H3C交换机
2020-10-09提问
  • 1收藏,1522浏览
百兆更换千兆交换机后大文件传输丢包,导致大文件无法上传共享库。
粉丝:6人 关注:3人
在交换机做几层转发,一般交换机查表转的,查表硬转的话,交换机没有MTU的概念,此时受最大帧长度控制。低于最大帧长度,转发;帧长度高于最大帧长度,丢弃。是否有做过流统看丢包丢在什么位置,先确认丢包位置吧,看是否丢包设备配置了包过滤等策略过滤掉了。
粉丝:14人 关注:0人
请贴拓扑图和交换机的配置。
二层配置
19口为设备所在口
[C_1F_3]dis current-configuration
version 7.1.070, Release 6126P20
sysname C_1F_3
clock timezone beijing add 08:00:00
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 1
dot1x timer quiet-period 30
dot1x timer handshake-period 20
dot1x timer reauth-period 7200
dot1x timer server-timeout 200
dot1x timer supp-timeout 20
dot1x timer tx-period 20
lldp global enable
password-recovery enable
vlan 1
vlan 8
vlan 10
vlan 17
vlan 20
stp global enable
interface NULL0
interface Vlan-interface1
ip address 172.31.1.41 255.255.255.0
description ESXI
storm-constrain broadcast ratio 10 10
storm-constrain multicast ratio 10 10
storm-constrain unicast ratio 10 10
storm-constrain control block
description OA
port access vlan 10
description CRM
port access vlan 10
interface GigabitEthernet1/0/4
description RMD
port access vlan 17
interface GigabitEthernet1/0/5
description TS-IMB
port access vlan 10
interface GigabitEthernet1/0/6
description TS-DELL
port access vlan 10
interface GigabitEthernet1/0/7
description Inspur
port access vlan 10
interface GigabitEthernet1/0/8
port access vlan 10
interface GigabitEthernet1/0/9
port access vlan 10
interface GigabitEthernet1/0/10
port access vlan 10
interface GigabitEthernet1/0/11
port access vlan 8
interface GigabitEthernet1/0/12
port access vlan 8
interface GigabitEthernet1/0/13
port access vlan 10
interface GigabitEthernet1/0/14
port access vlan 10
interface GigabitEthernet1/0/15
port access vlan 10
interface GigabitEthernet1/0/16
port access vlan 10
interface GigabitEthernet1/0/17
port access vlan 10
interface GigabitEthernet1/0/18
description CSG-Cloud
port access vlan 10
interface GigabitEthernet1/0/19
description ??Э?
port access vlan 10
flow-control
interface GigabitEthernet1/0/20
description AC
interface GigabitEthernet1/0/21
description ?????
port access vlan 10
interface GigabitEthernet1/0/22
port access vlan 10
interface GigabitEthernet1/0/23
port access vlan 10
interface GigabitEthernet1/0/24
port access vlan 10
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
description ?θ?
port link-type trunk
port trunk permit vlan 1 7 to 8 10 17 20
scheduler logfile size 16
line class aux
user-role network-admin
line class vty
user-role network-operator
line aux 0
authentication-mode password
user-role level-2
set authentication password hash $h$6$/YnPIZIwKE1Cwgsb$njQFIx7Pvn21UIMC32afS/FslngM6P7/oFsdudkvclqQTIYMNCGRgnpZ9wkbcdEPgp41Ac+jTF/GV+2myZdCUg==
line vty 0 3
authentication-mode scheme
line vty 4
user-role level-15
line vty 5 15
line vty 16 63
ip route-static 0.0.0.0 0 172.31.1.14
ntp-service unicast-server 172.16.0.250
super password role network-admin hash $h$6$mh/VImZbSDHQTmvx$cXhBwdDMYb57TdD6b9v8lsfvKK/iHlkxiTVQCynbt+MzStY9rj4+DW8B19P/R89YuyUNf+4lLHZpuWdi3hWlvQ==
radius scheme system
user-name-format without-domain
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
password hash $h$6$ifuU/LwQLC5C/zGL$qEv3Y47M0OI3xtukJ58zfwZT5IVVBME/Id7wLf33LhvVM2yfCdT/5QyQkCVJR52OTkIFBBrDlIyBAXUXTMoRqQ==
service-type telnet http https terminal
authorization-attribute idle-cut 60
authorization-attribute user-role level-15
ip http enable
ip https enable
return
