H3C 3100v3 上联 H3C5560X
2020-11-11提问
  • 1收藏,3043浏览
粉丝:1人 关注:1人
设置列表
  • 有序列表
  • 无序列表
在翻看二层3100时发现如下两种问题,自我排查发现 3层聚合口 和 二层 聚合口 均是允许了VLAN1通过,为什么还会出现如上原因呢?求大佬解答!
ARP 问题如下:出现频率每小时一次
%Nov 11 20:55:58:227 2020 SF5-3A2-5P05-3100-01 DRVPLAT/4/SOFTCAR DROP:
 PktType= ARP , srcMAC=3080-9baa-9842, Drop From Interface=GE1/0/48     at Stage=63, StageCnt=158536 TotalCnt=47292652, Max Rate Interface=GE1/0/48     !!
STP问题如下:出现频率几分钟一条,很多。(网上解释是说:因为STP的BPDU报文可以发出但是收不到所以报如下错误:)
%Nov 11 20:57:57:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 217's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 21:03:29:729 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 219's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
log 如下:
%Nov 11 21:14:47:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 207's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 21:14:18:729 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 200's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 21:08:30:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 219's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 21:06:02:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 220's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 21:04:30:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 218's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:49:51:729 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 211's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:49:25:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 216's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:49:07:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 215's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:47:46:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 206's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:46:49:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 212's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:40:00:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 201's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:23:17:729 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 203's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:20:21:700 2020 SF5-3A2-5P05-3100-01 SHELL/5/SHELL_LOGOUT: kzi_zhang logged out from 172.28.2.178.
%Nov 11 20:15:33:731 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 214's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:13:47:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 203's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:13:14:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 209's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
%Nov 11 20:13:01:730 2020 SF5-3A2-5P05-3100-01 STP/5/STP_BPDU_RECEIVE_EXPIRY: VLAN 210's port GigabitEthernet1/0/48 received no BPDU within the rcvdInfoWhi
粉丝:30人 关注:0人
日志内容
Instance [UINT32]'s port [STRING] received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
参数解释
$1:生成树实例编号。
$2:接口名。
日志等级
5
举例
STP/5/STP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet1/0/1 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
日志说明
非指定端口因在BPDU超时之前没有收到任何BPDU报文,端口状态发生改变。
处理建议
检查上行设备的STP状态及是否存在恶意攻击。
这是上联设备信息 display stp brief 1 Bridge-Aggregation35 DESI FORWARDING NONE 如下是上联日志信息, %Nov 11 13:27:13:106 2020 SF5-3A-Core-5560X-01 STP/4/STP_DISPUTE: VLAN 280's port Bridge-Aggregation35 received an inferior BPDU from a designated port which is in forwarding or learning state.
zhiliao_qLqCyj 发表时间:2020-11-12
可以查看官网日志手册:https://www.h3c.com/cn/Service/Document_Software/Document_Center/Switches/Catalog/S5560/S5560S-EI/Maintenance/Message/H3C_S5560S-EI_Message-6W100/
FackerC 发表时间:2020-11-12
谢谢!
