S6506R的交换机console密码清除
2018-05-01提问
  • 1收藏,1870浏览
我公司有一台S6506R的交换机,都不知道密码,我想恢复出厂设置,初始化掉,官方对这个设备没有保了。 哪位大哥能帮帮我,应该怎么弄?
粉丝:111人 关注:0人
在65设备上有两种方式,
1.在BOOTROM菜单下,ctrl+p,删除启动文件中用户的console密码(同时会删除别的密码,具体请看下面步骤)
    BOOT  MENU
1. Download application file
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5 Modify bootrom password
0. Reboot
Enter your choice(0-5):
Are you sure you want to delete the privileged level password? Yes or No (Y/N)y
Flash:/
File Number      File Size(bytes)     File Name
1.                       151            private-data.txt
2.                       978            vrpcfg.cfg
3.                       716            hostkey
4.                       572            serverkey
5(*).               11439439            s7500-cmw310-r3135p18.app
6.                  12549008            s6500-vrp310-f3045l01.app
7.                         4            snmpboots
8.                     12560            test.cfg
9.                      9373            cad.cfg
10.                   464225            diaginfo.txt
11.                  462749            n.txt
Flash Free Space : 7662592 bytes
The current application file is:    flash:/s7500-cmw310-r3135p18.app
The backup boot file has not been selected.
Please input the configuration file number :2
The file you selected is flash:/vrpcfg.cfg, Yes or No(Y/N)y
The file flash:/vrpcfg.cfg is an sysname mode file.
Deleting super password
Deleting aux0 password
Deleting the privileged level password ...
The privileged level password has been deleted successfully!
2.在BOOTROM菜单下,ctrl+y,导出用户的配置之后删除启动文件重新启动,此方法需要tftp服务器
    BOOT  MENU
4. Delete file from flash  //导出文件之后删除启动文件
5. Modify bootrom password
0. Reboot
Please set application file upload protocol parameter:
1. Set TFTP protocol parameter:
0. Return to boot menu
Enter your choice(0-1): 1
Load File name           :S7500-CMW310-R3135P18.app
Switch IP address        :200.1.1.1
Server IP address        :200.1.1.2
Are you sure you want to  upload file from flash? Yes or No(Y/N)
