msg360-10 恢复密码后里面无配置 ,如何web登陆设备
2020-10-27提问
  • 1收藏,884浏览
version 7.1.064, ESS 5215P01 # sysname H3C # password-recovery enable # vlan 1 # interface NULL0 # interface GigabitEthernet1/0/11 port link-mode route # interface GigabitEthernet1/0/12 port link-mode route # interface GigabitEthernet1/0/1 port link-mode bridge # interface GigabitEthernet1/0/2 port link-mode bridge # interface GigabitEthernet1/0/3 port link-mode bridge # interface GigabitEthernet1/0/4 port link-mode bridge # interface GigabitEthernet1/0/5 port link-mode bridge # interface GigabitEthernet1/0/6 port link-mode bridge # interface GigabitEthernet1/0/7 port link-mode bridge # interface GigabitEthernet1/0/8 port link-mode bridge # interface GigabitEthernet1/0/9 port link-mode bridge # interface GigabitEthernet1/0/10 port link-mode bridge # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class vty user-role network-operator # line aux 0 user-role network-operator # line con 0 user-role network-admin # line vty 0 31 user-role network-operator # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # wlan global-configuration # wlan ap-group default-gr
粉丝:1人 关注:1人
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Wlan/Xiao_Bei/H3C_MSG/Configure/Operation_Manual/H3C_MSG_WCG-6W106/
粉丝:124人 关注:6人
可以参考下MSG的用户手册连接:
1.2  登录Web网管
1.2.1  缺省登录账号
设备出厂时已经默认启用了HTTP服务,并且设置有默认的Web登录信息,用户可以直接使用默认登录信息通过HTTP服务登录设备的Web页面。默认的Web登录信息包括:
·     密码:admin
·     设备(Vlan-interface1)的IP地址:192.168.0.100
1.2.2  使用PC登录Web网管
采用如下步骤登录Web网管:
(1)     连接设备和PC
用交叉以太网线将PC和设备上的LAN接口(缺省情况下,所有端口均属于VLAN 1)相连。
(2)     为PC配置IP地址,保证能与设备互通
以下两种方式任选其一:
¡     如下图所示,配置PC的IP地址为“自动获取IP地址”和“自动获取DNS服务器地址”,由设备为PC自动分配IP地址。
图1-1 配置PC自动获取IP地址
¡     手动修改PC的IP地址为192.168.0.0/22网段内的任意地址(除192.168.0.100),例如192.168.0.2。
(3)     启动浏览器,输入登录信息
在PC上启动浏览器,在地址栏中输入“http://192.168.0.100”后回车,即可进入设备的Web登录页面。输入密码“admin”,单击<GO>按钮即可登录。
1.2.3  使用移动客户端登录Web网管
采用如下步骤登录Web网管:
(1)     连接设备和客户端
在客户端上连接名称为“xiaobei”的无线服务,该无线服务没有密码,可直接登录。
(2)     启动浏览器,输入登录信息
在客户端上启动浏览器,在地址栏中输入“http://192.168.0.100”,即可进入设备的Web登录页面。输入密码“admin”,单击<GO>按钮即可登录。
1.3  修改Web网管密码
采用如下步骤修改Web网管密码:
(1)     在Web网管页面上,单击右上角的下拉按钮,单击<修改密码>按钮。
(2)     在弹出的“修改密码”对话框输入新密码,单击<确定>按钮,完成操作。
1.4  微信公众号
采用如下步骤关注“无线爱好者联盟”公众号:
(1)     在Web网管页面上,单击右上角的下拉按钮,单击<微信公众号>按钮。
(2)     使用手机扫描弹出的二维码即可完成关注公众号操作。
1.5  退出Web网管
采用如下步骤退出Web网管:
(1)     在Web网管页面上,单击右上角的下拉按钮,单击<注销>按钮。
(2)     在弹出的“确认提示”对话框中,单击<是>按钮,即可退出Web网管。
