双链路出口问题
2020-10-14提问
  • 2关注
  • 1收藏,1008浏览
小男 零段
原来使用1条电信的做单位互联网访问,新增1条联通的作为备用链路,如何配置?当1条链路出现问题时自动切换另一条线路?
知道的大神指教,求带命令。
设置列表
  • 有序列表
  • 无序列表
[H3C]display current-configuration
 version 7.1.064, Release 7617
mdc Admin id 1
 sysname H3C
 password-recovery enable
vlan 1
interface Serial3/2/0
interface Serial3/2/1
interface Serial3/2/2
interface Serial3/2/3
interface Serial3/2/4
interface Serial3/2/5
interface Serial3/2/6
interface Serial3/2/7
interface NULL0
interface GigabitEthernet3/0/0
 port link-mode route
 combo enable copper
interface GigabitEthernet3/0/1
 combo enable copper
interface GigabitEthernet3/1/0
 ip address 10.1.1.1 255.255.255.252
 nat outbound
interface GigabitEthernet3/1/1
interface GigabitEthernet3/1/2
interface GigabitEthernet3/1/3
interface GigabitEthernet3/1/4
interface GigabitEthernet3/1/5
interface GigabitEthernet3/1/6
interface GigabitEthernet3/1/7
 ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet3/4/0
interface GigabitEthernet3/4/1
interface GigabitEthernet3/4/2
interface GigabitEthernet3/4/3
interface GigabitEthernet3/4/4
interface GigabitEthernet3/4/5
interface GigabitEthernet3/4/6
interface GigabitEthernet3/4/7
interface M-GigabitEthernet0/0/0
 scheduler logfile size 16
line class aux
 user-role network-admin
line class vty
 user-role network-operator
line aux 0 1
line vty 0 4
 authentication-mode scheme
line vty 5 63
 ip route-static 0.0.0.0 0 211.160.246.21
 ssh server enable
 ssh user xxxxx service-type stelnet authentication-type password
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user xywdgs class manage
 password hash xxxx
 service-type ssh telnet terminal https
public-key peer 192.168.10.1
 public-key-code begin
   xxxxxx
 public-key-code end
 peer-public-key end
return
小茶 五段
粉丝:5人 关注:0人
做NQA和track联动探测
等于没说、好像又说了点什么
小男 发表时间:2020-10-14
粉丝:124人 关注:6人
关于双链路在主链路故障时能快速切换,可以部署NQA检测来实现,以下是配置举例,请参考:
1.7.15  NQA联动配置举例
·     Router A到达Router C的静态路由下一跳为Router B。
·     在Router A上通过静态路由、Track与NQA联动,对到达Router C的静态路由有效性进行实时判断。
图1-17 NQA联动配置组网图
(1)     配置各接口的IP地址。(配置过程略)
(2)     在Router A上配置静态路由,并与Track项关联。
# 配置到达Router C的静态路由下一跳地址为10.2.1.1,并配置静态路由与Track项1关联。
[RouterA] ip route-static 10.1.1.2 24 10.2.1.1 track 1
(3)     在Router A上配置NQA测试组
# 创建管理员名为admin、操作标签为test1的NQA测试组。
[RouterA] nqa entry admin test1
# 配置测试类型为ICMP-echo。
[RouterA-nqa-admin-test1] type icmp-echo
# 配置目的地址为10.2.1.1。
[RouterA-nqa-admin-test1-icmp-echo] destination ip 10.2.1.1
# 测试频率为100ms。
[RouterA-nqa-admin-test1-icmp-echo] frequency 100
# 配置联动项1(连续失败5次触发联动)。
[RouterA-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[RouterA-nqa-admin-test1-icmp-echo] quit
# 启动ICMP-echo探测操作,并一直进行测试。
[RouterA] nqa schedule admin test1 start-time now lifetime forever
(4)     在Router A上配置Track项
# 配置Track项1,关联NQA测试组(管理员为admin,操作标签为test1)的联动项1。
[RouterA] track 1 nqa entry admin test1 reaction 1
# 显示Router A上Track项的信息。
[RouterA] display track all
Track ID: 1
  State: Positive
  Duration: 0 days 0 hours 0 minutes 0 seconds
  Notification delay: Positive 0, Negative 0 (in seconds)
  Tracked object:
    NQA entry: admin test1
    Reaction: 1
# 显示Router A的路由表。
Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         Static 60   0            10.2.1.1        GE1/0/1
10.2.1.0/24         Direct 0    0            10.2.1.2        GE1/0/1
10.2.1.0/32         Direct 0    0            10.2.1.2        GE1/0/1
10.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.255/32       Direct 0    0            10.2.1.2        GE1/0/1
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
以上显示信息表示,NQA测试的结果为下一跳地址10.2.1.1可达(Track项状态为Positive),配置的静态路由生效。
# 在Router B上删除接口GigabitEthernet1/0/1的IP地址。
<RouterB> system-view
[RouterB-GigabitEthernet1/0/1] undo ip address
Track ID: 1
  State: Negative
  Tracked object:
    Reaction: 1
# 显示Router A的路由表。
Destinations : 12        Routes : 12
以上显示信息表示,NQA测试的结果为下一跳地址10.2.1.1不可达(Track项状态为Negative),配置的静态路由无效。
我这边只有1个路由器
小男 发表时间:2020-10-14
您好,一个路由器也是可以做的,由于是双链路出去。
得闲饮茶013 发表时间:2020-10-14
粉丝:2人 关注:9人
默认情况下一条链路出现问题就是会切换到另一条的,为了切换的及时性,可以配置NOA探测来检测链路健康性:官网配置手册:https://www.h3c.com/cn/d_201606/931729_30005_0.htm#_Toc451718539
官网好复杂啊,我还是小白。
小男 发表时间:2020-10-14
你参考track结合静态路由配置的那个案例即可
卡卡西c 发表时间:2020-10-14
