H3C WX3024E
2020-10-28提问
  • 1收藏,1052浏览
根据手册操作,默认ping不同管理地址,还需要进行其他什么设置才能通吗?
默认配置:
# version 5.20, Release 3509P67 # sysname H3C # domain default enable system # telnet server enable # port-security enable # oap management-ip 192.168.0.101 slot 0 # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$ioHRXKYxE8GTHnYaSEBeEN9K7r3LDnfs authorization-attribute level 3 service-type telnet # wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 # wlan ap-group default_group # interface Bridge-Aggregation1 # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.100 255.255.255.0 # interface GigabitEthernet1/0/1 port link-aggregation group 1 # interface GigabitEthernet1/0/2 port link-aggregation group 1 # wlan ips malformed-detect-policy default signature deauth_flood signature-id 1 signature broadcast_deauth_flood signature-id 2 signature disassoc_flood signature-id 3 signature broadcast_disassoc_flood signature-id 4 signature eapol_logoff_flood signature-id 5 signature eap_success_flood signature-id 6 signature eap_failure_flood signature-id 7 signature pspoll_flood signature-id 8 signature cts_flood signature-id 9 signature rts_flood signature-id 10 signature addba_req_flood signature-id 11 signature-policy default countermeasure-policy default attack-detect-policy default virtual-security-domain default attack-detect-policy default malformed-detect-policy default signature-policy default countermeasure-policy default # user-interface con 0 user-interface vty 0 4 authentication-mode scheme user privilege level 3 # return
确保终端单网卡使用,如还有问题,可以参考链接https://www.h3c.com/cn/Service/Document_Software/Document_Center/Wlan/WX/H3C_WX3000E/
...看的就是这个手册,ping不通。。。
zhiliao_Wqw6f 发表时间:2020-10-28
看一下相应VLAN设置是否正确
zhiliao_jn 发表时间:2020-10-28
粉丝:18人 关注:1人
看下有没有没有加入聚合组的接口
默认是加入聚合组接口,网线插在GE/1/0/1的网口
zhiliao_Wqw6f 知了小白
