去做等保弥补相关,应该是做了密码策略,密码没显示出来,刚开始不知道,在admin用户里面加了原本的密码,提示
The system failed to assign password. It has been used previously.应该是没加成功,这个是以前的密码,后来就突然说之前能用的ssh用不了了,报错
remote side unexpectedly closed network,这个是怎么回事啊,为什么能用的突然用不了了,我只是改了密码,而且失败了。下面发一下配置。
(0)
[BEGIN] 2020/11/3 11:08:02
[º̐·506E]dis cu
version 5.20, Release 6710P02
sysname º̐·506E
clock timezone Beijing add 08:00:00
password-control enable
password-control length 8
password-control login-attempt 3 exceed lock-time 5
password-control complexity user-name check
password-control complexity same-character check
irf mac-address persistent always
undo irf auto-update enable
undo irf link-delay
irf member 1 priority 32
irf member 2 priority 30
domain default enable system
ip ttl-expires enable
ip unreachables enable
lldp enable
mirroring-group 1 local
switch-mode standard chassis 1
switch-mode normal chassis 1 slot 2
switch-mode normal chassis 1 slot 3
switch-mode normal chassis 1 slot 5
switch-mode normal chassis 1 slot 8
switch-mode standard chassis 2
switch-mode normal chassis 2 slot 2
switch-mode normal chassis 2 slot 3
switch-mode normal chassis 2 slot 5
switch-mode normal chassis 2 slot 8
irf-pbr enable
switch-mode route-normal
password-recovery enable
acl number 2000
rule 0 permit source 192.168.0.0 0.0.255.255
acl number 3000
rule 100 deny tcp source 192.168.188.0 0.0.0.255 source-port eq 0 destination 172.16.1.0 0.0.0.255 destination-port eq 3333
rule 105 permit ip
acl number 3001
rule 5 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.8.0 0.0.0.255
rule 6 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.9.0 0.0.0.255
rule 7 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
acl number 3002
rule 8 deny ip source 192.168.40.0 0.0.0.255 destination 192.168.8.0 0.0.0.255
rule 9 deny ip source 192.168.40.0 0.0.0.255 destination 192.168.9.0 0.0.0.255
rule 10 deny ip source 192.168.40.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
acl number 3003
rule 11 deny tcp source-port eq 445 destination-port eq 445
rule 12 deny tcp source-port eq 138 destination-port eq 138
rule 13 deny tcp source-port eq 139 destination-port eq 139
vlan 1
vlan 2 to 17
vlan 21 to 23
vlan 24
description ϞПAP
vlan 25
description ׇ»ۿό
vlan 26 to 28
vlan 172
vlan 188
vlan 200
vlan 1000
description MAD
vlan 3000
description ʏj¿
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool vlan172
network 172.16.252.0 mask 255.255.252.0
gateway-list 172.16.255.254
dns-list 114.114.114.114 202.96.128.166
expired day 0 hour 8
dhcp server ip-pool vlan24
network 192.168.24.0 mask 255.255.255.0
gateway-list 192.168.24.254
dns-list 114.114.114.114 202.96.128.86
user-group system
group-attribute allow-guest
local-user aaa
local-user admin
authorization-attribute level 3
service-type ssh terminal
service-type web
local-user audit
authorization-attribute level 1
service-type ssh
local-user gzdlzx
service-type ssh
local-user operator
service-type ssh
local-user system
service-type ssh
stp mode rstp
stp instance 0 root primary
stp enable
interface Bridge-Aggregation1
description 6-8F°칫˒
port access vlan 11
link-aggregation mode dynamic
interface Bridge-Aggregation2
description ͼ˩¹
port access vlan 14
interface Bridge-Aggregation4
description 9Fθ¹ݖѐ
interface Bridge-Aggregation5
description С¹¤³§
port access vlan 22
interface Bridge-Aggregation6
description ´䅿ۃƎ
port link-type trunk
port trunk permit vlan all
interface Bridge-Aggregation7
description Ůʺ̞ʡ
port access vlan 200
interface Bridge-Aggregation8
interface Bridge-Aggregation9
description ש½¥һ¥¹㲥˒
port access vlan 15
interface Bridge-Aggregation10
description xϡ¥ɽ·ԍӡ˒
port access vlan 23
interface Bridge-Aggregation11
description »džӂ¥6F
port access vlan 23
interface Bridge-Aggregation12
description ¹
port access vlan 22
interface Bridge-Aggregation13
description ·¹̓
interface Bridge-Aggregation14
description ͥԽ¹
interface Bridge-Aggregation15
description ³¤·肥±±4F
port access vlan 3
interface Bridge-Aggregation25
port access vlan 25
interface Bridge-Aggregation28
description т̞ʡ¥
port access vlan 28
interface Bridge-Aggregation100
port access vlan 3000
interface Route-Aggregation1
interface NULL0
interface Vlan-interface1
interface Vlan-interface2
ip address 192.168.2.254 255.255.255.0
interface Vlan-interface3
ip address 192.168.3.254 255.255.255.0
interface Vlan-interface4
ip address 192.168.4.254 255.255.255.0
interface Vlan-interface5
ip address 192.168.5.254 255.255.255.0
interface Vlan-interface6
ip address 192.168.6.254 255.255.255.0
interface Vlan-interface7
ip address 192.168.7.254 255.255.255.0
interface Vlan-interface8
ip address 192.168.8.254 255.255.255.0
interface Vlan-interface9
ip address 192.168.9.254 255.255.255.0
interface Vlan-interface10
ip address 192.168.10.254 255.255.255.0
interface Vlan-interface11
ip address 192.168.11.254 255.255.255.0
interface Vlan-interface12
ip address 192.168.12.254 255.255.255.0
interface Vlan-interface13
ip address 192.168.13.254 255.255.255.0
interface Vlan-interface14
ip address 192.168.14.254 255.255.255.0
interface Vlan-interface15
ip address 192.168.15.254 255.255.255.0
interface Vlan-interface16
ip address 192.168.16.254 255.255.255.0
interface Vlan-interface17
ip address 192.168.17.254 255.255.255.0
interface Vlan-interface21
ip address 192.168.21.254 255.255.255.0
interface Vlan-interface22
ip address 192.168.43.254 255.255.252.0
interface Vlan-interface23
ip address 192.168.35.254 255.255.252.0
interface Vlan-interface24
description ϞПAP
ip address 192.168.24.254 255.255.255.0
interface Vlan-interface25
ip address 192.168.25.254 255.255.255.0
interface Vlan-interface26
ip address 192.168.26.1 255.255.254.0
interface Vlan-interface28
description ݐË߉₥
ip address 192.168.28.254 255.255.254.0
interface Vlan-interface172
ip address 172.16.255.254 255.255.252.0
interface Vlan-interface188
ip address 192.168.188.1 255.255.255.0
interface Vlan-interface200
description Ůʺ̞ʡ
ip address 192.168.20.254 255.255.255.0
interface Vlan-interface1000
description MAD
mad bfd enable
mad ip address 1.1.1.1 255.255.255.252 member 1
mad ip address 1.1.1.2 255.255.255.252 member 2
interface Vlan-interface3000
ip address 172.16.1.3 255.255.255.0
interface GigabitEthernet1/2/0/1
port link-mode bridge
port access vlan 15
port link-aggregation group 9
interface GigabitEthernet1/2/0/2
port access vlan 23
port link-aggregation group 10
interface GigabitEthernet1/2/0/3
port access vlan 3
port link-aggregation group 15
interface GigabitEthernet1/2/0/4
description »džӂ¥6F
port access vlan 23
port link-aggregation group 11
interface GigabitEthernet1/2/0/5
port access vlan 10
interface GigabitEthernet1/2/0/6
port access vlan 12
interface GigabitEthernet1/2/0/7
port access vlan 13
interface GigabitEthernet1/2/0/8
port access vlan 16
interface GigabitEthernet1/2/0/9
port access vlan 14
interface GigabitEthernet1/2/0/10
port access vlan 7
interface GigabitEthernet1/2/0/11
description ³¤·肥ŏɽ¥»
port link-aggregation group 8
interface GigabitEthernet1/2/0/12
port access vlan 22
port link-aggregation group 12
interface GigabitEthernet1/2/0/13
port access vlan 22
port link-aggregation group 5
interface GigabitEthernet1/2/0/14
port link-aggregation group 14
interface GigabitEthernet1/2/0/15
port link-aggregation group 13
interface GigabitEthernet1/2/0/16
port link-aggregation group 7
interface GigabitEthernet1/2/0/17
port access vlan 11
interface GigabitEthernet1/2/0/18
port access vlan 14
port link-aggregation group 2
interface GigabitEthernet1/2/0/19
port access vlan 28
port link-aggregation group 28
interface GigabitEthernet1/2/0/20
port access vlan 25
port link-aggregation group 25
interface GigabitEthernet1/2/0/21
interface GigabitEthernet1/2/0/22
interface GigabitEthernet1/2/0/23
port link-aggregation group 4
interface GigabitEthernet1/2/0/24
port link-aggregation group 6
interface GigabitEthernet1/3/0/1
port access vlan 1000
stp disable
interface GigabitEthernet1/3/0/2
port access vlan 7
interface GigabitEthernet1/3/0/3
interface GigabitEthernet1/3/0/4
interface GigabitEthernet1/3/0/5
interface GigabitEthernet1/3/0/6
interface GigabitEthernet1/3/0/7
interface GigabitEthernet1/3/0/8
interface GigabitEthernet1/3/0/9
interface GigabitEthernet1/3/0/10
interface GigabitEthernet1/3/0/11
interface GigabitEthernet1/3/0/12
interface GigabitEthernet1/3/0/13
interface GigabitEthernet1/3/0/14
interface GigabitEthernet1/3/0/15
interface GigabitEthernet1/3/0/16
port access vlan 11
interface GigabitEthernet1/3/0/17
interface GigabitEthernet1/3/0/18
interface GigabitEthernet1/3/0/19
interface GigabitEthernet1/3/0/20
interface GigabitEthernet1/3/0/21
interface GigabitEthernet1/3/0/22
interface GigabitEthernet1/3/0/23
interface GigabitEthernet1/3/0/24
port link-aggregation group 100
interface GigabitEthernet1/5/0/1
port access vlan 26
interface GigabitEthernet1/5/0/2
port access vlan 26
interface GigabitEthernet1/5/0/3
port access vlan 26
interface GigabitEthernet1/5/0/4
port access vlan 26
interface GigabitEthernet1/5/0/5
port access vlan 26
interface GigabitEthernet1/5/0/6
port access vlan 26
interface GigabitEthernet1/5/0/7
port access vlan 26
interface GigabitEthernet1/5/0/8
port access vlan 26
interface GigabitEthernet1/5/0/9
port access vlan 26
interface GigabitEthernet1/5/0/10
port access vlan 26
interface GigabitEthernet1/5/0/11
interface GigabitEthernet1/5/0/12
port access vlan 26
interface GigabitEthernet1/5/0/13
port access vlan 26
interface GigabitEthernet1/5/0/14
port access vlan 26
interface GigabitEthernet1/5/0/15
port access vlan 26
interface GigabitEthernet1/5/0/16
port access vlan 26
interface GigabitEthernet1/5/0/17
port access vlan 26
interface GigabitEthernet1/5/0/18
port access vlan 26
interface GigabitEthernet1/5/0/19
port access vlan 26
interface GigabitEthernet1/5/0/20
port access vlan 26
interface GigabitEthernet1/5/0/21
port access vlan 26
interface GigabitEthernet1/5/0/22
port access vlan 26
interface GigabitEthernet1/5/0/23
port access vlan 26
interface GigabitEthernet1/5/0/24
port access vlan 26
interface GigabitEthernet2/2/0/1
port access vlan 15
interface GigabitEthernet2/2/0/2
port access vlan 23
interface GigabitEthernet2/2/0/3
port access vlan 3
interface GigabitEthernet2/2/0/4
port access vlan 23
interface GigabitEthernet2/2/0/5
interface GigabitEthernet2/2/0/6
interface GigabitEthernet2/2/0/7
interface GigabitEthernet2/2/0/8
interface GigabitEthernet2/2/0/9
interface GigabitEthernet2/2/0/10
interface GigabitEthernet2/2/0/11
interface GigabitEthernet2/2/0/12
port access vlan 22
interface GigabitEthernet2/2/0/13
port access vlan 22
interface GigabitEthernet2/2/0/14
interface GigabitEthernet2/2/0/15
interface GigabitEthernet2/2/0/16
interface GigabitEthernet2/2/0/17
port access vlan 11
interface GigabitEthernet2/2/0/18
port access vlan 14
interface GigabitEthernet2/2/0/19
port access vlan 28
interface GigabitEthernet2/2/0/20
port access vlan 25
interface GigabitEthernet2/2/0/21
interface GigabitEthernet2/2/0/22
interface GigabitEthernet2/2/0/23
interface GigabitEthernet2/2/0/24
interface GigabitEthernet2/3/0/1
stp disable
interface GigabitEthernet2/3/0/2
description 4Fµ蘓Մ@˒
port access vlan 7
interface GigabitEthernet2/3/0/3
description 7F705¼Nj㼺˒
port access vlan 8
interface GigabitEthernet2/3/0/4
description 7F706¼Nj㼺˒
port access vlan 9
interface GigabitEthernet2/3/0/5
description 7F707¼Nj㼺˒
port access vlan 10
interface GigabitEthernet2/3/0/6
description 6FԯӴ˒
port access vlan 13
interface GigabitEthernet2/3/0/7
description 7FԯӴ˒2
port access vlan 12
interface GigabitEthernet2/3/0/8
description 4Fͼ˩¹
port access vlan 14
interface GigabitEthernet2/3/0/9
description 6F¼Nj㼺˒
port access vlan 16
interface GigabitEthernet2/3/0/10
interface GigabitEthernet2/3/0/11
port access vlan 17
interface GigabitEthernet2/3/0/12
interface GigabitEthernet2/3/0/13
interface GigabitEthernet2/3/0/14
interface GigabitEthernet2/3/0/15
interface GigabitEthernet2/3/0/16
interface GigabitEthernet2/3/0/17
interface GigabitEthernet2/3/0/18
interface GigabitEthernet2/3/0/19
interface GigabitEthernet2/3/0/20
interface GigabitEthernet2/3/0/21
interface GigabitEthernet2/3/0/22
interface GigabitEthernet2/3/0/23
interface GigabitEthernet2/3/0/24
interface GigabitEthernet2/5/0/1
port access vlan 26
interface GigabitEthernet2/5/0/2
port access vlan 26
interface GigabitEthernet2/5/0/3
port access vlan 26
interface GigabitEthernet2/5/0/4
port access vlan 26
interface GigabitEthernet2/5/0/5
port access vlan 26
interface GigabitEthernet2/5/0/6
port access vlan 26
interface GigabitEthernet2/5/0/7
port access vlan 26
interface GigabitEthernet2/5/0/8
port access vlan 26
interface GigabitEthernet2/5/0/9
port access vlan 26
interface GigabitEthernet2/5/0/10
port access vlan 26
interface GigabitEthernet2/5/0/11
port access vlan 26
interface GigabitEthernet2/5/0/12
port access vlan 26
interface GigabitEthernet2/5/0/13
port access vlan 26
interface GigabitEthernet2/5/0/14
port access vlan 26
interface GigabitEthernet2/5/0/15
port access vlan 26
interface GigabitEthernet2/5/0/16
port access vlan 26
interface GigabitEthernet2/5/0/17
port access vlan 26
interface GigabitEthernet2/5/0/18
port access vlan 26
interface GigabitEthernet2/5/0/19
port access vlan 26
interface GigabitEthernet2/5/0/20
port access vlan 26
interface GigabitEthernet2/5/0/21
port access vlan 26
interface GigabitEthernet2/5/0/22
port access vlan 26
interface GigabitEthernet2/5/0/23
port access vlan 26
interface GigabitEthernet2/5/0/24
port access vlan 26
interface M-Ethernet1/0/0/0
interface Ten-GigabitEthernet1/8/0/1
interface Ten-GigabitEthernet1/8/0/2
interface Ten-GigabitEthernet2/8/0/1
interface Ten-GigabitEthernet2/8/0/2
ip route-static 0.0.0.0 0.0.0.0 172.16.1.1
ip route-static 172.18.0.0 255.255.240.0 192.168.25.2
ip route-static 172.21.1.0 255.255.255.0 192.168.25.2
info-center source default channel 2 log level warnings
info-center loghost source Vlan-interface3000
info-center loghost 172.16.1.8/24
undo info-center enable
undo info-center logfile enable
info-center security-logfile enable
dhcp server forbidden-ip 192.168.26.200 192.168.26.253
dhcp enable
ssh server enable
ssh server rekey-interval 24
sftp server enable
ssh server acl 2000
ip https acl 2000
ip https enable
load xml-configuration
load tr069-configuration
user-interface aux 1/0
idle-timeout 1 0
user-interface aux 2/0
user-interface vty 0 4
acl 3003 inbound
idle-timeout 1 0
user-interface vty 5 15
idle-timeout 1 0
irf-port 1/2
port group interface Ten-GigabitEthernet1/8/0/1 mode normal
port group interface Ten-GigabitEthernet1/8/0/2 mode normal
irf-port 2/1
port group interface Ten-GigabitEthernet2/8/0/1 mode normal
port group interface Ten-GigabitEthernet2/8/0/2 mode normal
return
[END] 2020/11/3 11:08:35
(0)
密码修改失败,提示这个密码之前被使用过,相当于你清空了密码,重新配置下
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我试了,把password-control给undo 掉,之后再修改密码,之后再开启password-control,结果还是不行,ssh提示connection closed by remote host
