MSR830的PPPOE IPV6设置问题
2020-09-29提问
  • 1收藏,1580浏览
零段
现情况:路由器通过PPPOE拨号上网,光猫能支持IPV4/IPV6,现经过设置后,路由运行ping ipv6 240c::6666能通(240C::6666为外网DNS),但VLAN 1下的终端ping 不通240c::6666,但能ping通路由器的外网口获取到的IPV6地址。配置如下,不知哪里设置有问题。麻烦大咖帮帮忙看有没办法解决
型号:MSR830-WiNet
软件版本:CMW520-R2516P22
固件版本:5.10
硬件版本:2.0
配置内容:
 version 5.20, Release 2516P22
 sysname H3C
 clock timezone Beijing add 08:00:00
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0
 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dns resolve dns proxy enable
 dns server 114.114.114.114
 dns server 202.96.128.86
 dns server 172.16.3.253
 dns server ipv6 240C::6666
 dns server ipv6 240C::6644
 ipv6 ipv6 unreachables enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 ntdp hop 8
 cluster enable
 port-security enable
 password-recovery enable
 blacklist enable blacklist ip 45.144.3.168
 ipv6 dhcp server enable
 ipv6 dhcp prefix-pool 1 prefix 1::/64 assign-len 64
 vlan 1
 domain system
 authentication ppp local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 ip pool 1 192.168.2.100 192.168.2.254
 traffic behavior behaviorfordeny
 filter deny
 dhcp server ip-pool vlan1 extended
 network ip range 172.16.0.1 172.16.0.254
 network mask 255.255.255.0
 gateway-list 172.16.0.1
 dns-list 172.16.0.1
 user-group system
 group-attribute allow-guest
 local-user admin
 authorization-attribute level 3
 service-type telnet
 service-type web
 cwmp undo cwmp enable
 ddns policy guanjiapo
 interval 0 0 12
 url ***.***/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
 username XXXXXX
 password cipher XXXXXXXXXXXXXXXXXXXXXXXXXXXX
 ipv6 dhcp pool 1
 network 1::/64 preferred-lifetime 432000 valid-lifetime 864000
 prefix-pool 64
 domain-name cnicg-ipv6
 dns-server 240C::6666
 dns-server 240C::6644
 interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
 interface Dialer10
 nat outbound
 nat server 1 protocol tcp global current-interface 211 inside 172.16.8.254 211
 nat server 2 protocol udp global current-interface 211 inside 172.16.8.254 211
 nat server 3 protocol tcp global current-interface 38000 inside 192.168.110.93 443
 nat server 4 protocol udp global current-interface 38000 inside 192.168.110.93 443
 nat server 5 protocol tcp global current-interface 38001 inside 192.168.110.93 8443
 nat server 6 protocol udp global current-interface 38001 inside 192.168.110.93 8443
 nat server 7 protocol tcp global current-interface 49283 inside 172.16.3.234 49283
 nat server 8 protocol tcp global current-interface 38100 inside 192.168.110.78 443
 ipv6 address auto
 ipv6 address auto link-local
 ipv6 mtu 1492
 link-protocol ppp
 ppp chap user 020XXXXXXX@163.gd
 ppp chap password cipher XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
 ppp pap local-user 020XXXXXXX@163.gd password cipher XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
 ddns apply policy guanjiapo fqdn ***.***
 interface Virtual-Ethernet1
 ip netstream inbound
 interface NULL0
 interface Vlan-interface1
 ipv6 nd ra interval 60 10
 undo ipv6 nd ra halt
 ipv6 nd autoconfig other-flag
 ipv6 address 1::/64 eui-64
 ipv6 mtu 1492
 ip address 172.16.0.1 255.255.255.0
 tcp mss 1024
 dhcp server apply ip-pool vlan1
 arp send-gratuitous-arp interval 2000
 ipv6 dhcp server apply pool 1 allow-hint preference 255 rapid-commit
 interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 pppoe-client dial-bundle-number 10
 interface GigabitEthernet0/4
 tcp mss 1024
 interface GigabitEthernet0/1
 port link-mode bridge
 interface GigabitEthernet0/2
 interface GigabitEthernet0/3
 ripng 1
 cluster
 ip-pool 192.168.171.1 255.255.255.0
 build WiNet
 cluster-local-user admin password cipher $c$3$e/X1GyifK+2Rumr0S3Owk7gGw+5FYliomyoR
 management-vlan synchronization enable
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 ip route-static 10.0.0.0 255.255.255.0 172.16.0.2
 ip route-static 172.16.1.0 255.255.255.0 172.16.0.2
 ip route-static 172.16.2.0 255.255.255.0 172.16.0.2
 ip route-static 172.16.3.0 255.255.255.0 172.16.0.2
 ip route-static 172.16.8.0 255.255.255.0 172.16.0.2
 ip route-static 172.16.9.0 255.255.255.0 172.16.0.2
 ip route-static 172.16.50.0 255.255.255.0 172.16.0.2
 ip route-static 192.168.110.0 255.255.255.0 172.16.0.2
 ipv6 route-static :: 0 Dialer10
 ipv6 route-static 2:: 64 Vlan-interface1 1::
 snmp-agent
 snmp-agent local-engineid 800063A2039C061BB35400
 snmp-agent sys-info version all
 undo snmp-agent trap enable voice dial
 ip netstream timeout active 1
 ip netstream timeout inactive 15
 ip netstream export version 9
 ip netstream export host 172.16.8.200 9996
 ip netstream export source interface Vlan-interface1
 ip netstream export v9-template refresh-rate time 60
 dhcp enable
 ntp-service unicast-server 203.107.6.88
 arp static 172.16.0.2 082e-5f52-ce00 1 GigabitEthernet0/1
 ip https enable
 dialer-rule 10 ip permit dialer-rule 1 ip permit
 nms primary monitor-interface Dialer10
 ip flow-ordering stat-interval 30
 load xml-configuration
 load tr069-configuration
 user-interface con 0
 user-interface tty 13
 user-interface vty 0 4
 authentication-mode scheme
 return
display ipv6 interface Dialer 10
Dialer10 current state :UP
 Line protocol current state :UP
 IPv6 is enabled, link-local address is FE80::9E06:1BD3:7CB3:5400
 Global unicast address(es):
 240E:F8:AD:139D:9E06:XXXX:XXXX:XXXX, subnet is 240E:F8:AD:139D::/64 [AUTOCFG]   (公网IPV6能获取,在此隐藏)
 [valid lifetime 2591682s/preferred lifetime 604482s]
  Joined group address(es):
 FF02::1:FF00:0
 FF02::1:FFB3:5400
 FF02::2 FF02::1
 MTU is 1492 bytes
 ND retransmit interval is 3000 milliseconds
 IPv6 Packet statistics:
 InReceives: 26
 InTooShorts: 0
 InTruncatedPkts: 0
 InHopLimitExceeds: 0
 InBadHeaders: 0
 InBadOptions: 0
ReasmReqds: 0
 ReasmOKs: 0
 InFragDrops: 0
 InFragTimeouts: 0
 OutFragFails: 0
 InUnknownProtos: 0
 InDelivers: 26
 OutRequests: 15
 OutForwDatagrams: 26595
 InNoRoutes: 0
 InTooBigErrors: 0
 OutFragOKs: 0
 OutFragCreates: 0
 InMcastPkts: 0
 InMcastNotMembers: 0
 OutMcastPkts: 0
 InAddrErrors: 0
 InDiscards: 0
 OutDiscards: 0
display ipv6 interface Vlan-interface 1
 IPv6 is enabled, link-local address is FE80::9E06:1BFF:FEB3:5403
 1::9E06:1BFF:FEB3:5403, subnet is 1::/64
 FF02::1:FF00:0
 FF02::1:2
 FF02::1:FFB3:5403
 FF02::2
 FF02::1
 FF05::1:
 MTU is 1492 bytes
 ND router advertisements are sent every 60 seconds
 ND router advertisements live for 1800 seconds Hosts use
 DHCP to obtain routable addresses. Hosts use
 DHCP to obtain other configuration
 InReceives: 27927
 InTooShorts: 0
 InTruncatedPkts: 0
 InBadHeaders: 0
 InBadOptions: 0
 ReasmReqds: 0
 ReasmOKs: 0
 InFragDrops: 0
 InFragTimeouts: 0
 OutFragFails: 0
 InUnknownProtos: 0
 InDelivers: 815
 OutRequests: 1009
 OutForwDatagrams: 0
 InNoRoutes: 0
 InTooBigErrors: 0
 OutFragOKs: 0
 OutFragCreates: 0
 InMcastPkts: 99
 InMcastNotMembers: 9
 OutMcastPkts: 315
 InAddrErrors: 0
 InDiscards: 0
 OutDiscards: 0
粉丝:22人 关注:1人
MSR V5设备只能实现设备上IPv6网,但不能使其终端通过IPv6上网。
V7设备通过PD方式为终端分配地址。
MSR830-WiNet有V7的升级包??
发表时间:2020-09-29
MSR不能跨版本升级。
江山青 发表时间:2020-09-29
