MSR810-W,下面接的设备无法上网,但路由器可以上网
2024-04-24提问
  • 0收藏,127浏览
田草 零段
最简单的设置一下上网,配置如下:
[H3C]dis cu
 version 7.1.064, Release 6728P26
 sysname H3C
wlan global-configuration
 telnet server enable
 undo resource-monitor output syslog snmp-notification netconf-event
 security-policy disable
 ip load-sharing mode per-flow src-ip global
 dhcp enable
 lldp global enable
 system-working-mode standard
 password-recovery enable
vlan 1
---- More ----%Jan  1 00:50:11:915 2011 H3C XMLCFG/6/WEB_AGENT_TIMEOUT: user admin from 192.168.1.3, session id 3, idle timed out.
dhcp server ip-pool lan2
 gateway-list 192.168.128.1
 network 192.168.128.0 mask 255.255.255.0
 dns-list 119.29.29.29 223.5.5.5
wlan service-template h3c-test
 ssid H3C-test
 service-template enable
controller Cellular0/0
controller Cellular0/1
interface Dialer0
interface NULL0
interface Vlan-interface1
 ip address 192.168.128.1 255.255.255.0
interface GigabitEthernet0/0
 port link-mode route
---- More ----%Jan  1 00:50:13:380 2011 H3C WEB/5/LOGOUT: admin 92.168.1.3 .
 description Single_Line1
 ip address dhcp-alloc
 nat outbound
interface GigabitEthernet0/1
 port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface WLAN-Radio0/0
object-policy ip Any-Any
 rule 65534 pass
security-zone name Local
security-zone name Trust
 import interface Vlan-interface1
security-zone name DMZ
security-zone name Untrust
 import interface Dialer0
security-zone name Management
zone-pair security source Any destination Any
 object-policy apply ip Any-Any
 scheduler logfile size 16
line class console
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line con 0
 idle-timeout 60 0
line vty 0 4
 idle-timeout 60 0
line vty 5 63
 info-center loghost 127.0.0.1 port 3301
 info-center source CFGLOG loghost level informational
performance-management
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$aW4WRG6KMzR6jb2i$hEaA6fWTOvfF0hyy6N9RLJOL7l5tl/Vx6x+0VRugK5UgDEjDm8ApcKyZFGiqooeNfKH3fdkilwmJIEWvCSk+kw==
 access-limit 10
 service-type http https
 authorization-attribute user-role level-15
 security-enhanced level 1
 ip http enable
 ip https enable
return
[H3C]
[H3C]ping 223.5.5.5
Ping 223.5.5.5 (223.5.5.5): 56 data bytes, press CTRL_C to break
56 bytes from 223.5.5.5: icmp_seq=0 ttl=113 time=13.298 ms
56 bytes from 223.5.5.5: icmp_seq=1 ttl=113 time=12.261 ms
56 bytes from 223.5.5.5: icmp_seq=2 ttl=113 time=12.231 ms
56 bytes from 223.5.5.5: icmp_seq=3 ttl=113 time=12.231 ms
56 bytes from 223.5.5.5: icmp_seq=4 ttl=113 time=13.539 ms
--- Ping statistics for 223.5.5.5 ---
round-trip min/avg/max/std-dev = 12.231/12.712/13.539/0.582 ms
[H3C]%Jan  1 00:50:47:530 2011 H3C PING/6/PING_STATISTICS: Ping statistics for 223.5.5.5: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 12.231/12.712/13.539/0.582 ms.
ping baidu.com
Ping baidu.com (39.156.66.10): 56 data bytes, press CTRL_C to break
56 bytes from 39.156.66.10: icmp_seq=0 ttl=46 time=37.951 ms
56 bytes from 39.156.66.10: icmp_seq=1 ttl=46 time=38.316 ms
56 bytes from 39.156.66.10: icmp_seq=2 ttl=46 time=38.225 ms
56 bytes from 39.156.66.10: icmp_seq=3 ttl=46 time=38.162 ms
56 bytes from 39.156.66.10: icmp_seq=4 ttl=46 time=38.339 ms
--- Ping statistics for baidu.com ---
round-trip min/avg/max/std-dev = 37.951/38.199/38.339/0.139 ms
[H3C]%Jan  1 00:50:55:049 2011 H3C PING/6/PING_STATISTICS: Ping statistics for baidu.com: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 37.951/38.199/38.339/0.139 ms.
粉丝:44人 关注:1人
你先把防火墙的功能关闭了,试试
把接口从安全域中删除
web界面设置的,还不会自动添加一条默认路由?:(
田草 发表时间:2024-04-24
回复田草:
不是 刚才看错了,能添加一条默认路由,因为你ping 公网都通了
zhiliao_h907dg 发表时间:2024-04-24
手动添加,ip route-static 0.0.0.0 0 192.168.8.1 还是不行
田草 发表时间:2024-04-24
zhiliao_Ikmrnc 知了小白
下面的电脑是静态ip吗,我看配置中接口没有选择dhcp
