2540H AC 广播组播高
2020-11-17提问
  • 2收藏,1928浏览
2540H AC 旁挂,本地转发,一直提示广播组播占比过高。
AC 配置如下
  1. #
  2. version 7.1.064, Release 5435P02
  3. #
  4. sysname H3C
  5. #
  6. clock timezone Beijing add 08:00:00
  7. clock protocol none
  8. #
  9. wlan global-configuration
  10. region-code-lock enable
  11. nas-id cm-0-1296872-210235A1JMC193000222
  12. #
  13. telnet server enable
  14. #
  15. dns server 202.106.0.20
  16. #
  17. lldp global enable
  18. #
  19. password-recovery enable
  20. #
  21. vlan 1
  22. #
  23. vlan 2 to 100
  24. #
  25. wlan service-template pzoom
  26. ssid PZOOM
  27. vlan 88
  28. client forwarding-location ap vlan 88
  29. quick-association enable
  30. akm mode psk
  31. preshared-key pass-phrase cipher $c$3$5UhJaMo7VJpKIRopewtfqYGTCoC79EzXcTf7IA==
  32. cipher-suite ccmp
  33. cipher-suite tkip
  34. security-ie rsn
  35. security-ie wpa
  36. ft enable
  37. ft method over-the-ds
  38. client-rate-limit inbound mode static cir 12000
  39. client-rate-limit outbound mode static cir 12000
  40. service-template enable
  41. #
  42. wlan service-template pzoom-guest
  43. ssid PZOOM-GUEST
  44. vlan 88
  45. client forwarding-location ap vlan 88
  46. akm mode psk
  47. preshared-key pass-phrase cipher $c$3$47OBJHFWEIhLgywK8cGJw/ytcBpBQER4B0BB
  48. cipher-suite ccmp
  49. cipher-suite tkip
  50. security-ie rsn
  51. security-ie wpa
  52. client-rate-limit inbound mode static cir 2000
  53. client-rate-limit outbound mode static cir 2000
  54. service-template enable
  55. #
  56. interface NULL0
  57. #
  58. interface Vlan-interface1
  59. ip address 192.168.0.100 255.255.255.0
  60. #
  61. interface Vlan-interface40
  62. ip address 172.16.40.253 255.255.255.0
  63. #
  64. interface GigabitEthernet1/0/5
  65. port link-mode route
  66. #
  67. interface GigabitEthernet1/0/6
  68. port link-mode route
  69. #
  70. interface GigabitEthernet1/0/1
  71. port link-mode bridge
  72. port link-type trunk
  73. port trunk permit vlan all
  74. #
  75. interface GigabitEthernet1/0/2
  76. port link-mode bridge
  77. #
  78. interface GigabitEthernet1/0/3
  79. port link-mode bridge
  80. #
  81. interface GigabitEthernet1/0/4
  82. port link-mode bridge
  83. #
  84. scheduler logfile size 16
  85. #
  86. line class console
  87. user-role network-admin
  88. #
  89. line class vty
  90. user-role network-operator
  91. #
  92. line con 0
  93. user-role network-admin
  94. #
  95. line vty 0 31
  96. authentication-mode scheme
  97. user-role network-operator
  98. #
  99. ip route-static 0.0.0.0 0 172.16.40.10
  100. #
  101. undo info-center logfile enable
  102. #
  103. domain system
  104. #
  105. domain default enable system
  106. #
  107. role name level-0
  108. description Predefined level-0 role
  109. #
  110. role name level-1
  111. description Predefined level-1 role
  112. #
  113. role name level-2
  114. description Predefined level-2 role
  115. #
  116. role name level-3
  117. description Predefined level-3 role
  118. #
  119. role name level-4
  120. description Predefined level-4 role
  121. #
  122. role name level-5
  123. description Predefined level-5 role
  124. #
  125. role name level-6
  126. description Predefined level-6 role
  127. #
  128. role name level-7
  129. description Predefined level-7 role
  130. #
  131. role name level-8
  132. description Predefined level-8 role
  133. #
  134. role name level-9
  135. description Predefined level-9 role
  136. #
  137. role name level-10
  138. description Predefined level-10 role
  139. #
  140. role name level-11
  141. description Predefined level-11 role
  142. #
  143. role name level-12
  144. description Predefined level-12 role
  145. #
  146. role name level-13
  147. description Predefined level-13 role
  148. #
  149. role name level-14
  150. description Predefined level-14 role
  151. #
  152. user-group system
  153. #
  154. local-user admin class manage
  155. password hash $h$6$JcmPXtoGJ//I0mCT$fR5PM/yJE6rzdfrYqjfuz7zezHTMPyufUY3/NtQLnt2AWkuNLuonAYS1FfXEvl3TvCmF4yTahG4vqSImLtRbMQ==
  156. service-type telnet http https
  157. authorization-attribute user-role network-admin
  158. #
  159. ip http enable
  160. ip https enable
  161. #
  162. wlan auto-ap enable
  163. wlan auto-persistent enable
  164. #
  165. wlan ap-group default-group
  166. vlan 1
  167. broadcast-probe reply disable
  168. ap-model WA4330-ACN
  169.   map-configuration flash:/apcfg.txt
  170.   radio 1
  171.   max-power 10
  172.   rate mandatory 12 24
  173.   rate supported 18 36 48 54
  174.   rate disabled 6 9
  175.   radio enable
  176.   rrm
  177.     calibrate-channel self-decisive enable
  178.   radio 2
  179.   max-power 10
  180.   rate mandatory 12 24
  181.   rate supported 18 36 48 54
  182.   rate disabled 6 9
  183.   radio enable
  184.   rrm
  185.     calibrate-channel self-decisive enable
  186.   radio 3
  187.   max-power 10
  188.   rate mandatory 11
  189.   rate supported 12 18 24 36 48 54
  190.   rate disabled 1 2 5.5 6 9
  191.   radio enable
  192.   rrm
  193.     calibrate-channel self-decisive enable
  194.   gigabitethernet 1
  195.   gigabitethernet 2
  196. ap-model WA5320-SI
  197.   map-configuration flash:/apcfg.txt
  198.   radio 1
  199.   max-power 10
  200.   rate mandatory 12 24
  201.   rate supported 18 36 48 54
  202.   rate disabled 6 9
  203.   radio enable
  204.   radio 2
  205.   max-power 10
  206.   rate mandatory 11
  207.   rate supported 12 18 24 36 48 54
  208.   rate disabled 1 2 5.5 6 9
  209.   radio enable
  210.   gigabitethernet 1
  211. ap-model WA5530-SI
  212.   map-configuration flash:/apcfg.txt
  213.   radio 1
  214.   max-power 10
  215.   rate mandatory 12 24
  216.   rate supported 18 36 48 54
  217.   rate disabled 6 9
  218.   radio enable
  219.   radio 2
  220.   max-power 10
  221.   rate mandatory 12 24
  222.   rate supported 18 36 48 54
  223.   rate disabled 6 9
  224.   radio enable
  225.   radio 3
  226.   max-power 10
  227.   rate mandatory 11
  228.   rate supported 12 18 24 36 48 54
  229.   rate disabled 1 2 5.5 6 9
  230.   radio enable
  231.   gigabitethernet 1
  232.   gigabitethernet 2
  233. ap-model WA6320H-LI
  234.   map-configuration flash:/apcfg.txt
  235.   radio 1
  236.   rate mandatory 12 24
  237.   rate supported 18 36 48 54
  238.   rate disabled 6 9
  239.   radio enable
  240.   radio 2
  241.   rate mandatory 11
  242.   rate supported 12 18 24 36 48 54
  243.   rate disabled 1 2 5.5 6 9
  244.   radio enable
  245.   gigabitethernet 1
  246.   gigabitethernet 2
  247.   gigabitethernet 3
  248.   gigabitethernet 4
  249.   gigabitethernet 5
  250. #
  251. wlan ap 1F-01 model WA4330-ACN
  252. serial-id 210235A1K6C18B000482
  253. description 3-11
  254. vlan 1
  255. radio 1
  256.   service-template pzoom
  257.   service-template pzoom-guest
  258. radio 2
  259.   service-template pzoom
  260.   service-template pzoom-guest
  261. radio 3
  262.   service-template pzoom
  263.   service-template pzoom-guest
  264. gigabitethernet 1
  265. gigabitethernet 2
  266. #
  267. wlan ap 1F-02 model WA5530-SI
  268. serial-id 219801A1BW819BE00GGS
  269. vlan 1
  270. radio 1
  271.   service-template pzoom
  272.   service-template pzoom-guest
  273. radio 2
  274.   service-template pzoom
  275.   service-template pzoom-guest
  276. radio 3
  277.   radio enable
  278.   service-template pzoom
  279.   service-template pzoom-guest
  280. gigabitethernet 1
  281. gigabitethernet 2
  282. #
  283. wlan ap 1F-03 model WA4330-ACN
  284. serial-id 210235A1K6C18B000624
  285. description 3-3
  286. vlan 1
  287. radio 1
  288.   service-template pzoom
  289.   service-template pzoom-guest
  290. radio 2
  291.   service-template pzoom
  292.   service-template pzoom-guest
  293. radio 3
  294.   radio disable
  295.   service-template pzoom
  296.   service-template pzoom-guest
  297. gigabitethernet 1
  298. gigabitethernet 2
  299. #
  300. wlan ap 1F-04 model WA4330-ACN
  301. serial-id 210235A1K6C18B000145
  302. vlan 1
  303. radio 1
  304.   service-template pzoom
  305.   service-template pzoom-guest
  306. radio 2
  307.   service-template pzoom
  308.   service-template pzoom-guest
  309. radio 3
  310.   radio disable
  311.   service-template pzoom
  312.   service-template pzoom-guest
  313. gigabitethernet 1
  314. gigabitethernet 2
  315. #
  316. wlan ap 1F-05 model WA4330-ACN
  317. serial-id 210235A1K6C18B000218
  318. description 2-3
  319. vlan 1
  320. radio 1
  321.   service-template pzoom
  322.   service-template pzoom-guest
  323. radio 2
  324.   service-template pzoom
  325.   service-template pzoom-guest
  326. radio 3
  327.   radio disable
  328.   service-template pzoom
  329.   service-template pzoom-guest
  330. gigabitethernet 1
  331. gigabitethernet 2
  332. #
  333. wlan ap 2F-01 model WA4330-ACN
  334. serial-id 210235A1K6C18B000148
  335. description 2-10
  336. vlan 1
  337. radio 1
  338.   service-template pzoom
  339.   service-template pzoom-guest
  340. radio 2
  341.   service-template pzoom
  342.   service-template pzoom-guest
  343. radio 3
  344.   radio disable
  345.   service-template pzoom
  346.   service-template pzoom-guest
  347. gigabitethernet 1
  348. gigabitethernet 2
  349. #
  350. wlan ap 2F-02 model WA5530-SI
  351. serial-id 219801A1BW819CE0008X
  352. vlan 1
  353. radio 1
  354.   radio enable
  355.   service-template pzoom
  356.   service-template pzoom-guest
  357. radio 2
  358.   radio enable
  359.   service-template pzoom
  360.   service-template pzoom-guest
  361. radio 3
  362.   service-template pzoom
  363.   service-template pzoom-guest
  364. gigabitethernet 1
  365. gigabitethernet 2
  366. #
  367. wlan ap 2F-03 model WA5530-SI
  368. serial-id 219801A1BW819CE000FY
  369. vlan 1
  370. radio 1
  371.   radio enable
  372.   service-template pzoom
  373.   service-template pzoom-guest
  374. radio 2
  375.   radio enable
  376.   service-template pzoom
  377.   service-template pzoom-guest
  378. radio 3
  379.   service-template pzoom
  380.   service-template pzoom-guest
  381. gigabitethernet 1
  382. gigabitethernet 2
  383. #
  384. wlan ap 2F-04 model WA5530-SI
  385. serial-id 219801A1BW819CE000DK
  386. vlan 1
  387. radio 1
  388.   channel 44
  389.   radio enable
  390.   channel band-width 40
  391.   service-template pzoom
  392.   service-template pzoom-guest
  393. radio 2
  394.   channel 157
  395.   radio enable
  396.   service-template pzoom
  397.   service-template pzoom-guest
  398. radio 3
  399.   radio disable
  400.   service-template pzoom
  401.   service-template pzoom-guest
  402. gigabitethernet 1
  403. gigabitethernet 2
  404. #
  405. wlan ap 2F-05 model WA5530-SI
  406. serial-id 219801A1BW819CE000FS
  407. vlan 1
  408. radio 1
  409.   radio enable
  410.   service-template pzoom
  411.   service-template pzoom-guest
  412. radio 2
  413.   radio enable
  414.   service-template pzoom
  415.   service-template pzoom-guest
  416. radio 3
  417.   service-template pzoom
  418.   service-template pzoom-guest
  419. gigabitethernet 1
  420. gigabitethernet 2
  421. #
  422. wlan ap 2F-06 model WA4330-ACN
  423. serial-id 210235A1K6C18B000478
  424. description 3-8
  425. vlan 1
  426. radio 1
  427.   service-template pzoom
  428.   service-template pzoom-guest
  429. radio 2
  430.   service-template pzoom
  431.   service-template pzoom-guest
  432. radio 3
  433.   radio disable
  434.   service-template pzoom
  435.   service-template pzoom-guest
  436. gigabitethernet 1
  437. gigabitethernet 2
  438. #
  439. wlan ap 2F-07 model WA5530-SI
  440. serial-id 219801A1BW819CE000G0
  441. vlan 1
  442. radio 1
  443.   channel 36
  444.   radio enable
  445.   channel band-width 40
  446.   service-template pzoom
  447.   service-template pzoom-guest
  448. radio 2
  449.   type dot11ac
  450.   channel 149
  451.   radio enable
  452.   channel band-width 40
  453.   dot11ac support maximum-nss 8
  454.   service-template pzoom
  455.   service-template pzoom-guest
  456. radio 3
  457.   service-template pzoom
  458.   service-template pzoom-guest
  459. gigabitethernet 1
  460. gigabitethernet 2
  461. #
  462. wlan ap 3F-01 model WA4330-ACN
  463. serial-id 210235A1K6C18B000723
  464. vlan 1
  465. radio 1
  466.   service-template pzoom
  467.   service-template pzoom-guest
  468. radio 2
  469.   service-template pzoom
  470.   service-template pzoom-guest
  471. radio 3
  472.   radio disable
  473.   service-template pzoom
  474.   service-template pzoom-guest
  475. gigabitethernet 1
  476. gigabitethernet 2
  477. #
  478. wlan ap 3F-02 model WA5530-SI
  479. serial-id 219801A1BW819BE00GH6
  480. vlan 1
  481. radio 1
  482.   service-template pzoom
  483.   service-template pzoom-guest
  484. radio 2
  485.   service-template pzoom
  486.   service-template pzoom-guest
  487. radio 3
  488.   service-template pzoom
  489.   service-template pzoom-guest
  490. gigabitethernet 1
  491. gigabitethernet 2
  492. #
  493. wlan ap 3F-03 model WA5530-SI
  494. serial-id 219801A1BW819BE00GH5
  495. vlan 1
  496. radio 1
  497.   service-template pzoom
  498.   service-template pzoom-guest
  499. radio 2
  500.   service-template pzoom
  501.   service-template pzoom-guest
  502. radio 3
  503.   service-template pzoom
  504.   service-template pzoom-guest
  505. gigabitethernet 1
  506. gigabitethernet 2
  507. #
  508. wlan ap 3F-04 model WA5530-SI
  509. serial-id 219801A1BW819BE00G9R
  510. vlan 1
  511. radio 1
  512.   service-template pzoom
  513.   service-template pzoom-guest
  514. radio 2
  515.   service-template pzoom
  516.   service-template pzoom-guest
  517. radio 3
  518.   service-template pzoom
  519.   service-template pzoom-guest
  520. gigabitethernet 1
  521. gigabitethernet 2
  522. #
  523. wlan ap 3F-05 model WA4330-ACN
  524. serial-id 210235A1K6C18B000330
  525. vlan 1
  526. radio 1
  527.   service-template pzoom
  528.   service-template pzoom-guest
  529. radio 2
  530.   service-template pzoom
  531.   service-template pzoom-guest
  532. radio 3
  533.   service-template pzoom
  534.   service-template pzoom-guest
  535. gigabitethernet 1
  536. gigabitethernet 2
  537. #
  538. wlan ap 3F-06 model WA4330-ACN
  539. serial-id 210235A1K6C195000973
  540. vlan 1
  541. radio 1
  542.   service-template pzoom
  543.   service-template pzoom-guest
  544. radio 2
  545.   service-template pzoom
  546.   service-template pzoom-guest
  547. radio 3
  548.   radio disable
  549.   service-template pzoom
  550.   service-template pzoom-guest
  551. gigabitethernet 1
  552. gigabitethernet 2
  553. #
  554. wlan ap 3F-07 model WA4330-ACN
  555. serial-id 210235A1K6C18B000118
  556. description 2-11
  557. vlan 1
  558. radio 1
  559.   service-template pzoom
  560.   service-template pzoom-guest
  561. radio 2
  562.   service-template pzoom
  563.   service-template pzoom-guest
  564. radio 3
  565.   radio disable
  566.   service-template pzoom
  567.   service-template pzoom-guest
  568. gigabitethernet 1
  569. gigabitethernet 2
  570. #
  571. wlan ap 3F-08 model WA5530-SI
  572. serial-id 219801A1BW819BE00GHP
  573. vlan 1
  574. radio 1
  575.   service-template pzoom
  576.   service-template pzoom-guest
  577. radio 2
  578.   service-template pzoom
  579.   service-template pzoom-guest
  580. radio 3
  581.   service-template pzoom
  582.   service-template pzoom-guest
  583. gigabitethernet 1
  584. gigabitethernet 2
  585. #
  586. wlan ap 3F-09 model WA4330-ACN
  587. serial-id 210235A1K6C18B000443
  588. description 3-2
  589. vlan 1
  590. radio 1
  591.   service-template pzoom
  592.   service-template pzoom-guest
  593. radio 2
  594.   service-template pzoom
  595.   service-template pzoom-guest
  596. radio 3
  597.   radio disable
  598.   service-template pzoom
  599.   service-template pzoom-guest
  600. gigabitethernet 1
  601. gigabitethernet 2
  602. #
  603. wlan ap 3F-10 model WA5530-SI
  604. serial-id 219801A1BW819BE00GH1
  605. vlan 1
  606. radio 1
  607.   service-template pzoom
  608.   service-template pzoom-guest
  609. radio 2
  610.   service-template pzoom
  611.   service-template pzoom-guest
  612. radio 3
  613.   service-template pzoom
  614.   service-template pzoom-guest
  615. gigabitethernet 1
  616. gigabitethernet 2
  617. #
  618. wlan ap 3F-11 model WA5530-SI
  619. serial-id 219801A1BW819BE00FWF
  620. vlan 1
  621. radio 1
  622.   service-template pzoom
  623.   service-template pzoom-guest
  624. radio 2
  625.   service-template pzoom
  626.   service-template pzoom-guest
  627. radio 3
  628.   service-template pzoom
  629.   service-template pzoom-guest
  630. gigabitethernet 1
  631. gigabitethernet 2
  632. #
  633. wlan ap 3F-12 model WA4330-ACN
  634. serial-id 210235A1K6C18B000698
  635. description 2-4
  636. vlan 1
  637. radio 1
  638.   service-template pzoom
  639.   service-template pzoom-guest
  640. radio 2
  641.   service-template pzoom
  642.   service-template pzoom-guest
  643. radio 3
  644.   radio disable
  645.   service-template pzoom
  646.   service-template pzoom-guest
  647. gigabitethernet 1
  648. gigabitethernet 2
  649. #
  650. wlan ap 3F-13 model WA5530-SI
  651. serial-id 219801A1BW819BE00G6M
  652. vlan 1
  653. radio 1
  654.   service-template pzoom
  655.   service-template pzoom-guest
  656. radio 2
  657.   service-template pzoom
  658.   service-template pzoom-guest
  659. radio 3
  660.   service-template pzoom
  661.   service-template pzoom-guest
  662. gigabitethernet 1
  663. gigabitethernet 2
  664. #
  665. wlan ap 3F-14 model WA4330-ACN
  666. serial-id 210235A1K6C18B000434
  667. description 3-7
  668. vlan 1
  669. radio 1
  670.   service-template pzoom
  671.   service-template pzoom-guest
  672. radio 2
  673.   service-template pzoom
  674.   service-template pzoom-guest
  675. radio 3
  676.   radio disable
  677.   service-template pzoom
  678.   service-template pzoom-guest
  679. gigabitethernet 1
  680. gigabitethernet 2
  681. #
  682. wlan ap 3F-15 model WA5530-SI
  683. serial-id 219801A1BW819BE00GH0
  684. vlan 1
  685. radio 1
  686.   service-template pzoom
  687.   service-template pzoom-guest
  688. radio 2
  689.   service-template pzoom
  690.   service-template pzoom-guest
  691. radio 3
  692.   service-template pzoom
  693.   service-template pzoom-guest
  694. gigabitethernet 1
  695. gigabitethernet 2
  696. #
  697. wlan ap 3F-16 model WA4330-ACN
  698. serial-id 210235A1K6C18B000373
  699. vlan 1
  700. radio 1
  701.   service-template pzoom
  702.   service-template pzoom-guest
  703. radio 2
  704.   service-template pzoom
  705.   service-template pzoom-guest
  706. radio 3
  707.   radio disable
  708.   service-template pzoom
  709.   service-template pzoom-guest
  710. gigabitethernet 1
  711. gigabitethernet 2
  712. #
  713. wlan ap 3F-17 model WA4330-ACN
  714. serial-id 210235A1K6C191000121
  715. description 2-9
  716. vlan 1
  717. radio 1
  718.   service-template pzoom
  719.   service-template pzoom-guest
  720. radio 2
  721.   service-template pzoom
  722.   service-template pzoom-guest
  723. radio 3
  724.   radio disable
  725.   service-template pzoom
  726.   service-template pzoom-guest
  727. gigabitethernet 1
  728. gigabitethernet 2
  729. #
  730. wlan ap 3F-18 model WA4330-ACN
  731. serial-id 210235A1K6C191000139
  732. description 3-10
  733. vlan 1
  734. radio 1
  735.   service-template pzoom
  736.   service-template pzoom-guest
  737. radio 2
  738.   service-template pzoom
  739.   service-template pzoom-guest
  740. radio 3
  741.   radio disable
  742.   service-template pzoom
  743.   service-template pzoom-guest
  744. gigabitethernet 1
  745. gigabitethernet 2
  746. #
  747. wlan ap 3F-19 model WA5320-SI
  748. serial-id 219801A1B38199E006M6
  749. vlan 1
  750. radio 1
  751.   radio enable
  752.   service-template pzoom
  753.   service-template pzoom-guest
  754. radio 2
  755.   radio disable
  756.   service-template pzoom
  757.   service-template pzoom-guest
  758. gigabitethernet 1
  759. #
  760. wlan ap 3F-20 model WA5320-SI
  761. serial-id 219801A1B38199E0062Y
  762. vlan 1
  763. radio 1
  764.   radio enable
  765.   service-template pzoom
  766.   service-template pzoom-guest
  767. radio 2
  768.   radio enable
  769.   service-template pzoom
  770.   service-template pzoom-guest
  771. gigabitethernet 1
  772. #
  773. wlan ap 3F-21 model WA5530-SI
  774. serial-id 219801A1BW819BE00GH3
  775. vlan 1
  776. radio 1
  777.   service-template pzoom
  778.   service-template pzoom-guest
  779. radio 2
  780.   service-template pzoom
  781.   service-template pzoom-guest
  782. radio 3
  783.   service-template pzoom
  784.   service-template pzoom-guest
  785. gigabitethernet 1
  786. gigabitethernet 2
  787. #
  788. wlan ap 3F-22 model WA4330-ACN
  789. serial-id 210235A1K6C18B000061
  790. description 3-1
  791. vlan 1
  792. radio 1
  793.   service-template pzoom
  794.   service-template pzoom-guest
  795. radio 2
  796.   service-template pzoom
  797.   service-template pzoom-guest
  798. radio 3
  799.   service-template pzoom
  800.   service-template pzoom-guest
  801. gigabitethernet 1
  802. gigabitethernet 2
  803. #
  804. wlan ap 3F-23 model WA4330-ACN
  805. serial-id 210235A1K6C191000077
  806. description 3-5
  807. vlan 1
  808. radio 1
  809.   service-template pzoom
  810.   service-template pzoom-guest
  811. radio 2
  812.   service-template pzoom
  813.   service-template pzoom-guest
  814. radio 3
  815.   radio enable
  816.   service-template pzoom
  817.   service-template pzoom-guest
  818. gigabitethernet 1
  819. gigabitethernet 2
  820. #
  821. wlan ap 3F-24 model WA4330-ACN
  822. serial-id 210235A1K6C191000141
  823. description 2-7
  824. vlan 1
  825. radio 1
  826.   service-template pzoom
  827.   service-template pzoom-guest
  828. radio 2
  829.   service-template pzoom
  830.   service-template pzoom-guest
  831. radio 3
  832.   radio enable
  833.   service-template pzoom
  834.   service-template pzoom-guest
  835. gigabitethernet 1
  836. gigabitethernet 2
  837. #
  838. wlan ap 3F-25 model WA6320H-LI
  839. serial-id 219801A2BU8204E00035
  840. vlan 1
  841. radio 1
  842.   service-template pzoom
  843.   service-template pzoom-guest
  844. radio 2
  845.   service-template pzoom
  846.   service-template pzoom-guest
  847. gigabitethernet 1
  848. gigabitethernet 2
  849. gigabitethernet 3
  850. gigabitethernet 4
  851. gigabitethernet 5
  852. #
  853. wlan ap B1-01 model WA4330-ACN
  854. serial-id 210235A1K6C18B000365
  855. description 3-9
  856. vlan 1
  857. radio 1
  858.   service-template pzoom
  859.   service-template pzoom-guest
  860. radio 2
  861.   max-power 13
  862.   power-lock enable
  863.   service-template pzoom
  864.   service-template pzoom-guest
  865. radio 3
  866.   radio enable
  867.   service-template pzoom
  868.   service-template pzoom-guest
  869. gigabitethernet 1
  870. gigabitethernet 2
  871. #
  872. wlan ap B1-02 model WA4330-ACN
  873. serial-id 210235A1K6C18B000068
  874. description 3-4
  875. vlan 1
  876. radio 1
  877.   service-template pzoom
  878.   service-template pzoom-guest
  879. radio 2
  880.   service-template pzoom
  881.   service-template pzoom-guest
  882. radio 3
  883.   radio disable
  884.   service-template pzoom
  885.   service-template pzoom-guest
  886. gigabitethernet 1
  887. gigabitethernet 2
  888. #
  889. wlan ap B1-03 model WA4330-ACN
  890. serial-id 210235A1K6C18B000465
  891. description 2-6
  892. vlan 1
  893. radio 1
  894.   service-template pzoom
  895.   service-template pzoom-guest
  896. radio 2
  897.   service-template pzoom
  898.   service-template pzoom-guest
  899. radio 3
  900.   radio disable
  901.   service-template pzoom
  902.   service-template pzoom-guest
  903. gigabitethernet 1
  904. gigabitethernet 2
  905. #
  906. cloud-management server domain oasis.h3c.com
  907. #
  908. return
核心配置如下:
  1. sysname H3C
  2. telnet server enable
  3. irf mac-address persistent timer
  4. irf auto-update enable
  5. undo irf link-delay
  6. irf member 1 priority 1
  7. dhcp enable
  8. dhcp server forbidden-ip 192.168.10.1 192.168.10.100
  9. lldp global enable
  10. fan prefer-direction slot 1 port-to-power
  11. password-recovery enable
  12. vlan 1
  13. vlan 10
  14. vlan 20
  15. vlan 30
  16. vlan 40
  17. vlan 50
  18. vlan 60
  19. vlan 70
  20. vlan 80
  21. vlan 88
  22. vlan 100
  23. vlan 110
  24. vlan 120
  25. vlan 130
  26. vlan 140
  27. vlan 200
  28. vlan 300
  29. stp global enable
  30. dhcp server ip-pool 10
  31. gateway-list 10.140.10.10
  32. network 10.140.10.0 mask 255.255.255.0
  33. dns-list 202.106.0.20 114.114.114.114
  34. forbidden-ip 10.140.10.10
  35. dhcp server ip-pool 20
  36. gateway-list 10.140.20.10
  37. network 10.140.20.0 mask 255.255.255.0
  38. dns-list 202.106.0.20 114.114.114.114
  39. forbidden-ip 10.140.20.10
  40. dhcp server ip-pool 30
  41. gateway-list 10.140.30.10
  42. network 10.140.30.0 mask 255.255.255.0
  43. dns-list 202.106.0.20 114.114.114.114
  44. forbidden-ip 10.140.30.10
  45. dhcp server ip-pool 40
  46. gateway-list 172.16.40.10
  47. network 172.16.40.0 mask 255.255.255.0
  48. dhcp server ip-pool 50
  49. gateway-list 10.140.50.10
  50. network 10.140.50.0 mask 255.255.255.0
  51. dns-list 202.106.0.20 114.114.114.114
  52. forbidden-ip 10.140.50.10
  53. dhcp server ip-pool 60
  54. gateway-list 10.140.60.10
  55. network 10.140.60.0 mask 255.255.255.0
  56. dns-list 202.106.0.20 114.114.114.114
  57. forbidden-ip 10.140.60.10
  58. dhcp server ip-pool 70
  59. gateway-list 10.140.70.10
  60. network 10.140.70.0 mask 255.255.255.0
  61. dns-list 202.106.0.20 114.114.114.114
  62. forbidden-ip 10.140.70.10
  63. dhcp server ip-pool 80
  64. gateway-list 10.140.80.10
  65. network 10.140.80.0 mask 255.255.255.0
  66. dns-list 202.106.0.20 114.114.114.114
  67. forbidden-ip 10.140.80.10
  68. dhcp server ip-pool 88
  69. gateway-list 10.140.88.10
  70. network 10.140.88.0 mask 255.255.252.0
  71. dns-list 202.106.196.115 202.106.0.20
  72. expired day 0 hour 3
  73. dhcp server ip-pool 100
  74. gateway-list 10.140.100.10
  75. network 10.140.100.0 mask 255.255.255.0
  76. dns-list 202.106.0.20 114.114.114.114
  77. forbidden-ip 10.140.100.10
  78. dhcp server ip-pool 140
  79. gateway-list 10.140.140.10
  80. network 10.140.140.0 mask 255.255.255.0
  81. dns-list 202.106.0.20 114.114.114.114
  82. forbidden-ip 10.140.40.10
  83. forbidden-ip 10.140.140.10
  84. policy-based-route adsl permit node 1
  85. if-match acl 2000
  86. apply next-hop 10.10.11.1 direct
  87. interface NULL0
  88. interface Vlan-interface10
  89. ip address 10.140.10.10 255.255.255.0
  90. interface Vlan-interface20
  91. ip address 10.140.20.10 255.255.255.0
  92. interface Vlan-interface30
  93. ip address 10.140.30.10 255.255.255.0
  94. interface Vlan-interface40
  95. ip address 172.16.40.10 255.255.255.0
  96. ip policy-based-route adsl
  97. interface Vlan-interface50
  98. ip address 10.140.50.10 255.255.255.0
  99. interface Vlan-interface60
  100. ip address 10.140.60.10 255.255.255.0
  101. interface Vlan-interface70
  102. ip address 10.140.70.10 255.255.255.0
  103. interface Vlan-interface80
  104. ip address 10.140.80.10 255.255.255.0
  105. interface Vlan-interface88
  106. ip address 10.140.88.10 255.255.252.0
  107. ip policy-based-route adsl
  108. interface Vlan-interface100
  109. ip address 10.140.100.10 255.255.255.0
  110. interface Vlan-interface110
  111. ip address 10.140.110.10 255.255.255.0
  112. interface Vlan-interface120
  113. ip address 10.140.120.10 255.255.255.0
  114. interface Vlan-interface130
  115. ip address 10.110.20.10 255.255.255.0
  116. interface Vlan-interface140
  117. ip address 10.140.140.10 255.255.255.0
  118. ip policy-based-route adsl
  119. interface Vlan-interface200
  120. ip address 10.10.10.2 255.255.255.0
  121. interface Vlan-interface300
  122. ip address 10.10.11.2 255.255.255.0
  123. interface GigabitEthernet1/0/1
  124. port link-mode bridge
  125. port access vlan 200
  126. interface GigabitEthernet1/0/2
  127. port link-mode bridge
  128. port access vlan 300
  129. interface GigabitEthernet1/0/3
  130. port link-mode bridge
  131. interface GigabitEthernet1/0/4
  132. port link-mode bridge
  133. interface GigabitEthernet1/0/5
  134. port link-mode bridge
  135. port link-type trunk
  136. undo port trunk permit vlan 1
  137. port trunk permit vlan 40 88
  138. interface GigabitEthernet1/0/6
  139. port link-mode bridge
  140. port link-type trunk
  141. undo port trunk permit vlan 1
  142. port trunk permit vlan 40 88
  143. interface GigabitEthernet1/0/7
  144. port link-mode bridge
  145. port link-type trunk
  146. undo port trunk permit vlan 1
  147. port trunk permit vlan 40 88
  148. interface GigabitEthernet1/0/8
  149. port link-mode bridge
  150. interface GigabitEthernet1/0/9
  151. port link-mode bridge
  152. interface GigabitEthernet1/0/10
  153. port link-mode bridge
  154. interface GigabitEthernet1/0/11
  155. port link-mode bridge
  156. interface GigabitEthernet1/0/12
  157. port link-mode bridge
  158. interface GigabitEthernet1/0/13
  159. port link-mode bridge
  160. port link-type trunk
  161. port trunk permit vlan all
  162. interface GigabitEthernet1/0/14
  163. port link-mode bridge
  164. port link-type trunk
  165. port trunk permit vlan all
  166. interface GigabitEthernet1/0/15
  167. port link-mode bridge
  168. port link-type trunk
  169. port trunk permit vlan all
  170. interface GigabitEthernet1/0/16
  171. port link-mode bridge
  172. port link-type trunk
  173. port trunk permit vlan all
  174. interface GigabitEthernet1/0/17
  175. port link-mode bridge
  176. port link-type trunk
  177. port trunk permit vlan all
  178. interface GigabitEthernet1/0/18
  179. port link-mode bridge
  180. port link-type trunk
  181. port trunk permit vlan all
  182. interface GigabitEthernet1/0/19
  183. port link-mode bridge
  184. port link-type trunk
  185. port trunk permit vlan all
  186. interface GigabitEthernet1/0/20
  187. port link-mode bridge
  188. port link-type trunk
  189. port trunk permit vlan all
  190. interface GigabitEthernet1/0/21
  191. port link-mode bridge
  192. port link-type trunk
  193. port trunk permit vlan all
  194. interface GigabitEthernet1/0/22
  195. port link-mode bridge
  196. port link-type trunk
  197. port trunk permit vlan all
  198. interface GigabitEthernet1/0/23
  199. port link-mode bridge
  200. port link-type trunk
  201. port trunk permit vlan all
  202. interface GigabitEthernet1/0/24
  203. port link-mode bridge
  204. port link-type trunk
  205. port trunk permit vlan all
  206. interface M-GigabitEthernet0/0/0
  207. interface Ten-GigabitEthernet1/0/25
  208. port link-mode bridge
  209. interface Ten-GigabitEthernet1/0/26
  210. port link-mode bridge
  211. interface Ten-GigabitEthernet1/0/27
  212. port link-mode bridge
  213. interface Ten-GigabitEthernet1/0/28
  214. port link-mode bridge
  215. scheduler logfile size 16
  216. line class aux
  217. user-role network-admin
  218. line class vty
  219. user-role network-operator
  220. line aux 0
  221. user-role network-admin
  222. line vty 0 4
  223. authentication-mode scheme
  224. user-role network-operator
  225. line vty 5 63
  226. user-role network-operator
  227. ip route-static 0.0.0.0 0 10.10.10.1
  228. undo info-center enable
  229. time-range any 00:00 to 23:59 daily
  230. acl number 2000 name neiwang match-order auto
  231. rule 0 permit source 10.140.140.188 0 time-range any
  232. radius scheme system
  233. user-name-format without-domain
  234. domain system
  235. domain default enable system
  236. role name level-0
  237. description Predefined level-0 role
  238. role name level-1
  239. description Predefined level-1 role
  240. role name level-2
  241. description Predefined level-2 role
  242. role name level-3
  243. description Predefined level-3 role
  244. role name level-4
  245. description Predefined level-4 role
  246. role name level-5
  247. description Predefined level-5 role
  248. role name level-6
  249. description Predefined level-6 role
  250. role name level-7
  251. description Predefined level-7 role
  252. role name level-8
  253. description Predefined level-8 role
  254. role name level-9
  255. description Predefined level-9 role
  256. role name level-10
  257. description Predefined level-10 role
  258. role name level-11
  259. description Predefined level-11 role
  260. role name level-12
  261. description Predefined level-12 role
  262. role name level-13
  263. description Predefined level-13 role
  264. role name level-14
  265. description Predefined level-14 role
  266. user-group system
  267. local-user admin class manage
  268. password hash $h$6$X0gxIB6RTOc4Xn6L$bQaALAnb/JKHIyPWSWNXtX3BXmC2rqE6Xa3CO2ZjXOAOGSPFuUyHQsO2VSkrMZLGCm/dPSNTjG2Bpn7urwkg0Q==
  269. service-type telnet http https
  270. authorization-attribute user-role network-admin
  271. authorization-attribute user-role network-operator
  272. ip http enable
  273. ip https enable
  274. return
锤哥 七段
粉丝:16人 关注:5人
建议打400咨询一下
已经出了支持的时间了
zhiliao_g4qx3 发表时间:2020-11-17
回复zhiliao_g4qx3:
最后如何解决了呢
zhiliao_nV4kbN 发表时间:2023-02-10
