MSR3640 MPLS问题
2020-11-03提问
  • 1收藏,1184浏览
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
调试电力调度数据网路由器MSR3640 MPLS VPN,老路由器数据往新路由器数据迁移,本端到对端主调的业务地址不通,到备调的业务是通的,但是新路由器可以查到到对端主调的业务地址网段,但是业务不通,请问是什么原因造成的,怎么解决?
老路由器配置:
 port link-mode route
interface GigabitEthernet0/0.100
 description To-YuanQuB.S-RT-YeWu
 vlan-type dot1q vid 100
 ip binding vpn-instance vpn-rt
 ip address 65.40.3.193 255.255.255.192
interface GigabitEthernet0/0.300
 description To-YuanQuB.S-RT-HuLian
 vlan-type dot1q vid 300
 ip address 65.3.145.186 255.255.255.252
interface GigabitEthernet0/1
interface GigabitEthernet0/1.200
 description To-YuanQuB.S-NRT-YeWu
 vlan-type dot1q vid 200
 ip binding vpn-instance vpn-nrt
 ip address 65.72.3.193 255.255.255.192
interface GigabitEthernet0/1.300
 description To-YuanQuB.S-NRT-HuLian
 ip address 65.3.145.190 255.255.255.252
bgp 26518
 undo synchronization
 group RR internal
 peer RR connect-interface LoopBack0
 peer 65.2.61.3 group RR
 peer 65.2.61.4 group RR
 ipv4-family vpn-instance vpn-rt
  import-route direct
  import-route static
 ipv4-family vpn-instance vpn-nrt
  import-route direct
  import-route static
 ipv4-family vpnv4
  peer RR enable
  peer 65.2.61.3 enable
  peer 65.2.61.4 enable
ospf 1
 area 0.0.0.5
  network 65.2.62.12 0.0.0.0
  network 65.3.145.180 0.0.0.3
  network 65.3.145.176 0.0.0.3
  network 65.3.145.184 0.0.0.3
  network 65.3.145.188 0.0.0.3
 snmp-agent
 snmp-agent local-engineid 800063A203C4CAD9317BB9
 snmp-agent community read wlmq
 snmp-agent community read xjdlr
 snmp-agent community write xjdlw
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 65.254.18.1 params securityname xjdlr v2c
 undo snmp-agent trap enable voice dial
 ssh server enable
 ssh user tlfzdh service-type stelnet authentication-type password
 load xml-configuration
 load tr069-configuration
user-interface con 0
 authentication-mode password
 set authentication password cipher #'/=.Q]0BS7Q=^Q`MAF4<1!!
user-interface tty 13
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
return
新交换机:
<YuanQuB.R>dis current-configuration
 version 7.1.064, Release 0707P21
 sysname YuanQuB.R
ip vpn-instance vpn-nrt
 route-distinguisher 26518:200
 vpn-target 26518:200 import-extcommunity
 vpn-target 26518:200 26518:300 export-extcommunity
ip vpn-instance vpn-rt
 route-distinguisher 26518:100
 vpn-target 26518:100 import-extcommunity
 vpn-target 26518:100 26518:300 export-extcommunity
 telnet server enable
 port-security enable
 router id 65.2.62.12
ospf 1
 area 0.0.0.5
 mpls lsr-id 65.2.62.12
 dns proxy enable
 password-recovery enable
vlan 1
mpls ldp
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface Serial6/0
 ppp mp MP-group0
interface Serial6/1
 ppp mp MP-group1
interface Serial6/2
interface Serial6/3
interface MP-group0
 description TO-TLF-DD-HJ.R1
 ip address 65.3.145.177 255.255.255.252
 ospf cost 200
 ospf bfd enable
 mpls enable
 mpls ldp enable
 bfd min-transmit-interval 200
 bfd min-receive-interval 200
 bfd detect-multiplier 3
interface MP-group1
 description TO-TLF-DD-HJ.R2
 ip address 65.3.145.181 255.255.255.252
 ospf cost 250
 ospf bfd enable
 mpls enable
 mpls ldp enable
interface NULL0
interface LoopBack0
 ip address 65.2.62.12 255.255.255.255
interface Ethernet2/0
 port link-mode bridge
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
 combo enable copper
 description TO-YuanQuB.S-RT-YEWU
 description T0-YuanQuB.S-RT-HuLian
 combo enable copper
 description TO-YuanQuB.S-NRT-YuWu
 description TO-YuanQuB.S-NRT-HuLian
interface GigabitEthernet0/2
bgp 26518
 group RR internal
 address-family vpnv4
  peer RR enable
  address-family ipv4 unicast
   import-route direct
   import-route static
   import-route direct
   import-route static
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
line vty 0 4
 protocol inbound telnet
line vty 5 63
 snmp-agent
 undo snmp-agent trap enable bfd
 undo snmp-agent trap enable bgp
 undo snmp-agent trap enable configuration
 undo snmp-agent trap enable l3vpn
 undo snmp-agent trap enable ldp
 undo snmp-agent trap enable mac-address
 undo snmp-agent trap enable ospf
 undo snmp-agent trap enable standard
 undo snmp-agent trap enable system
 ssh server enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
 password-control complexity user-name check
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$6EYJtCXUtWDADhis$wHi11n4Kk/+jGulDVUNDI2mO8U4kdGuSabPjy1ik3cCbv5Saxl8oGlDsWkPyd4VSKbIqvOt0L0r2rtvIEcyDsg==
 service-type telnet terminal
local-user tlfzdh class manage
 password hash $h$6$BhIGfQt1NnoyyeGG$UC7MbswjMDO3hvIv23U1ChYyqJqWs5phCRZGgV+JpKV+pn+WAAcMX7aSfehKkXlx+roNNvZZn6EqaOp5fw3bCw==
 service-type ssh
 ip http enable
wlan global-configuration
wlan ap-group default-group
 vlan 1
return
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
4 个回答
配置有对比过吗?
已经对比了
zhiliao_uU1eEK 发表时间:2020-11-03
ospf,bgp状态正常吗,vrf路由表能学到路由吗
zhiliao_yoElC 发表时间:2020-11-03
dis ip route-table vpn-instance vpn-rt 可以看到主调路由
zhiliao_uU1eEK 发表时间:2020-11-04
粉丝:4人 关注:0人
是不是多路径导致的
我们有两个通道,一主一备
粉丝:10人 关注:7人
查看标签分发是否正常
粉丝:124人 关注:6人
关于更换了新的路由器业务不通的问题,以下是排查要点,请参考:
1、对比老设备的配置看下是否有不相同的地方。
2、检查下本端到备调的BGP邻居关系是否已正常建立。
3、检查下VPN实例的RT值、RD值是否有相似的地方。
4、检查下业务地址段在BGP内的VPN实例发布看下。
