对根叔知了社区有害的内容 >
对根叔知了社区有害的内容
话
S5024PV2-EI
2018-07-16发布
System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing.......................Done! **************************************************************************** * * * H3C S5024PV2-EI BootWare, Version 1.10 * * * **************************************************************************** Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Jun 5 2014 11:34:07 CPU Type : MIPS4kec CPU L1 Cache : 16KB CPU Clock Speed : 500MHz Memory Type : DDR3 SDRAM Memory Size : 128MB Memory Speed : 300MHz BootWare Size : 3MB Flash Size : 32MB BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/S5024PV2_EI-CMW520-R1105.bin!.................................. ............................................................. The main application file is invalid! Starting to get the backup application file--flash:/S5024PV2_EI-CMW520-R1105_bak.bin!.............................. .................................................................. The backup application file is invalid! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails! BootWare password: Not required. Please press Enter to continue. 按Ctrl+D和Ctrl+B都没有反应,求救解决办法
1个回复
1
粉丝:10人 关注:1人
是否多次重启还不行,如果是,设备故障,打他们400返修吧
回复
