现场HOSTB为总部,HOSTA和HOSTC为分支需要通过IPSEC VPN和总部互访(分支之间也需要互相访问),总部使用固定地址,分支4G拨号动态获地址和总部使用野蛮模式建立IPSEC隧道。由于两个分支和总部内网网段冲突,不可以直接通过ipsec隧道去访问总部,可以通过建立静态vxlan隧道实现大二层互通。
HOSTA
# 配置接口Loopback0的IP地址,作为隧道的源端地址
interface LoopBack0
# 接口下调用ipsec策略
ip address 1.1.1.1 255.255.0.0
ipsec apply policy policy1
# 配置去往公网的默认路由
ip route-static 0.0.0.0 0 1.1.1.2
# IPSEC感兴趣流
acl advanced 3000
rule 0 permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
rule 1 permit ip source 10.1.1.0 0.0.0.255 destination 10.1.3.0 0.0.0.255
ipsec transform-set transform1
esp encryption-algorithm 3des-cbc
esp authentication-algorithm md5
ipsec policy policy1 1 isakmp
security acl 3000
remote-address 2.2.2.2
ike-profile profile1
ike profile profile1
keychain keychain1
exchange-mode aggressive
local-identity fqdn devicea
match remote identity address 2.2.2.2 255.255.0.0
ike keychain keychain1
pre-shared-key address 2.2.2.2 255.255.0.0 key H3c
HOSTB
interface LoopBack0
ip address 10.1.2.1 255.255.255.0
# 接口下调用ipsec策略
ip address 2.2.2.2 255.255.0.0
# 配置去往公网的静态路由
ip route-static 0.0.0.0 0 2.2.2.1
ipsec policy-template template1 1
local-address 2.2.2.2
ipsec policy-template template1 2
ike-profile profile2
ipsec policy policy1 1 isakmp template template1
ipsec policy policy1 2 isakmp template template2
keychain keychain1
match remote identity fqdn devicea
ike profile profile2
keychain keychain2
match remote identity fqdn devicec
pre-shared-key address 1.1.1.1 255.255.0.0 key H3C
ike keychain keychain2
pre-shared-key address 3.3.3.2 255.255.0.0 key H3C
HOSTC
interface LoopBack0
ip address 10.1.3.1 255.255.255.0
# 接口下调用ipsec策略
ip address 3.3.3.2 255.255.0.0
# 配置去往公网的静态路由
ip route-static 0.0.0.0 0 3.3.3.1
# 配置IPSEC感兴趣流
acl advanced 3000
rule 0 permit ip source 10.1.3.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
rule 0 permit ip source 10.1.3.0 0.0.0.255 destination 10.1.1.0 0.0.0.255
security acl 3000
keychain keychain1
local-identity fqdn devicec
pre-shared-key address 2.2.2.2 255.255.0.0 key H3C
2.总部和分支1建立vxlan隧道tunnel100,总部和分支2建立vxlan隧道200,分支1通过分支2和总部建立vxlan隧道tunnel300
HOSTA
# 开启L2VPN能力
l2vpn enable
# 创建vsi实例test和vxlan 1 并使Tunnel100和Tunnel300关联vxlan1
vsi test
vxlan 1
tunnel 100
tunnel 300
# 接口关联VSI实例vpn1
interface GigabitEthernet1/0/6
xconnect vsi test
# 在HOSTA和HOSTB之间建立VXLAN隧道
interface Tunnel100 mode vxlan
source 10.1.1.1
destination 10.1.2.1
# 在HOSTA和HOSTC之间建立VXLAN隧道
interface Tunnel300 mode vxlan
source 10.1.1.1
destination 10.1.3.1
HOSTB
# 开启L2VPN能力
l2vpn enable
# 创建vsi实例test和vxlan 1 并使Tunnel100和Tunnel200关联vxlan1
vsi test
vxlan 1
tunnel 100
tunnel 200
# 接口关联VSI实例vpn1
xconnect vsi test
source 10.1.2.1
destination 10.1.1.1
# 在HOSTC和HOSTB之间建立VXLAN隧道
interface Tunnel200 mode vxlan
source 10.1.2.1
HOSTC
# 开启L2VPN能力
l2vpn enable
# 创建vsi实例test和vxlan 1 并使Tunnel200和Tunnel300关联vxlan1
vsi test
vxlan 1
tunnel 200
tunnel 300
# 接口关联VSI实例vpn1
xconnect vsi test
source 10.1.3.1
source 10.1.3.1
当现场出现总部和分支内网网段相同的时候,我们内网访问的流量无法使用ipsec隧道进行互访,所以我们需要创建一个vxlan over ipsec的网络,使用ipsec使设备的loopback接口互通,然后使用loopback接口建立vxlan隧道,这样就能实现总部和分支之间同网段互相访问。如果两个分支之间互相访问,那么我们就需要在两个分支之创建一个vxlan隧道,实际流量还是要经过我们的总部设备的转发。
