IRF Upgrade.
IRF upgrade requires that packet loss be minimized, high reliability, short interruption time, smooth upgrade, and excessively smooth configuration.
Instructions |
Preparations: |
1.
Save switch configuration: Save (on device and PC) |
2. Check whether the space of the two devices is enough, if not, delete /unreserved the extra files; |
3. Use the TFTP\FTP to upload the software package to the device, and use the Copy command to copy a copy to the backup device. |
4.Delete the .mdb file. |
Start : |
5.Disconnect the uplink and downlink of SW-2, then disconnect the stacking line and the MAD line to split IRF into two devices. |
Upgrade IRF standby device (SW-2): |
6.Confirm that SW2 is in a normal state,boot-loader and restart without saving the configuration, and check the version after completion. |
7. Disconnect SW-1 uplink and downlink , connect SW-2 uplink and downlink , check whether the service is normal; |
Upgrade SW-1 according to the method of SW-2. |
8.
Disconnect SW-2 uplink and downlink , connect SW-1 uplink and downlink , check whether the service is normal; |
9. Reconnect the stacking link, SW-2 will restart soon, and connect the uplink and downlink of SW-2 at the same time; |
After the IRF converges, check whether the service is normal. |
1.Remember to delete the .mdb file in the flash before upgrading.
2.Note: Be sure to apply for the change window!
No comments
案例意见反馈
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
