OCE所用的centos系统缺省即支持python2.3,使得我们可以使用暴力破解克星:DenyHosts
下载地址:***.***/projects/denyhosts/files/denyhosts/2.5/DenyHosts-2.5-python2.3.noarch.rpm/download
安装:
[root@localhost opt]# rpm -ivh DenyHosts-2.5-python2.3.noarch.rpm
Preparing... ########################################### [100%]
1:DenyHosts ########################################### [100%]创建配置文件:
[root@localhost /]# cd /usr/share/denyhosts/
[root@localhost denyhosts]# ls
CHANGELOG.txt denyhosts.cfg-dist plugins scripts
daemon-control-dist LICENSE.txt README.txt setup.py
[root@localhost denyhosts]# cp denyhosts.cfg-dist denyhosts.cfg缺省denyhosts.cfg文件的规则是:
1.同一个IP使用不存在的账号连续登录输入错误密码5次,即被封IP
2.同一个IP使用存在的非root账号连续登录输入错误密码10次,即被封IP
3.同一个IP使用root账号只要登录输入错误密码1次,即被封IP修改配置文件:
[root@localhost denyhosts]# vi denyhosts.cfg
将25行用#号注释掉 #SECURE_LOG=/private/var/log/system.log
让root账号有2次输错密码的机会,修改129行 DENY_THRESHOLD_ROOT = 3将denyhost启动脚本添加到服务中去:
[root@localhost denyhosts]# cp daemon-control-dist /etc/init.d/daemon-control启动脚本:
[root@localhost /]# service daemon-control start
starting DenyHosts: /usr/bin/env python /usr/bin/denyhosts.py --daemon --cOnfig=/usr/share/denyhosts/denyhosts.cfg查看状态:
[root@localhost /]# service daemon-control status
DenyHosts is running with pid = 14199
[root@localhost /]# ps -ef|grep 14199
root 14199 1 0 15:47 ? 00:00:00 python /usr/bin/denyhosts.py --daemon --cOnfig=/usr/share/denyhosts/denyhosts.cfg
root 14211 14074 0 15:48 pts/3 00:00:00 grep 14199可以使用的命令有
service daemon-control start/stop/status/restart/debug
更多帮助请参考文档
***.***/faq.html#3_16实时检查一下/etc/hosts.deny,可能需要10分钟左右就会出现黑客的IP,这些IP将无法使用ssh连接OCE服务器:
[root@localhost denyhosts]# tail -f /etc/hosts.deny
sshd: 125.131.226.196
sshd: 222.242.186.83
sshd: 59.103.0.133
sshd: 61.132.221.220
sshd: 221.236.13.28
sshd: 88.191.31.99
sshd: 125.46.54.252
sshd: 202.106.171.102
sshd: 69.197.163.178
sshd: 203.116.18.173下面是尝试攻击某OCE系统的所有IP地址:
[root@localhost ~]# cat /etc/hosts.deny
# hosts.deny This file contains access rules which are used to
# deny connections to network services that either use
# the tcp_wrappers library or that have been
# started through a tcp_wrappers-enabled xinetd.
# The rules in this file can also be set up in
# /etc/hosts.allow with a 'deny' option instead.
# See 'man 5 hosts_access' and 'man 5 hosts_options'
# for information on rule syntax.
# See 'man tcpd' for information on tcp_wrappers.
# The portmap line is redundant, but it is left to remind you that
# the new secure portmap uses hosts.deny and hosts.allow. In particular
# you should know that NFS uses portmap!
sshd: 121.9.212.73
sshd: 121.15.207.100
sshd: 202.109.242.18
sshd: 219.143.125.149
sshd: 210.176.183.154
sshd: 211.141.110.200
sshd: 125.88.130.12
sshd: 203.113.91.188
sshd: 122.225.30.22
sshd: 218.97.129.220
sshd: 222.73.177.179
sshd: 59.103.0.133
sshd: 221.236.13.28
sshd: 88.191.31.99
sshd: 125.46.54.252
该案例暂时没有网友评论
案例意见反馈
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
