IRF模式切换成正常模式怎么操作
2020-09-28提问
  • 1收藏,3110浏览
IRF模式切换成正常模式怎么操作
粉丝:22人 关注:1人
(1)       断开IRF连接。可以直接将IRF物理连接线缆拔出也可以使用命令行关闭主设备上所有的IRF物理端口。
(2)       IRF分裂后,分别将两台成员设备从IRF模式切换到独立运行模式。
 配置步骤
(1)       确定主设备。
<IRF> display irf
MemberID  Slot  Role    Priority  CPU-Mac         Description
 *+1      0     Master  1         00e0-fc0f-8c01  DeviceA
   1      3     Standby 1         00e0-fc0f-8c02  DeviceA
   2      0     Standby 1         00e0-fc0f-15e1  DeviceB
   2      3     Standby 1         00e0-fc0f-15e2  DeviceB
 The Bridge MAC of the IRF is: 0000-fc00-313e
 Auto upgrade                : no
 Mac persistent              : always
 Domain ID                   : 1
 Auto merge                  : no
通过以上显示信息可以看出,Device A是主设备。
(2)       断开IRF连接:手工关闭主设备(Device A)的IRF物理端口Ten-Gigabitethernet 1/3/1/1
<IRF> system-view
[IRF] interface ten-gigabitethernet 1/3/1/1
[IRF-Ten-Gigabitethernet1/3/1/1] shutdown
[IRF-Ten-Gigabitethernet1/3/1/1] quit
(3)       Device AIRF端口的配置删除
[IRF] irf-port 1/2
[IRF-irf-port1/2] undo port group interface ten-gigabitethernet1/3/1/1
[IRF-irf-port1/2] quit
(4)       Device A的运行模式切换到独立运行模式。
[IRF] undo chassis convert mode
The device will switch to stand-alone mode and reboot. Continue?[Y/N]:
Before pressing ENTER you must choose 'YES' or 'NO'[Y/N]:y
You are recommended to save the current running configuration and specify the co
nfiguration file for the next startup. Now save the running configuration to the
 next-startup configuration file? [Y/N]:y
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
Do you want to convert the content of the next startup configuration file cfa0:/
startup.cfg to make it available in stand-alone mode? [Y/N]:y
Now rebooting, please wait...
Device A自动重启来完成模式的切换。
(5)       登录Device B后,将Device BIRF端口的配置删除
<IRF> system-view
[IRF] interface ten-gigabitethernet 2/3/1/1
[IRF-Ten-Gigabitethernet2/3/1/1] shutdown
[IRF-Ten-Gigabitethernet2/3/1/1] quit
[IRF] irf-port 2/1
[IRF-irf-port2/1] undo port group interface ten-gigabitethernet2/3/1/1
[IRF-irf-port2/1] quit
(6)       Device B的运行模式切换到独立运行模式。
Device B自动重启来完成模式的切换。
如果IRF上创建了VLAN接口、配置了IP地址,并且Device ADevice B上都存在该VLAN的成员端口(即配置了端口加入VLAN)。此时,Device ADevice B恢复到独立运行模式后,会产生IP地址冲突,请登录其中一台设备,修改该VLAN接口的IP地址。
粉丝:24人 关注:13人
取消irf的配置,接口不要绑定
粉丝:124人 关注:6人
关于将IRF切换回正常模式,看下是否有可以恢复出厂设置,如果可以,先清空配置,让两台设备都从IRF分裂出来。
然后在2号机上使用irf member 1 renumber 1切换回正常的端口号。
有些型号的设备还需要单独的命令切换回正常模式。要看具体的型号才能确定。
