H3C WA4320-ACN 无线AP 无法连接AC
2020-10-14提问
  • 1收藏,2745浏览
WA4320-ACN 登入console口,会出现以下提示:
%Mar 27 08:32:30:997 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:33:00:997 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:33:31:154 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:34:01:034 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:34:31:036 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:35:01:032 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:35:31:157 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:36:01:053 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:36:21:198 2017 H3C SHELL/5/SHELL_LOGIN: Console logged in from con0. %Mar 27 08:36:31:051 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008). %Mar 27 08:36:36:185 2017 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is dir <H3C>%Mar 27 08:37:01:050 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008
另外无线AP的灯是绿色的
粉丝:47人 关注:4人
就是AP的上行接口与对端设备接口的PVID不一致,关系不大,AP绿色常亮 应该是没注册在线。
A.1  指示灯
WA4320-ACN的指示灯说明如下表所示。
表A-1 指示灯状态说明
指示灯
指示灯颜色
指示灯状态
状态说明
橙色
常亮
设备上电启动中
1Hz闪烁
以太网口或射频口异常(以太网接口down或检测不到射频接口等)
2Hz闪烁
Blink模式
配置Blink状态检测功能后,关联到AC的Fit AP闪烁指示灯以示关联AC成功
绿色
常亮
Fit AP未成功注册到AC前一直处于此状态
1Hz闪烁
2.4G射频接口有客户端在线
蓝色
常亮
AP已经启动完成,正处于待机状态(无客户端在线)
当工作在Fit模式时,表示已经成功注册到AC
1Hz闪烁
5G射频接口有客户端在线
2Hz闪烁
AP正在更新应用程序(AP工作在Fit模式时特有的状态)
绿蓝交替
1Hz交替闪烁
2.4G和5G射频接口均有客户端在线
常灭
设备初始化异常
那你现在就要就是要排查AP为啥没有在线,AC与APping一下看能否Ping  通,然后看下AC上的配置有没有正确,二层注册还是三层注册。
粉丝:124人 关注:6人
%Mar 27 08:37:01:050 2017 H3C LLDP/5/LLDP_PVID_INCONSISTENT: PVID mismatch discovered on GigabitEthernet1/0/1 (PVID 1), with WW-ZYB-B-Fu-1F GigabitEthernet0/0/9 (PVID 3008  //提示本端和对端的pvid不一致。
关于AP无法上线,以下是排查要点,请参考:
1、确保基础网络可达,比如二层注册的VLAN透传、三层注册的路由可达。
2、确保AP能适配到AC。
3、确保AC的授权足够。
4、确保DHCP地址池空间范围足够。
5、确保AP的序列号已在AC内正确注册完成。
粉丝:24人 关注:1人
这个日志是邻居学习到的pvid不一致,ap不上线,建议先检查ap是否为瘦ap、ap是否获取到地址、到ac是否可达
zhiliao_e9UzS7 知了小白
把AP重置后,就恢复正常,谢谢各位大哥!
