对根叔知了社区有害的内容 >
对根叔知了社区有害的内容
3par存储的硬盘状态处于servicing
4天前发布
由于硬盘亮黄灯,随后检查其状态,输出信息如下
3par8000 cli% showpd -c
                             -------- Normal Chunklets -------- ---- Spare Chunklets ----
                             - Used - -------- Unused --------- - Used - ---- Unused ----
Id CagePos Type State  Total  OK Fail  Free Uninit Unavail Fail OK  Fail Free Uninit Fail
 0 0:0:0   SSD  normal  1787  28    0  1312      0       0    0 26     0  421      0    0
 1 0:1:0   SSD  normal  1787  28    0  1312      0       0    0 22     0  425      0    0
 2 0:2:0   SSD  normal  1787  30    0  1310      0       0    0  2     0  445      0    0
 3 0:3:0   SSD  normal  1787  29    0  1311      0       0    0  2     0  445      0    0
 4 0:4:0   SSD  normal  1787  30    0  1310      0       0    0  8     0  439      0    0
 5 0:5:0   SSD  normal  1787  29    0  1311      0       0    0  3     0  444      0    0
 6 0:6:0   SSD  normal  1787   0    0  1341      0       0    0  0     0  446      0    0
 7 0:7:0   SSD  normal  1787   0    0  1341      0       0    0  0     0  446      0    0
 8 total               14296 174    0 10548      0       0    0 63     0 3511      0    0
3par8000 cli% showpd -s
Id CagePos Type -State- -Detailed_State- -SedState--
 0 0:0:0   SSD  normal  normal           not_capable
 1 0:1:0   SSD  normal  normal           not_capable
 2 0:2:0   SSD  normal  normal           not_capable
 3 0:3:0   SSD  normal  normal           not_capable
 4 0:4:0   SSD  normal  normal           not_capable
 5 0:5:0   SSD  normal  normal           not_capable
 6 0:6:0   SSD  normal  servicing        not_capable
 7 0:7:0   SSD  normal  servicing        not_capable
 8 total
可以看到 disk ID 6和7的 Detailed_State 是servicing,并且查看showpd -c 的信息,这两块硬盘的容量没有正常使用 (字体加粗部分)
由于槽位6和槽位7做过硬盘插拔操作,怀疑是有残留的硬盘信息占用槽位,随后,本人执行removespare 6:a、removespare 7:a,将旧硬盘的残留信息移除,然后执行servicemag resume 0 6、servicemag resume 0 7,命令执行后的反馈信息如下:
3par8000 cli% servicemag resume 0 6
Are you sure you want to run servicemag?
select q=quit y=yes n=no: y
... mag 0 6 already onlooped
... firmware is current on pd WWN [5001173100533388] Id [ 6]
... checking for valid disks...
...   disks in mag  : 0 6
...      normal disks:  WWN [5001173100533388] Id [ 6]  diskpos [0]
...  not normal disks:
... verifying spare space for disks 6 and 6
... playback chunklets from pd WWN [5001173100533388] Id [ 6]
The servicemag resume operation will continue in the background.
3par8000 cli% servicemag resume 0 7
... mag 0 7 already onlooped
... firmware is current on pd WWN [5001173100462600] Id [ 7]
...   disks in mag  : 0 7
...      normal disks:  WWN [5001173100462600] Id [ 7]  diskpos [0]
... verifying spare space for disks 7 and 7
... playback chunklets from pd WWN [5001173100462600] Id [ 7]
3par8000 cli% servicemag status
Cage 0, magazine 7:
The magazine is being brought online due to a servicemag resume.
The last status update was at Mon Apr 14 11:03:52 2025.
The command started at Mon Apr 14 11:00:06 2025
Chunklet relocations have completed 28 in 4 minutes and 8 seconds
servicemag resume 0 7 -- is in Progress
再次通过showpd -s查看硬盘状态,其 Detailed_State 恢复为normal:
 6 0:6:0   SSD  normal  normal           not_capable
 7 0:7:0   SSD  normal  normal           not_capable
 8 total
0个回复
该话题暂时没有网友回复过
回复
