MSR36-60 子网间通信异常,只能单方通讯??
2018-01-24提问
  • 1收藏,3104浏览
望龙 零段
如下配置:
60段的电脑可以PING 通172段,172段的ping不通60段?
60段的是一个交换机,划分VLAN6。当然,60段的所有电脑和3660的G2口都在VLAN6里面。
 version 7.1.064, Release 0605P20
 sysname wanglong
 qos carl 1 destination-ip-address range 172.16.0.2 to 172.16.3.250 per-address
 dhcp enable
 dns proxy enable
 dns server 59.49.49.49
 dns server 219.149.135.188
 password-recovery enable
vlan 1
dhcp server ip-pool defaultpool
 gateway-list 172.16.0.1
 network 172.16.0.0 mask 255.255.248.0
 address range 172.16.0.2 172.16.3.250
 dns-list 59.49.49.49 219.149.135.188
 expired day 0 hour 1
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 172.16.0.1 255.255.248.0
 tcp mss 1460
 dhcp server apply ip-pool defaultpool
interface GigabitEthernet0/1
 combo enable copper
 ip address 59.49.15.xxx 255.255.240.0
 tcp mss 1460
 nat outbound 2000
interface GigabitEthernet0/2
 ip address 192.168.60.253 255.255.255.0
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
line vty 0 4
 authentication-mode scheme
line vty 5 15
line vty 16 63
 ip route-static 0.0.0.0 0 59.49.15.···
 ssh server enable
 ssh server acl 3000
acl basic 2000
 rule 10 permit
acl advanced 3000
 rule 5 permit ip source 192.168.60.0 0.0.0.255
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash ···
 service-type ssh telnet http
local-user bingo class manage
 password hash ···
public-key peer 127.0.0.1
 public-key-code begin
 public-key-code end
 peer-public-key end
connection-limit policy 1
wlan global-configuration
 control-address disable
wlan ap-group default-group
return
1、你这路由不对,MSR上只有1条指向59段的默认路由,没有动态路由协议,那么向60段怎么走?
2、MSR上G0/2是一个三层口,怎么加入到vlan 6的?
3、60能ping通172的,从这个配置来看不可能,怀疑是你60那一段也有一个172网段的IP正好被ping通了
建议你排查一下你的路由情况,从目前来看,172到60方向,根本就没路可走
谢谢您得回答,我之前配置过静态路由,没什么效果。因为G0和G2是直连路由,路由表里面都有路由,理论是不用配置路由得。 路由器的G2口连接的三层交换的VLAN6,ACCES口。 核心交换机下VLAN6的主机网关设置成60.253可以ping通172段的网络。
望龙 发表时间:2018-05-02
呵呵 九段
粉丝:27人 关注:0人
两个网段下面的设备能ping通对端网段的网关吗?
可以ping通
望龙 发表时间:2018-05-02
