IE4100-12TP 环网配置
2020-11-11提问
  • 1收藏,867浏览
6台IE4100千兆光口组环网,怎么配置指令?
6台IE4100千兆光口收尾相连,组成千兆环网,怎么配置?另外咨询下,聚合是啥意思?业主要我们每台电脑双网卡接入交换机。电脑ip同网段应该不能联通吧?!
粉丝:8人 关注:1人
1.11.1  单环配置举例
·     Device A~Device D构成RRPP域1,该域的控制VLAN为VLAN 4092,保护VLAN为VLAN 1~30。
·     Device A、Device B、Device C和Device D构成主环Ring 1。Device A为主环的主节点,Ethernet1/0/1和Ethernet1/0/2分别为主、副端口;Device B、Device C和Device D为主环的传输节点,其各自的Ethernet1/0/1和Ethernet1/0/2分别为主、副端口。
图1-8 单环配置组网图
(1)     配置Device A
# 创建VLAN 1~30,将这些VLAN都映射到MSTI 1上,并激活MST域的配置。
[DeviceA] vlan 1 to 30
[DeviceA] stp region-configuration
[DeviceA-mst-region] instance 1 vlan 1 to 30
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# 分别在端口Ethernet1/0/1Ethernet1/0/2上取消物理连接状态up/down抑制时间配置,关闭生成树协议,配置端口信任报文的802.1p优先级,并将端口配置为Trunk端口且允许VLAN 130通过。
[DeviceA] interface Ethernet 1/0/1
[DeviceA-Ethernet1/0/1] undo link-delay
[DeviceA-Ethernet1/0/1] undo stp enable
[DeviceA-Ethernet1/0/1] qos trust dot1p
[DeviceA-Ethernet1/0/1] port link-type trunk
[DeviceA-Ethernet1/0/1] port trunk permit vlan 1 to 30
[DeviceA-Ethernet1/0/1] quit
[DeviceA] interface Ethernet 1/0/2
[DeviceA-Ethernet1/0/2] undo link-delay
[DeviceA-Ethernet1/0/2] undo stp enable
[DeviceA-Ethernet1/0/2] qos trust dot1p
[DeviceA-Ethernet1/0/2] port link-type trunk
[DeviceA-Ethernet1/0/2] port trunk permit vlan 1 to 30
[DeviceA-Ethernet1/0/2] quit
# 创建RRPP域1,将VLAN 4092配置为该域的控制VLAN,并将MSTI 1所映射的VLAN配置为该域的保护VLAN。
[DeviceA] rrpp domain 1
[DeviceA-rrpp-domain1] control-vlan 4092
[DeviceA-rrpp-domain1] protected-vlan reference-instance 1
# 配置本设备为主环Ring 1的主节点,主端口为Ethernet1/0/1,副端口为Ethernet1/0/2,并使能该环。
[DeviceA-rrpp-domain1] ring 1 node-mode master primary-port Ethernet 1/0/1 secondary-port Ethernet 1/0/2 level 0
[DeviceA-rrpp-domain1] ring 1 enable
[DeviceA-rrpp-domain1] quit
# 使能RRPP协议。
[DeviceA] rrpp enable
(2)     配置Device B
[DeviceB] vlan 1 to 30
[DeviceB] stp region-configuration
[DeviceB-mst-region] instance 1 vlan 1 to 30
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# 分别在端口Ethernet1/0/1和Ethernet1/0/2上取消物理连接状态up/down抑制时间配置,关闭生成树协议,配置端口信任报文的802.1p优先级,并将端口配置为Trunk端口且允许VLAN 1~30通过。
[DeviceB] interface Ethernet 1/0/1
[DeviceB-Ethernet1/0/1] undo link-delay
[DeviceB-Ethernet1/0/1] undo stp enable
[DeviceB-Ethernet1/0/1] qos trust dot1p
[DeviceB-Ethernet1/0/1] port link-type trunk
[DeviceB-Ethernet1/0/1] port trunk permit vlan 1 to 30
[DeviceB-Ethernet1/0/1] quit
[DeviceB] interface Ethernet 1/0/2
[DeviceB-Ethernet1/0/2] undo link-delay
[DeviceB-Ethernet1/0/2] undo stp enable
[DeviceB-Ethernet1/0/2] qos trust dot1p
[DeviceB-Ethernet1/0/2] port link-type trunk
[DeviceB-Ethernet1/0/2] port trunk permit vlan 1 to 30
[DeviceB-Ethernet1/0/2] quit
[DeviceB] rrpp domain 1
[DeviceB-rrpp-domain1] control-vlan 4092
[DeviceB-rrpp-domain1] protected-vlan reference-instance 1
# 配置本设备为主环Ring 1的传输节点,主端口为Ethernet1/0/1,副端口为Ethernet1/0/2,并使能该环。
[DeviceB-rrpp-domain1] ring 1 node-mode transit primary-port Ethernet 1/0/1 secondary-port Ethernet 1/0/2 level 0
[DeviceB-rrpp-domain1] ring 1 enable
[DeviceB-rrpp-domain1] quit
# 使能RRPP协议。
[DeviceB] rrpp enable
(3)     配置Device C
Device C的配置与Device B相似,配置过程略。
(4)     配置Device D
Device D的配置与Device B相似,配置过程略。
(5)     检验配置效果
配置完成后,用户可以使用display命令查看各设备上RRPP的配置和运行情况。
