关于MSR2600的网络波动和安全问题
2020-10-22提问
  • 1收藏,1943浏览
哄哄 零段
粉丝:1人 关注:1人
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
1、最近网络波动很明显,偶尔会断网,MSR2600CPU占用率很高,查看日志发现interface Virtual-Access0,interface Virtual-Access1口会翻动,在一段时间内不断UP DOWM,以及日志出现shell failed to log in from 58.21.146.180,或者其他IP地址, The usage of security log file flash:/seclog/seclog.log reaches 80%.等日志大量出现。telnet检查时命令行有明显卡顿。同时查看CPU占用较高。但内存占用一般。
2、在检查的时候发现切换使用备线 Dialer2 无法上网,但是有流量经过。不知道是Dialer1冲突了还是其他原因。
3、display interface Dialer 0 Dialer0
Current state: UP Line protocol state: UP Description: Dialer0 Interface Bandwidth: 1000000 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet address: 14.145.172.109/32 (PPP-negotiated) Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 100000000 bps Output queue - Urgent queuing: Size/Length/Discards 0/1024/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 Last clearing of counters: Never Last 300 seconds input rate: 5711477 bytes/sec, 45691816 bits/sec, 6419 packets/sec Last 300 seconds output rate: 838847 bytes/sec, 6710776 bits/sec, 3556 packets/sec Input: 13649735410 packets, 11106225424178 bytes, 0 drops Output: 8171890213 packets, 2166551625406 bytes, 4 drops
display interface Dialer 1
Dialer1 Current state: UP Line protocol state: UP(spoofing) Description: Dialer1 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Enabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Output queue - Urgent queuing: Size/Length/Discards 0/1024/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops
display interface Dialer 2
Dialer2 Current state: UP Line protocol state: UP Description: Dialer2 Interface Bandwidth: 1000000 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet address: 113.119.9.17/32 (PPP-negotiated) Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 1000000 kbps Output queue - Urgent queuing: Size/Length/Discards 0/1024/0 Output queue - Protocol queuing: Size/Length/Discards 0/500/0 Output queue - FIFO queuing: Size/Length/Discards 0/75/0 Last clearing of counters: Never Last 300 seconds input rate: 7 bytes/sec, 56 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 3093416 packets, 2445066634 bytes, 0 drops Output: 1516751 packets, 253541090 bytes, 0 drops
ping测试和日志如下图
MSR2600 配置如下:
 <H3C>display current-configuration # version 7.1.064, Release 0707P16 # sysname H3C # clock timezone Beijing add 08:00:00 clock protocol ntp # telnet server enable # port-security enable # ip pool PPPoEServerIpPoolName 192.168.30.101 192.168.30.201 ip pool l2tp1 192.168.30.2 192.168.30.100 # dialer-group 1 rule ip permit dialer-group 2 rule ip permit dialer-group 3 rule ip permit # dhcp enable dhcp server always-broadcast # dns proxy enable dns server 202.96.128.166 dns server 202.96.128.86 # password-recovery enable # vlan 1 # traffic behavior behaviorfordeny filter deny # dhcp server ip-pool vlan1 gateway-list 192.168.11.1 network 192.168.11.0 mask 255.255.255.0 dns-list 192.168.11.1 202.96.128.86 static-bind ip-address 192.168.11.50 mask 255.255.255.0 hardware-address a4bb-6dc2-13cf # ddns policy GigabitEthernet0/0 url ***.***/dyndns/update?system=dyndns&hostname=<h>&myip=<a> username fantadust password cipher $c$3$BcMH+neN3Fix1gx5ZMTfZiPsSUvkB6i8hVzyBdQ= # ddns policy ***.*** url ***.***/dyndns/update?system=dyndns&hostname=<h>&myip=<a> username root password cipher $c$3$SzGpTwIX4/MByDdicVhA/cXEx2xhUI2Q7yUreig2JA== interval 0 0 15 # policy-based-route dust permit node 0 if-match acl 3000 apply output-interface Dialer0 # policy-based-route dust permit node 10 if-match acl 3000 # controller Cellular0/0 # interface Aux0 # interface Dialer0 bandwidth 1000000 mtu 1492 ppp chap password cipher $c$3$gRGRBYNencFGy7+v7rh61vG7bVwVmwDDNKNx ppp chap user 02007723548@163.gd ppp ipcp dns admit-any ppp ipcp dns request ppp pap local-user 02007723548@163.gd password cipher $c$3$dJJXXU+M+glzTZCSaLlIESeBGuqr4Q2bMb7U dialer bundle enable dialer-group 10 dialer timer idle 0 dialer timer autodial 5 ip address ppp-negotiate tcp mss 1024 qos car inbound carl 1 cir 120000 cbs 62500 ebs 0 green pass red discard yellow pass qos car inbound carl 4 cir 120000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car outbound carl 3 cir 15000 cbs 1250000 ebs 0 green pass red discard yellow pass qos car outbound carl 2 cir 15000 cbs 750000 ebs 0 green pass red discard yellow pass nat outbound ddns apply policy GigabitEthernet0/0 fqdn ***.*** # interface Dialer1 mtu 1492 ppp chap password cipher $c$3$dSSwdQHossgTarHWoJ8hv7HnhswNuJdwZNwm ppp chap user 02001873127@163.gd ppp ipcp dns admit-any ppp ipcp dns request ppp pap local-user 02001873127@163.gd password cipher $c$3$jVnwcJmLKt95YXc+SS1e9MKPRHwBR1XJER+L dialer bundle enable dialer-group 11 dialer timer idle 0 dialer timer autodial 5 ip address ppp-negotiate tcp mss 1024 qos car inbound carl 6 cir 130000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car inbound carl 5 cir 120000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car inbound carl 9 cir 120000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car outbound carl 7 cir 15000 cbs 937500 ebs 0 green pass red discard yellow pass qos car outbound carl 8 cir 15000 cbs 937500 ebs 0 green pass red discard yellow pass qos car outbound carl 10 cir 15000 cbs 937500 ebs 0 green pass red discard yellow pass nat outbound ddns apply policy ***.*** fqdn ***.*** # interface Dialer2 ppp chap password cipher $c$3$Q61fpp6YAr1aBShSjIUqODdAPVDtWsjrWgnJ ppp chap user 02001873127@163.gd ppp ipcp dns admit-any ppp ipcp dns request ppp pap local-user 02001873127@163.gd password cipher $c$3$qG4udYZV/rwN0vZXtoeR+odq/U3FGVf1ImUQ dialer bundle enable dialer-group 3 dialer timer idle 0 dialer timer autodial 5 ip address ppp-negotiate nat outbound ddns apply policy ***.*** fqdn ***.*** # interface Virtual-Template0 ppp authentication-mode chap ppp ipcp dns 192.168.30.1 202.96.128.166 remote address pool l2tp1 ip address 192.168.30.1 255.255.255.0 # interface NULL0 # interface Vlan-interface1 ip address 192.168.11.1 255.255.255.0 # interface GigabitEthernet0/0 port link-mode route description Multiple_Line qos car inbound carl 5 cir 120000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car inbound carl 6 cir 130000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car inbound carl 9 cir 120000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car outbound carl 7 cir 15000 cbs 7500000 ebs 0 green pass red discard yellow pass qos car outbound carl 8 cir 15000 cbs 750000 ebs 0 green pass red discard yellow pass qos car outbound carl 10 cir 15000 cbs 937500 ebs 0 green pass red discard yellow pass pppoe-client dial-bundle-number 0 # interface GigabitEthernet0/1 port link-mode route description Multiple_Line pppoe-client dial-bundle-number 2 # interface GigabitEthernet0/8 port link-mode route tcp mss 1024 pppoe-server bind virtual-template 0 # interface GigabitEthernet0/9 port link-mode route # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # interface GigabitEthernet0/5 port link-mode bridge # interface GigabitEthernet0/6 port link-mode bridge # interface GigabitEthernet0/7 port link-mode bridge # security-zone name Local # security-zone name Trust # security-zone name DMZ # security-zone name Untrust # security-zone name Management # scheduler logfile size 16 # line class aux user-role network-admin # line class tty user-role network-operator # line class usb user-role network-admin # line class vty user-role network-operator # line aux 0 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 Dialer0 preference 50 ip route-static 0.0.0.0 0 Dialer1 preference 80 ip route-static 0.0.0.0 0 Dialer2 ip route-static 192.168.14.0 23 192.168.11.2 ip route-static 192.168.15.0 24 192.168.11.2 ip route-static 192.168.17.0 24 192.168.11.3 ip route-static 192.168.18.0 23 192.168.11.2 ip route-static 192.168.20.0 24 192.168.11.2 ip route-static 192.168.21.0 24 192.168.11.2 ip route-static 192.168.22.0 24 192.168.11.3 ip route-static 192.168.40.0 24 192.168.11.2 ip route-static 192.168.100.0 24 192.168.11.3 # info-center security-logfile enable # ntp-service enable ntp-service unicast-server 114.118.7.161 ntp-service unicast-server 120.25.108.11 # acl basic 2999 rule 1 permit source 192.168.11.50 0 # acl advanced 3000 rule 0 permit ip source 192.168.15.0 0.0.0.255 # undo password-control aging enable undo password-control history enable password-control length 6 password-control login-attempt 3 exceed lock-time 10 password-control update-interval 0 password-control login idle-time 0 password-control complexity user-name check # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$M8weHhmmbGXBQT/k$eSbNYXIINYmRaMVOrqO0FQjE88K3Oo/EWVMhRbbMTbGIzjUHFDaUXb/jYqOhdxj17Ceq3GMLLbzpJVhiYF2weg== service-type ftp service-type telnet terminal http authorization-attribute user-role network-admin # local-user fantadust class manage password hash $h$6$hW8XrWjRnwLdxcTe$s6TRc7+9g+M9UhJ8VGzpTFR4A3zKjocFjXNhVx0WOOvrw55Z3t13BlLLBwWd7ZC4pE4TiT6HYe5gy/AeNUWA1Q== authorization-attribute user-role network-operator # local-user vpn2020 class manage authorization-attribute user-role network-operator # local-user vpner class manage authorization-attribute user-role network-operator # local-user fantadust class network password cipher $c$3$NwBSr0nYk7v1B7C4+mXkBY27MBDKo6c3v2k4I6g= service-type ppp authorization-attribute user-role network-operator # local-user vpn2020 class network password cipher $c$3$myVzp/EbMvqsh4zzweOuu/YgfFwZch4cTs9+YNN4 service-type ppp authorization-attribute user-role network-operator # l2tp-group 1 mode lns allow l2tp virtual-template 0 undo tunnel authentication tunnel password cipher $c$3$t3v5bwyQ/++a1dh9LRBZE3WeDaaS2oF9WEE= # l2tp enable # ip http enable web idle-timeout 300 # wlan global-configuration # wlan ap-group default-group vlan 1 # cloud-management server domain oasis.h3c.com # return
MSR2600为核心出口路由 出口为两条电信五百兆宽带。其中MSR2600ZHONG 配置了最基础的L2TPVPN 下联S5560交换机,交换机下联无线AC和一堆傻瓜交换机。
请问
1、是不是因为启用telnet被攻击了,在不断试登录?
2、网络波动是负载过大还是,其他原因?有限和无线总共带了接近400台设备
3、双出口的拨号设置是否有问题?谢谢各位大佬!
粉丝:124人 关注:6人
看到了CPU的利用率已经到了80%,CPU利用率过高会对业务有影响。
同时看到有主机在尝试登陆路由器,可以根据日志反馈的IP在ACL内进行拦截看下。为了保证设备的安全,建议使用复杂度高的密码。
另外也可以使用dis process cpu查看下具体是哪个进程对于CPU的利用率高。
以下是MSR2600的用户手册连接:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_2600/
粉丝:1人 关注:1人
两个出口都是自动获取的嘛?
都是PPOE拨号,向电信那边拿的地址,不是固定IP
哄哄 发表时间:2020-10-22
我看到设备的cpu已经超标了,超过百分之75就已经会丢包了,可以排查一下是否存在环路
平凡的烧年 发表时间:2020-10-22
请问除了环路还有可能是被攻击了吗?我发现日志里有很多登陆失败的不同的IP地址
哄哄 发表时间:2020-10-22
用了Wireshark抓了几次包,没有相同的包TTL依次递减的情况,应该可以排除环路
哄哄 发表时间:2020-10-22
