F1000-AK110
2020-10-14提问
  • 1收藏,850浏览
两台防护墙搭建IPsec,由于一端地址不固定,故采用野蛮模式。
配置完后ike sa 已建立,但无法通信。检查感兴趣流,加密认证方式均无问题。
烦请大神帮忙协助一下。
相关配置已添加至附件
ipsec sa有吗,可以看一下是否有感兴趣流互相包含的情况。
ipsec sa没有建立成功
A波波1 发表时间:2020-10-14
总部这边remote-address后面添加的是主机名,是需要能够解析出来的地址,若不固定可以不配: # ipsec policy GE1/0/10 1 isakmp transform-set GE1/0/10_IPv4_1 security acl name IPsec_GE1/0/10_IPv4_1 local-address 113.140.12.18 remote-address F100 ike-profile GE1/0/10_IPv4_1
我不是我没有别瞎说啊 发表时间:2020-10-14
主机名不应该是 ike identity fqdn的值吗,还是要怎么设置
可以参考命令手册,这个主机名是需要解析的而不是fqdn:https://www.h3c.com/cn/d_202006/1308294_30005_0.htm#_Toc43392940 hostname:IPsec隧道的对端主机名,为1~253个字符的字符串,不区分大小写。该主机名可被DNS服务器解析为IP地址。
总部配置:
[H3C]dis cur
interface GigabitEthernet1/0/10
port link-mode route
ip address 113.140.12.18 255.255.255.252
nat outbound 3000
ipsec apply policy GE1/0/10
ip route-static 0.0.0.0 0 113.140.12.17
ip route-static 10.0.0.0 8 10.234.235.213 description to beijing mi
ip route-static 10.240.68.0 22 10.254.254.2 description to vlan 5
ip route-static 10.240.70.0 24 113.140.12.17 description to ipsec vpn
acl advanced 3000
rule 5 deny ip source 10.240.68.0 0.0.1.255 destination 10.240.70.0 0.0.0.255
rule 7 deny ip source 10.108.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 9 deny ip source 10.132.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 11 deny ip source 10.237.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 13 deny ip source 10.115.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 20 permit ip
acl advanced name IPsec_GE1/0/10_IPv4_1
rule 1 permit ip source 10.240.68.0 0.0.1.255 destination 10.240.70.0 0.0.0.255
rule 2 permit ip source 10.108.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 3 permit ip source 10.132.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 4 permit ip source 10.237.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
rule 5 permit ip source 10.115.0.0 0.0.255.255 destination 10.240.70.0 0.0.0.255
local-user admin class manage
password hash $h$6$xOepK/5371cBciGm$Mq3iHCQCidZUQzfzAi5bf0epLaQD1VU+RGsB9sHUokOgZJtIU6a7pRz41+d6obmqGeWsBo0IH6ZylpbgfpCGow==
service-type ftp
service-type ssh terminal https
authorization-attribute work-directory slot1#flash:
authorization-attribute user-role level-15
session top-statistics enable
ipsec transform-set GE1/0/10_IPv4_1
esp encryption-algorithm aes-cbc-128
esp authentication-algorithm sha1
remote-address F100
ike identity fqdn F1000
ike profile GE1/0/10_IPv4_1
keychain GE1/0/10_IPv4_1
exchange-mode aggressive
local-identity address 113.140.12.18
match remote identity fqdn F100
match local address GigabitEthernet1/0/10
proposal 65535
ike proposal 65535
description GE1/0/10_IPv4_1
ike keychain GE1/0/10_IPv4_1
pre-shared-key hostname F100 key cipher $c$3$V9bq5l1BOGU9jYDlsmLU95GNhgsA7ngLfw==
return
分部配置:
[H3C]dis current-configuration
dhcp enable
dhcp server ip-pool 10.240.70.0
gateway-list 10.240.70.1
network 10.240.70.0 mask 255.255.255.0
dns-list 10.108.6.6
interface GigabitEthernet1/0/4
ip address 10.240.70.1 255.255.255.0
dhcp server apply ip-pool 10.240.70.0
interface GigabitEthernet1/0/11
ip address 192.168.2.100 255.255.255.0
nat outbound 3001
ipsec apply policy GE1/0/11
ip route-static 0.0.0.0 0 192.168.2.1
acl advanced 3001
rule 5 deny ip source 10.240.70.0 0.0.0.255 destination 10.240.68.0 0.0.1.255
rule 7 deny ip source 10.240.70.0 0.0.0.255 destination 10.108.0.0 0.0.255.255
rule 9 deny ip source 10.240.70.0 0.0.0.255 destination 10.132.0.0 0.0.255.255
rule 11 deny ip source 10.240.70.0 0.0.0.255 destination 10.237.0.0 0.0.255.255
rule 13 deny ip source 10.240.70.0 0.0.0.255 destination 10.115.0.0 0.0.255.255
rule 15 permit ip
acl advanced 3005
rule 5 permit ip source 10.240.70.0 0.0.0.255 destination 10.240.68.0 0.0.1.255
rule 7 permit ip source 10.240.70.0 0.0.0.255 destination 10.108.0.0 0.0.255.255
rule 9 permit ip source 10.240.70.0 0.0.0.255 destination 10.132.0.0 0.0.255.255
rule 11 permit ip source 10.240.70.0 0.0.0.255 destination 10.237.0.0 0.0.255.255
rule 13 permit ip source 10.240.70.0 0.0.0.255 destination 10.115.0.0 0.0.255.255
ipsec transform-set GE1/0/11_IPv4_1
ipsec policy GE1/0/11 1 isakmp
security acl 3005
remote-address 113.140.12.18
ike-profile GE1/0/11_IPv4_1
ike profile GE1/0/11_IPv4_1
keychain GE1/0/11_IPv4_1
local-identity fqdn F100
match remote identity address 113.140.12.18 255.255.255.252
match local address GigabitEthernet1/0/11
proposal 65535
ike proposal 65535
description GE1/0/11_IPv4_1
ike keychain GE1/0/11_IPv4_1
pre-shared-key address 113.140.12.18 255.255.255.252 key cipher $c$3$AN0UDqqhGiMZLtBBuVW5FmJMex5MvH1DGw==
return
