s6850-56HF 接入交换机的这段配置是什么意思
2020-10-26提问
  • 1收藏,1105浏览
粉丝:0人 关注:3人
bgp 4200001005
 bgp update-delay on-startup 120
 default-route update-first
 router-id 10.33.240.5
 bestroute compare-med
peer 10.33.129.9 as-number 4200000102
 peer 10.33.129.9 route-update-interval 0
 peer 10.33.129.9 timer keepalive 1 hold 3
 peer 10.33.129.9 enable
 peer 10.33.129.9 route-policy Policy-ASW-EBGP-Egress export
peer 10.33.128.157 advertise-community
 peer 10.33.128.157 advertise-ext-community
route-policy Policy-ASW-EBGP-Egress permit node 10
 if-match tag 3000
route-policy Policy-ASW-EBGP-Egress permit node 20
 if-match ip address prefix-list Prefix-Loopback0
route-policy Policy-ASW-EBGP-Egress deny node 100
route-policy Policy-Import-Route-StaticToBGP permit node 10
 if-match tag 3000
 ip prefix-list Prefix-Loopback0 index 10 permit 10.33.240.5 32
 ip prefix-list Prefix-Loopback0 index 20 permit 10.33.240.6 32
 ip community-list basic Community-HOST permit 10:10
 ip community-list basic Community-HOST permit 10:20
ip route-static 10.32.2.0 23 NULL0 tag 3000 description RSW-Connect-Subnet
 ip route-static 10.64.1.0 24 NULL0 tag 3000 description OPS-Subnet
 ip route-static 10.65.1.0 24 NULL0 tag 3000 description BigData-Subnet
 ip route-static 10.66.1.0 24 NULL0 tag 3000 description DB-Subnet
 ip route-static 10.69.1.0 24 NULL0 tag 3000 description Test-Subnet
 ip route-static 10.70.1.0 24 NULL0 tag 3000 description Pre-Subnet
 ip route-static vpn-instance Management 0.0.0.0 0 M-GigabitEthernet0/0/0 10.16.0.129
粉丝:124人 关注:6人
bgp 4200001005  //BGP进程号
 router-id 10.33.240.5  //指定router-id
peer 10.33.129.9 as-number 4200000102  //指向BGP邻居、为EBGP
 peer 10.33.129.9 timer keepalive 1 hold 3 //配置邻居的生存周期
 peer 10.33.129.9 enable  //启动邻居
 peer 10.33.129.9 route-policy Policy-ASW-EBGP-Egress export  //调用路由策略
peer 10.33.128.157 advertise-community  //指向团体属性
route-policy Policy-ASW-EBGP-Egress permit node 10  //配置路由策略,节点10
 if-match tag 3000  //匹配跳数
 if-match tag 3000
 ip prefix-list Prefix-Loopback0 index 10 permit 10.33.240.5 32  //配置IP地址前缀列表
