FTP映射失败
2020-11-09提问
  • 1收藏,1442浏览
telnet端口失败,外网连接FTP是不是和nat alg没配置有关系?
  1. version 7.1.064, Release 060
  2. #
  3. sysname router2
  4. #
  5. telnet server enable
  6. #
  7. port-mapping application ftp port 1025
  8. #
  9. ip load-sharing mode per-flow global
  10. #
  11. dhcp enable
  12. dhcp server always-broadcast
  13. #
  14. dns proxy enable
  15. dns server 61.139.2.69
  16. #
  17. password-recovery enable
  18. #
  19. vlan 1
  20. #
  21. dhcp server ip-pool 1
  22. gateway-list 172.16.1.1
  23. network 172.16.1.0 mask 255.255.255.0
  24. dns-list 61.139.2.69
  25. #
  26. controller Cellular0/0
  27. #
  28. interface NULL0
  29. #
  30. interface GigabitEthernet0/0
  31. port link-mode route
  32. description Multiple_Line
  33. ip address 222.XX.80.YYY 255.255.255.128
  34. tcp mss 1280
  35. ip last-hop hold
  36. nat outbound
  37. #
  38. interface GigabitEthernet0/1
  39. port link-mode route
  40. description Multiple_Line
  41. ip address 222.XXX.90.YYY 255.255.255.128
  42. ip last-hop hold
  43. nat outbound
  44. nat server protocol tcp global 222.XXX.90.YYY 1024 inside 172.16.1.254 20
  45. nat server protocol tcp global 222.XXX.90.YYY 1025 inside 172.16.1.254 21
  46. nat hairpin enable
  47. #
  48. interface GigabitEthernet0/2
  49. port link-mode route
  50. combo enable copper
  51. ip address 172.16.1.1 255.255.255.0
  52. #
  53. interface GigabitEthernet0/3
  54. port link-mode route
  55. description Multiple_Line
  56. combo enable copper
  57. ip address 171.XXX.209.YYY 255.255.255.128
  58. ip last-hop hold
  59. nat outbound
  60. #
  61. interface GigabitEthernet0/4
  62. port link-mode route
  63. #
  64. interface GigabitEthernet0/5
  65. port link-mode route
  66. #
  67. scheduler logfile size 16
  68. #
  69. line class console
  70. user-role network-admin
  71. #
  72. line class tty
  73. user-role network-operator
  74. #
  75. line class vty
  76. user-role network-operator
  77. #
  78. line con 0
  79. user-role network-admin
  80. #
  81. line vty 0 63
  82. authentication-mode scheme
  83. user-role network-operator
  84. #
  85. ip route-static 0.0.0.0 0 222.XXX.80.YYY
  86. ip route-static 0.0.0.0 0 222.XXX.90.YYY
  87. ip route-static 0.0.0.0 0 171.XXX.209.YYY
  88. ip route-static 192.168.0.0 16 10.10.10.2
  89. ip route-static 192.168.0.0 16 172.16.1.2
  90. #
  91. password-control enable
  92. undo password-control aging enable
  93. undo password-control history enable
  94. password-control length 6
  95. password-control login-attempt 3 exceed lock-time 10
  96. password-control update-interval 0
  97. password-control login idle-time 0
  98. password-control complexity user-name check
  99. #
  100. domain system
  101. #
  102. domain default enable system
  103. #
  104. role name level-0
  105. description Predefined level-0 role
  106. #
  107. role name level-1
  108. description Predefined level-1 role
  109. #
  110. role name level-2
  111. description Predefined level-2 role
  112. #
  113. role name level-3
  114. description Predefined level-3 role
  115. #
  116. role name level-4
  117. description Predefined level-4 role
  118. #
  119. role name level-5
  120. description Predefined level-5 role
  121. #
  122. role name level-6
  123. description Predefined level-6 role
  124. #
  125. role name level-7
  126. description Predefined level-7 role
  127. #
  128. role name level-8
  129. description Predefined level-8 role
  130. #
  131. role name level-9
  132. description Predefined level-9 role
  133. #
  134. role name level-10
  135. description Predefined level-10 role
  136. #
  137. role name level-11
  138. description Predefined level-11 role
  139. #
  140. role name level-12
  141. description Predefined level-12 role
  142. #
  143. role name level-13
  144. description Predefined level-13 role
  145. #
  146. role name level-14
  147. description Predefined level-14 role
  148. #
  149. user-group system
  150. #
  151. local-user admin class manage
  152. service-type telnet http
  153. authorization-attribute user-role network-admin
  154. #
  155. ip http port 8444
  156. ip http enable
  157. #
  158. wlan global-configuration
  159. control-address disable
  160. nas-id cm-0-830347-210235A2C7M18
  161. wlan ap-group default-group
  162. #
  163. cloud-management server domain oasis.h3c.com
  164. #
  165. return
粉丝:6人 关注:0人
该问题是由于FTP使用特殊端口号,导致出口设备的NAT ALG无法正常工作。此时在全局下配置一条port-mapping ftp port XX命令即可。XX即为服务器端被修改的端口号。
配置了,还是不行
丶丶丶丶 发表时间:2020-11-09
参考这个文档案例:https://zhiliao.h3c.com/Theme/details/5669
一切皆可能 发表时间:2020-11-09
你改端口了  有个配置要加下  直接新映射21 不行吗
能说详细点嘛,那个配置出问题了
回复丶丶丶丶:
看下面回复
无双上将潘凤 发表时间:2020-11-09
port-mapping ftp port xx  xx是你映射的端口  试试
port-mapping ftp port 1025 这样嘛?
回复丶丶丶丶:
嗯嗯 试试看
好的
不行
port-mapping 前面必须加上 application 这个
后面
回复丶丶丶丶:
那加一下吧 具体命令我也忘记了 可以了没
加上了,还是不行
回复丶丶丶丶:
你内网是访问正常的吧 你现在测试是热点测试还是内网测试外网ip?
内网访问正常
公网访问内网
回复丶丶丶丶:
地址多少 我看看?
ftp://222.212.90.232:1025
回复丶丶丶丶:
端口能改到50000以后吗 我怕运营商会封前面一些公共端口
可以
改好了
改成50001
