ACG1030升级之后出错
2020-10-14提问
  • 1收藏,1030浏览
Bootloader V1.4(Build time: Jun 11 2014 - 14:52:43) board revision major:2, minor:0 OCTEON CN5020-SCP pass 1.1, Core clock: 700 MHz, DDR clock: 199 MHz (398 Mhz data rate) WARNING: WARNING: Measured DDR clock mismatch! expected: 333 MHz, measured: 199 MHz, cpu clock: 700 MHz WARNING: Using measured clock for configuration. WARNING: DRAM: 2048 MB Flash: 4 MB Clearing DRAM........ done BIST check passed. Starting PCI PCI Status: PCI 32-bit PCI BAR 0: 0x00000000, PCI BAR 1: Memory 0x00000000 PCI 0xf8000000 Net: octeth0, octeth1, octeth2 Bus 0 (CF Card): OK ide 0: Model: SMI MODEL Firm: 20111006 Ser#: 20090410 000040A2 Type: Removable Hard Disk Capacity: 487.7 MB = 0.4 GB (998928 x 512) Press Ctrl+C to stop auto start : 0 Loading serial.no .reading serial.no ** Unable to read "serial.no" from ide 0:1 ** ******** load serial.no failed Loading startup.cfg .reading startup.cfg Loading vmlinux.64 .reading vmlinux.64 /sbin/rc starting Mounting file systems Setting up loopback fsck.fat 3.0.26 (2014-03-07) Starting check/repair pass. Starting verification pass. /dev/sda1: 974 files, 47668/62333 clusters [ 168.194621] ata3.00: exception Emask 0x10 SAct 0x0 SErr 0x30000 action 0xe [ 168.277055] ata3: SError: { PHYRdyChg PHYInt } [ 168.330304] ata3.00: failed command: READ DMA EXT [ 168.386693] ata3.00: cmd 25/00:f8:37:79:04/00:00:1d:00:00/e0 tag 0 dma 126976 in [ 168.386693] res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x30 (host bus error) [ 168.572239] ata3.00: status: { DRDY }
建议拨打400咨询一下
