S5120-HI fan模块问题
2020-10-27提问
  • 1收藏,942浏览
Fan 1:
  Error: Failed to display the manufacture information of the specified fan.
Slot 2:
  ---- More ----                DEVICE_NAME          : S5120-52SC-HI
DEVICE_SERIAL_NUMBER :
MAC_ADDRESS          : MANUFACTURING_DATE   : 2014-05-31
VENDOR_NAME          : H3C
Power 1:
DEVICE_NAME          : LSPM2150A
MANUFACTURING_DATE   : 2014-07-23
VENDOR_NAME          : H3C
Power 2:
  This Power does not exist!
Fan 1:
%May 14 06:58:40:699 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 06:58:41:937 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
4FD-S5120-SW-STK-1 IFNET/3/LINK_UPDOWN: GigabitEthernet2/0/17 link status is UP.
%May 14 07:00:00:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:00:01:937 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:01:20:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:01:21:937 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:02:40:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:02:41:937 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:04:00:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:04:01:937 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:05:20:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:05:21:937 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:05:36:611 2000 CMF-Z4FD-S5120-SW-STK-1 ARP/4/RATELIMIT: The ARP packet rate(456pps) exceeded the rate limit(100pps) on interface GigabitEthernet1/0/49 in the last 60 seconds.
  ---- More ----                %May 14 07:06:36:611 2000 CMF-Z4FD-S5120-SW-STK-1 ARP/4/RATELIMIT: The ARP packet rate(335pps) exceeded the rate limit(100pps) on interface GigabitEthernet1/0/49 in the last 60 seconds.
%May 14 07:06:40:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:06:41:957 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:07:27:144 2000 CMF-Z4FD-S5120-SW-STK-1 IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/3 link status is DOWN.
%May 14 07:07:30:843 2000 CMF-Z4FD-S5120-SW-STK-1 IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/3 link status is UP.
%May 14 07:08:00:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:08:01:957 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:09:20:700 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:09:21:957 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
%May 14 07:10:40:703 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: -Slot=2; Fan 2 failed.
%May 14 07:10:41:957 2000 CMF-Z4FD-S5120-SW-STK-1 DEVM/2/FAN_FAILED: Fan 1 failed.
请问这个是风扇坏了吗
另外请教几个问题   S5120   HI   做堆叠,一共三台。       请教一下。1   此款交换机的 LSPM1FAN  模块是否支持热插拔。    2 目前三台LSPM1FAN
模块都不工作了,是否因为堆叠造成其中一块换了,其他两块也停止工作呢?  3  更换的话要一次三块都更换吗?
粉丝:7人 关注:1人
1、支持。
2、风扇模块都是独立的,不存在A故障影响B的情况;
3、是的,全部需要更换。
粉丝:95人 关注:1人
支持
    2 目前三台LSPM1FAN
不会,只有第二台的风扇坏了,更换第二台的风扇即可
dis fan可以查看风扇状态
粉丝:124人 关注:6人
可以使用dis fan查看下风扇的状态是否为fault
风扇模块支持热插拔,但是不要全部一次拔出。需逐个拔出,安装正常后再更换其他的。
可以收集产品型号、序列号、诊断信息文件反馈400确认是否是风扇坏了。
