H3C EWPX1WCME0版本升级System image is starting加载后卡住
2018-04-27提问
  • 1收藏,1860浏览
Zekkz 零段
设备从Release 5121P32版本升级到Release 5221版本
出现以下现象卡住
Image file cfa0:/boot.bin is self-decompressing............................. .............................Done.
System image is starting...
31:Using default Mac address 31:Sanity Check failed on prom_info @ 8025ecf8 31:sizeof(psb_info) = 288, psb_info_version = 1, prom_info->magic_dword = 900dbeef00000001, prom_info->size = 120
31:argc=7, argv=80007fb0, envp=0, prom_info=8025ecf8
31:argv[1] = [mem=128M]
 31:argv[2] = [cOnsole=ttyS1,9600] 31:argv[3] = [pages_linux=0x0a00] 31:argv[4] = [use_new_sema]
31:argv[5] = [nmi_clear_erl ]
 31:argv[6] = [comware_address=0x82500000]
31:blinux will use new semaphore implementation!
31:_orion_timer_intercept @ mips/rtl_time.c 254 is called
 31:hello,world!
31:Now we call COMWARE entry!
卡了大概有有半小时左右
粉丝:3人 关注:0人
 EWPX1WCME0  您的这个ac是v7还是v5的,另外您的这个报错是启动的错误么 ?版本的是否正确
