msg360和华为的核心连接华三的ap接在msg360上。这个要怎么配置。华为的核心上需要怎么配置
2020-10-28提问
  • 1收藏,1192浏览
如题
粉丝:42人 关注:0人
MSG既可以做出口网关下挂交换机,也可以直接旁挂在交换机上,配置看现场需求。
可以下载轻轻松松配案例集,所需案例都有:https://zhiliao.h3c.com/topic/huati/1249
4 个回答
粉丝:95人 关注:1人
MSG旁挂在华为上,然后华为和MSG之间放通vlan,网络可达AP就可以注册上来。
粉丝:40人 关注:3人
核心上需要放通各自的vlan即可
(1)      配置L3 switch的接口
# 创建VLAN 100和VLAN 400,并配置IP地址,用于转发AC和AP间的CAPWAP隧道内的流量。
<L3 switch> system-view
[L3 switch] vlan 100
[L3 switch-vlan100] quit
[L3 switch] interface vlan-interface 100
[L3 switch-Vlan-interface100] ip address 192.168.10.83 255.255.255.0
[L3 switch-Vlan-interface100] quit
[L3 switch] vlan 400
[L3 switch-vlan400] quit
[L3 switch] interface vlan-interface 400
[L3 switch-Vlan-interface400] ip address 192.168.40.1 255.255.255.0
[L3 switch-Vlan-interface400] quit
# 创建VLAN 200,并为该接口配置IP地址。Client使用该VLAN接入无线网络。
[L3 switch] vlan 200
[L3 switch-vlan200] quit
[L3 switch] interface vlan-interface 200
[L3 switch-Vlan-interface200] ip address 192.168.20.1 255.255.255.0
[L3 switch-Vlan-interface200] quit
# 创建VLAN 300,并为该接口配置IP地址。Host使用该VLAN与AC建立连接。
[L3 switch] vlan 300
[L3 switch-vlan300] quit
[L3 switch] interface vlan-interface 300
[L3 switch-Vlan-interface300] ip address 192.168.30.1 255.255.255.0
[L3 switch-Vlan-interface300] quit
# 配置L3 switch和AC相连的接口GigabitEthernet1/0/1为Trunk类型,允许VLAN100和VLAN 200通过。
[L3 switch] interface gigabitEthernet 1/0/1
[L3 switch-GigabitEthernet1/0/1] port link-type trunk
[L3 switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[L3 switch-GigabitEthernet1/0/1] quit
# 配置L3 switch和L2 switch1和相连的接口GigabitEthernet1/0/2为Trunk类型,禁止VLAN 1报文通过,允许VLAN 400通过。
[L3 switch] interface gigabitEthernet 1/0/2
[L3 switch-GigabitEthernet1/0/2] port link-type trunk
[L3 switch-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[L3 switch-GigabitEthernet1/0/2] port trunk permit vlan 400
 [L3 switch-GigabitEthernet1/0/2] quit
# 配置L3 switch和L2 switch2相连的接口GigabitEthernet1/0/3为Trunk类型,禁止VLAN 1报文通过,允许VLAN 300通过。
[L3 switch] interfac gigabitEthernet 1/0/3
[L3 switch-GigabitEthernet1/0/3] port link-type trunk
[L3 switch-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[L3 switch-GigabitEthernet1/0/3] port trunk permit vlan 300
[L3 switch-GigabitEthernet1/0/3] quit
z6Kl9 九段
粉丝:66人 关注:2人
二层旁挂,放通相关vlan即可
zhiliao_1QvPg0 知了小白
还是不要多说什么了,
了解新华三(h3c)的产品先看下这个吧。
https://zhiliao.h3c.com/questions/dispcont/254273
