 3000
//阻止到达server的IP分片报文
 rule 1 deny ip destination 11.0.0.1 0 fragment
//允许ftp分片报文通过
 rule 2 permit tcp destination 11.0.0.1 0 destination-port eq ftp fragment
interface Ethernet1/0
 ip address 10.0.0.254 255.255.0.0
 firewall packet-filter 3000 inbound            //在接口上应用acl
interface Ethernet2/0
 speed 10
 duplex full
 ip address 11.0.0.254 255.255.255.0
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 add interface Ethernet2/0
 set priority 85
firewall zone untrust
 add interface Ethernet1/0
 set priority 5
firewall zone DMZ
 set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
 FTP server enable
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
return
四、配置关键点
1.ACL中配置对分片报文的阻断;
2.在接口上应用ACL
五、验证结果
在攻击机Attacker10.0.0.1上对11.0.0.1进行ping大包,PC会对ping报文进行分片,结果无法ping11.0.0.1
在攻击机上ftp 11.0.0.1,正常。
[DOWN]dis acl 3000
Advanced ACL  3000, 2 rules
Acl's step is 1
 rule 1 deny ip destination 11.0.0.1 0 fragment (0 times matched)
 rule 2 permit tcp destination 11.0.0.1 0 destination-port eq ftp fragment (0 ti
mes matched)
[DOWN]dis acl 3000
Acl's step is 1
 rule 1 deny ip destination 11.0.0.1 0 fragment (108 times matched)
mes matched)
