S5130S-52S-HI断电重新上电后反复重启
2020-10-01提问
  • 1收藏,921浏览
S5130S-52S-HI断电重新上电后反复重启,开机提示信息如下:
#vStarting......
Press Ctrl+D to access BASIC BOOT MENU
Booting Normal Extend BootWare....
*                H3C S5130S-52S-HI Switch BOOTROM, Version 133                 *
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.
Creation Date       : Oct 23 2019, 09:18:44
CPU Clock Speed     : 800MHz
Memory Size         : 512MB
Flash Size          : 256MB
CPLD Version        : 001
PCB Version         : Ver.B
Mac Address         : 703d152ce1c0
Press Ctrl+B to access EXTENDED BOOT MENU...0
Loading the main image files...
Loading file flash:/s5130s_hi-cmw710-system-r6311.bin...........................
.......................Done.
Loading file flash:/s5130s_hi-cmw710-boot-r6311.bin.........Done.
Image file flash:/s5130s_hi-cmw710-boot-r6311.bin is self-decompressing.........
..Done.
System is starting...
            Board checking.......................LSP9LTSUD
            SDRAM fast selftest........................OK!
            Flash fast selftest........................OK!
            CPLD selftest..............................OK!
            Switch chip selftest.......................OK!
            PHY selftest...............................OK!
            Please check leds....................FINISHED!
Cryptographic algorithms tests passed.
[Starting......
## Switch baudrate to 115200 bps and press ENTER ...
    Starting......
Memory Size         : 512MB
Flash Size          : 256MB
CPLD Version        : 001
PCB Version         : Ver.B
Loading file flash:/s5130s_hi-cmw710-system-r6311.bin............... B    cStarting......
..Done.
  Starting......
Memory Size         : 512MB
Flash Size          : 256MB
CPLD Version        : 001
PCB Version         : Ver.B
Mac Address         : 703d152cf0c0
粉丝:30人 关注:0人
您好,感觉像是版本丢失了,可以尝试在boot下单独传版本试试,若依旧有问题,建议拨打400看一下是否是设备故障
粉丝:124人 关注:6人
看到交换机一直在加载系统,有可能是软件版本文件损坏了。
可以考虑重新导入一个新的软件版本到设备后再重新启动看下。
以下是S5130S-HI系列的软件版本下载链接:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S5130/H3C_S5130S_HI/
用户名:yx800
密码:01230123
注意查看软件版本说明书,有适配和升级的说明。
