qos cbq可以调用acl网段的配置案例,设置优先级来转发业务
2020-11-05提问
  • 1收藏,1125浏览
粉丝:150人 关注:1人
请参考
https://zhiliao.h3c.com/Theme/details/82887
AVAYA 九段
粉丝:32人 关注:0人
QOS优先级重标记实验报告
实验拓扑:
            1/0/3 通用交换机                  192.168.1.2
  host
 192.168.1.1
实验要求:
实验拓扑如图所示,1.2为数据库服务器,1.1为邮件服务器,要求从host访问的数据有限访问数据库服务器,次之访问邮件服务器。
实验配置
[sw]dis cu
 version 5.20, Release 5101P02
 sysname sw
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
acl number 3000
 rule 0 permit ip destination 192.168.1.2 0  抓取访问1.2的流量
acl number 3001
 rule 0 permit ip destination 192.168.1.1 0   抓取访问1.1的流量
vlan 1
radius scheme system
 server-type extended
 primary authentication 127.0.0.1 1645
 primary accounting 127.0.0.1 1646
 user-name-format without-domain
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier ma operator and
 if-match acl 3001   定义类,符合1.1的被定义
traffic classifier de operator and
 if-match acl 3000   定义类,符合1.2的被定义
traffic behavior ma
 remark local-precedence 3   定义行为,设定优先级为3
traffic behavior de
 remark local-precedence 4  定义行为,设定优先级为4
qos policy snow
 classifier de behavior de   定义策略
 classifier ma behavior ma   定义策略
user-group system
 group-attribute allow-guest
interface NULL0
interface Vlan-interface1
 ip address dhcp-alloc client-identifier mac Vlan-interface1
 port link-mode bridge
 qos priority 6
 qos apply policy snow inbound   将策略应用在端口的入方向
 qos sp
实验效果:
%Apr 27 20:08:32:248 2000 sw QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Classifier-behavior de in policy snow applied on interface GigabitEth.
Reason: Not supported by hardware.
Done.
%Apr 27 20:08:32:478 2000 sw QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Classifier-behavior ma in policy snow applied on interface GigabitEth.
