怎么设置成傻瓜式交换机,
插上网线上不去网
(0)
默认就是傻瓜,有配置的话 得需要重置一下:
The saved configuration file will be erased. Are you sure? [Y/N]:Y //确定删除保存的配置文件
This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N //不保存配置
This command will reboot the device. Continue? [Y/N]:Y //继续重启
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
