设置列表
对齐方式
# igmp snooping enable
igmp snooping send-query enable
igmp snooping send-query source-address x.x.x.x
multicast layer-2 invalid-packet igmp snooping max-count 100
# netstream as-mode 32
netstream sampler random-packets 100 inbound
netstream sampler random-packets 100 outbound
# netstream timeout ipv6 active 1
netstream timeout ipv6 inactive 5
netstream export ipv6 version 9 origin-as bgp-nexthop
netstream export ipv6 index-switch 32
netstream export ipv6 template timeout-rate 1 #
华三产品为S12508X-AF,版本为2713
(0)
—— igmp snooping
—— igmp-snooping querier
—— igmp-snooping general-query source-ip x.x.x.x
—— ip netstream timeout active
—— ip netstream timeout inactive
——ip netstream export version
—— ip netstream export template refresh-rate
(0)
—— igmp snooping
我看手册,这个好像只可以vlan或者vsi下配置,不能全局配置是吗?
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
# igmp snooping enable —— igmp snooping igmp snooping send-query enable —— igmp-snooping querier igmp snooping send-query source-address x.x.x.x —— igmp-snooping general-query source-ip x.x.x.x 我看手册,这个好像只可以vlan或者vsi下配置,不能全局配置是吗?
貌似是的 后面这两条只能在VLAN或VSI里
