S6800支持irf2.0吗?
2017-05-08提问
  • 1收藏,4100浏览
天乐 四段
S6800支持irf2.0吗?
asdasd 六段
粉丝:7人 关注:5人
支持
粉丝:2人 关注:3人
IRF的堆叠
智能弹性架构技术(H3C开发的软件虚拟化技术)
将多台设备堆叠在一起,在逻辑上形成一台虚拟的逻辑主设备。主设备的运行状态与从设备的运行状态保持同步。提高了高可靠性。实现了多台设备的协同管理,统一工作,和不间断维护。
优点:简化管理、提高性能、弹性扩展、高可靠性。
成员:master和slave
在配置成功后需要进行重启才能狗正常运作。
缺省情况下,设备的成员优先级均为1。priority值越大表示优先级越高。
H3C的基本配置:
此处的两个设备变一个设备是指在逻辑上变成一台设备
基本命令配置:
S1:
[H3C]int ten1/0/49
[H3C-Ten-GigabitEthernet1/0/49]shu
[H3C-Ten-GigabitEthernet1/0/49]shutdown
[H3C-Ten-GigabitEthernet1/0/49]qu
[H3C]irf domain 10
[H3C]irf member 1 renumber 1
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]y
[H3C]irf-port 1/1
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/49
[H3C-irf-port1/1]qu
[H3C]irf-port-configuration active
[H3C]save
The current configuration will be written to the device. Are you sure? [Y/N]:n
[H3C]int ten1/0/49
[H3C-Ten-GigabitEthernet1/0/49]undo shutdown
[H3C]save
S2:
<H3C>system-view
[H3C]INT TEN1/0/49
%Nov 13 14:08:50:039 2016 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/49 changed to down.
%Nov 13 14:08:50:044 2016 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/49 changed to down.
[H3C]irf domain 10
[H3C]irf member 1 renumber 2
[H3C]irf-port 1/2
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/49
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[H3C-irf-port1/2]qu
[H3C]int ten1/0/49
[H3C-Ten-GigabitEthernet1/0/49]un shutdown
[H3C-Ten-GigabitEthernet1/0/49]%Nov 13 14:10:26:230 2016 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/49 changed to up.
%Nov 13 14:10:26:232 2016 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/49 changed to up.
[H3C]save
<H3C>reboot
验证:
[H3C]dis cu
 version 7.1.059, Alpha 7159
 sysname H3C
 irf domain 10
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 irf member 2 priority 1
 lldp global enable
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/49
irf-port 2/2
 port group interface Ten-GigabitEthernet2/0/49
 stp global enable
interface NULL0
interface FortyGigE1/0/53
 port link-mode bridge
interface FortyGigE1/0/54
interface FortyGigE2/0/53
interface FortyGigE2/0/54
 combo enable fiber
 combo enable fiber
 combo enable fiber
interface GigabitEthernet1/0/4
 combo enable fiber
interface GigabitEthernet1/0/5
 combo enable fiber
interface GigabitEthernet1/0/6
 combo enable fiber
interface GigabitEthernet1/0/7
 combo enable fiber
interface GigabitEthernet1/0/8
 combo enable fiber
interface GigabitEthernet1/0/9
 combo enable fiber
interface GigabitEthernet1/0/10
 combo enable fiber
interface GigabitEthernet1/0/11
 combo enable fiber
interface GigabitEthernet1/0/12
 combo enable fiber
interface GigabitEthernet1/0/13
 combo enable fiber
interface GigabitEthernet1/0/14
 combo enable fiber
interface GigabitEthernet1/0/15
 combo enable fiber
interface GigabitEthernet1/0/16
 combo enable fiber
interface GigabitEthernet1/0/17
 combo enable fiber
interface GigabitEthernet1/0/18
 combo enable fiber
interface GigabitEthernet1/0/19
 combo enable fiber
interface GigabitEthernet1/0/20
 combo enable fiber
interface GigabitEthernet1/0/21
 combo enable fiber
interface GigabitEthernet1/0/22
 combo enable fiber
interface GigabitEthernet1/0/23
 combo enable fiber
interface GigabitEthernet1/0/24
 combo enable fiber
interface GigabitEthernet1/0/25
 combo enable fiber
interface GigabitEthernet1/0/26
 combo enable fiber
interface GigabitEthernet1/0/27
 combo enable fiber
interface GigabitEthernet1/0/28
 combo enable fiber
interface GigabitEthernet1/0/29
 combo enable fiber
interface GigabitEthernet1/0/30
 combo enable fiber
interface GigabitEthernet1/0/31
 combo enable fiber
interface GigabitEthernet1/0/32
 combo enable fiber
interface GigabitEthernet1/0/33
 combo enable fiber
interface GigabitEthernet1/0/34
 combo enable fiber
interface GigabitEthernet1/0/35
 combo enable fiber
interface GigabitEthernet1/0/36
 combo enable fiber
interface GigabitEthernet1/0/37
 combo enable fiber
interface GigabitEthernet1/0/38
 combo enable fiber
interface GigabitEthernet1/0/39
 combo enable fiber
interface GigabitEthernet1/0/40
 combo enable fiber
interface GigabitEthernet1/0/41
 combo enable fiber
interface GigabitEthernet1/0/42
 combo enable fiber
interface GigabitEthernet1/0/43
 combo enable fiber
interface GigabitEthernet1/0/44
 combo enable fiber
interface GigabitEthernet1/0/45
 combo enable fiber
interface GigabitEthernet1/0/46
 combo enable fiber
interface GigabitEthernet1/0/47
 combo enable fiber
interface GigabitEthernet1/0/48
 combo enable fiber
interface GigabitEthernet2/0/1
 combo enable fiber
interface GigabitEthernet2/0/2
 combo enable fiber
interface GigabitEthernet2/0/3
 combo enable fiber
interface GigabitEthernet2/0/4
 combo enable fiber
interface GigabitEthernet2/0/5
 combo enable fiber
interface GigabitEthernet2/0/6
 combo enable fiber
interface GigabitEthernet2/0/7
 combo enable fiber
interface GigabitEthernet2/0/8
 combo enable fiber
interface GigabitEthernet2/0/9
 combo enable fiber
interface GigabitEthernet2/0/10
 combo enable fiber
interface GigabitEthernet2/0/11
 combo enable fiber
interface GigabitEthernet2/0/12
 combo enable fiber
interface GigabitEthernet2/0/13
 combo enable fiber
interface GigabitEthernet2/0/14
出现2/0/X说明堆叠成功
IRF MAD BFD 多活检测配置案例
配置:
R1:
[H3C]int g1/0/1
[H3C-GigabitEthernet1/0/1]port link-mode route
[H3C-GigabitEthernet1/0/1]ip add 1.1.1.1 24
[H3C]int ten 1/0/50
[H3C-Ten-GigabitEthernet1/0/50]shut
[H3C-Ten-GigabitEthernet1/0/50]qui
[H3C]irf domain 10
[H3C]irf-port 1/1
[H3C-irf-port1/1]po g in ten 1/0/50
[H3C-irf-port1/1]qui
[H3C]int ten 1/0/50
[H3C-Ten-GigabitEthernet1/0/50]un sh
[H3C]save
[H3C]vlan 3
[IRF-vlan3]por g1/0/1
[IRF-vlan3]por g2/0/1
[IRF]int vlan 3
[IRF-Vlan-interface3]mad bfd enable
[IRF-Vlan-interface3]mad ip address 1.1.1.1  24 member 1
[IRF-Vlan-interface3]mad ip address 1.1.1.2  24 member 2
[IRF-Vlan-interface3]quit
[IRF-GigabitEthernet1/0/1]un stp en
[IRF-GigabitEthernet1/0/1]qui
[IRF]int g2/0/1
[IRF-GigabitEthernet2/0/1]un stp en
[IRF-GigabitEthernet2/0/1]qui
R2:
<H3C>sys
[H3C]int g1/0/1
[H3C-GigabitEthernet1/0/1]ip add 1.1.1.2 24
[H3C]int ten 1/0/50
[H3C]irf do 10
[H3C]irf m 1 re 2
[H3C]irf-p 1/2
[H3C-irf-port1/2]po g in ten 1/0/50
[H3C-irf-port1/2]qui
