HCL 1060
2020-09-24提问
  • 1收藏,829浏览
粉丝:0人 关注:6人
防火墙做的irf双机热备直连路由器不通,配置如下
设置列表
  • 有序列表
  • 无序列表
(2)     配置Track,监测上、下行接口的状态
[DeviceA] track 1 interface gigabitethernet 1/0/1
[DeviceA-track-1] quit
[DeviceA] track 2 interface gigabitethernet 1/0/2
[DeviceA-track-2] quit
[DeviceA] track 3 interface gigabitethernet 2/0/1
[DeviceA-track-3] quit
[DeviceA] track 4 interface gigabitethernet 2/0/2
[DeviceA-track-4] quit
(3)     配置以太网冗余接口
# 创建以太网冗余接口Reth11。
[DeviceA] interface reth 11
[DeviceA-Reth11] member interface gigabitethernet 1/0/1 priority 100
[DeviceA-Reth11] member interface gigabitethernet 2/0/1 priority 80
[DeviceA-Reth11] ip address 51.1.1.2 255.255.255.0
[DeviceA-Reth11] quit
# 创建以太网冗余接口Reth12。
[DeviceA] interface reth 12
[DeviceA-Reth12] member interface gigabitethernet 1/0/2 priority 100
[DeviceA-Reth12] member interface gigabitethernet 2/0/2 priority 80
[DeviceA-Reth12] ip address 52.1.1.2 255.255.255.0
[DeviceA-Reth12] quit
(4)     配置冗余组
# 创建冗余组a。
[DeviceA] redundancy group a
# 将以太网冗余接口Reth11和Reth12加到冗余组a中。
[DeviceA-redundancy-group-a] member interface reth 11
[DeviceA-redundancy-group-a] member interface reth 12
# 创建Node 1,Node 1和Device A绑定,为主节点。关联的Track项为1和2。
[DeviceA-redundancy-group-a] node 1
[DeviceA-redundancy-group-a-node1] bind slot 1
[DeviceA-redundancy-group-a-node1] priority 20
[DeviceA-redundancy-group-a-node1] track 1 interface gigabitethernet 1/0/1
[DeviceA-redundancy-group-a-node1] track 2 interface gigabitethernet 1/0/2
[DeviceA-redundancy-group-a-node1] quit
# 创建Node 2,Node 2和Device B绑定,为备节点。关联的Track项为3和4。
[DeviceA-redundancy-group-a] node 2
[DeviceA-redundancy-group-a-node2] bind slot 2
[DeviceA-redundancy-group-a-node2] priority 10
[DeviceA-redundancy-group-a-node2] track 3 interface gigabitethernet 2/0/1
[DeviceA-redundancy-group-a-node2] track 4 interface gigabitethernet 2/0/2
[DeviceA-redundancy-group-a-node2] quit
[DeviceA-redundancy-group-a] quit
(5)     开启会话业务热备份功能
粉丝:124人 关注:6人
关于防火墙部署双机热备后路由器无法PING通的问题,以下是排查要点,请参考:
1、检查涉及到的物理端口、冗余口是否已加入安全域。
2、检查下安全策略或域间策略是否已放通,尤其到LOCAL域的策略。
3、检查下物理端口的状态是否已UP。
4、确保两端都已经配置了路由的发布或指向。
Xcheng 九段
粉丝:121人 关注:3人
模拟器目前不支持验证冗余组。。。
虽然能配置,但是结果是不对的。。。
建议更换真机测试,如果有需要的话。
