修改WA4320用户连接wifi时的密码,请wlan大神指点。
2020-09-24提问
  • 1收藏,1465浏览
杨帅 零段
XXXXXXXXXXXX>dis cu
 version 5.20, Release 1508P11
 sysname WA4320-ACN-SI_XXXXXX
 clock timezone UTC add 00:00:00
 domain default enable system
 telnet server enable
 port-security enable
 password-recovery enable
 undo attack-defense tcp fragment enable
vlan 1
vlan 400
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$EaL3JEMw2eP0QCGuI0YxtWQVJAbvBUze
 authorization-attribute level 3
 service-type telnet
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
 ssid XXXXX
 cipher-suite wep40
 wep default-key 1 wep40 pass-phrase cipher $c$3$+pyh0/IYaCMNlGoMpcg0e0B+i/yonU87
 service-template enable
cwmp
 undo cwmp enable
interface NULL0
interface Vlan-interface1
 ip address XXXXXXXXXXXXX
 speed 1000
 duplex full
interface WLAN-BSS32
 port link-type hybrid
 port hybrid vlan 1 400 untagged
interface WLAN-BSS33
interface WLAN-BSS36
interface WLAN-Radio1/0/1
 channel 149
 service-template 1 interface wlan-bss 32
interface WLAN-Radio1/0/2
 channel 1
 service-template 1 interface wlan-bss 33
 ip route-static 0.0.0.0 0.0.0.0 XXXXXXXXXX
 arp-snooping enable
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
粉丝:149人 关注:3人
官网上有配置举例:
https://www.h3c.com/cn/d_201707/1017280_30005_0.htm#_Toc488398545
1.3  WLAN安全典型配置举例
1.3.1  PSK认证典型配置举例
你需要修改int wlan-ess32和int wlan-ess 33 的加密方式,把服务模板下的
 cipher-suite wep40
删掉。
这些命令需要把服务模板关闭再修改,建议按照官网的例子举一反三
