Print
H3C WX系列AC上本地转发 、隐藏ssid功能的配置
H3C WX系列AC上实现本地转发 、隐藏ssid功能的配置
一、 组网需求:
AC(WX5002WX5004)、AP(WA2610E-GNP)、交换机
二、 组网图:
三、 配置步骤:
1、AC上配置信息:
< AC>display   current-configuration
 version 5.20, Release 2308P06
 sysname AC
 domain default enable system
 telnet server enable
 port-security enable
vlan 1
vlan 2
vlan 3397
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool ap1
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.254
user-group system
 group-attribute allow-guest
local-user admin
 password simple admin
 authorization-attribute level 3
 service-type telnet
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
 ssid 456
 beacon ssid-hide
 bind WLAN-ESS 1
 cipher-suite tkip
 security-ie rsn
 client forwarding-mode local vlan 3397
 service-template enable
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.100 255.255.255.0
interface Vlan-interface2
 ip address 192.168.2.254 255.255.255.0
 port link-type trunk
 port trunk permit vlan all
interface WLAN-ESS1
 port link-type hybrid
 undo port hybrid vlan 1
port hybrid  vlan  3397 untagged
 port hybrid  pvid vlan 3397
port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher wrWR2LZofLw4qvbcs+daVw==
wlan ap ap1  model WA2610E-GNP id 1
 map-configuration aplocal.txt
 serial-id 219801A0CSC124009767
 radio 1
  service-template 1 vlan-id 3397
  radio enable
 undo info-center logfile enable
 dhcp enable
 load xml-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
return
2、交换机上配置信息:
 sysname sw1
radius scheme system
domain system
dhcp server ip-pool 2
 network 192.168.3.0 mask 255.255.255.0
 gateway-list 192.168.3.254
vlan 1 to 3
vlan 3397
interface Vlan-interface3397
 ip address 192.168.3.254 255.255.255.0
interface Aux1/0/0
interface Ethernet1/0/1     //上连接AC//
 poe enable
interface Ethernet1/0/2     //下连接AP//
 poe enable
 port trunk pvid vlan 2     //AP所属的vlan//
 dhcp enable
user-interface aux 0
return
3、主要配置步骤
(1)配置无线接口(ESS
[AC]int wlan-ess 1
[AC-WLAN-ESS1]port link-type hybrid
[AC-WLAN-ESS1]undo port hybrid vlan 1
[AC-WLAN-ESS1]port hybrid vlan  3397 untagged
[AC-WLAN-ESS1]port hybrid pvid vlan 3397
[AC-WLAN-ESS1]port-security port-mode psk
[AC-WLAN-ESS1]port-security tx-key-type 11key
[AC-WLAN-ESS1]port-security preshared-key pass-phrase  12345678
(2)配置无线服务
[AC]wlan ser  1 crypto
[AC-wlan-st-1] ssid 456
[AC-wlan-st-1] bind WLAN-ESS 1
[AC-wlan-st-1]cipher-suite tkip
[AC-wlan-st-1]security-ie rsn
[AC-wlan-st-1]client forwarding-mode local vlan 3397
[AC-wlan-st-1]service-template enable
(3)配置AP模板
[AC]wlan ap ap1  model WA2610E-GNP id 1
[AC-wlan-ap-ap1] map-configuration aplocal.txt
[AC-wlan-ap-ap1] serial-id 219801A0CSC124009767
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template 1 vlan-id 3397
[AC-wlan-ap-ap1-radio-1]  radio enable
(4)配置DHCP信息
[AC]dhcp enable
[AC]dhcp server  ip-pool  ap1   //AP的地址池
[AC-dhcp-pool-ap1]network 192.168.2.0 mask 255.255.255.0
[AC-dhcp-pool-ap1]gateway-list 192.168.2.254
[sw]dhcp server  ip-pool  2    //用户地址池
[sw-dhcp-pool-2]network 192.168.3.0 mask 255.255.255.0
[sw-dhcp-pool-2]gateway-list 192.168.3.254
四、 配置关键点:
1、将下面的aplocal.txt文件中需要的配置命令,制作完成后上传到AC flash中:
vlan 3397
2、在本地转发的时候,AP最大下发256vlan,所以在写aplocal.txt文件的时候要注意,如果业务vlan是案例中的3397,不要笼统的写成vlan 1 to 3397,否则会造成无法成功下发业务vlan
3、在进行AP本地转发前,如果AP已经注册在线,为RUN状态,那么进行本地转发功能实现时,需要重启AP,因为本地转发功能下发到AP的配置文件是在AP注册过程中下发下去的。
