IPSec VPN第二阶段建立不起来,在线等。
2020-11-19提问
  • 1收藏,3839浏览
*Nov 19 11:09:08:732 2020 F100-C-G3 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65537. *Nov 19 11:09:08:732 2020 F100-C-G3 IPSEC/7/PACKET: Alloc IPsec cache: Global fs seq : 124, Private index : 0, Private seq : 0. *Nov 19 11:09:08:831 2020 F100-C-G3 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65537. *Nov 19 11:09:08:831 2020 F100-C-G3 IPSEC/7/PACKET: Alloc IPsec cache: Global fs seq : 124, Private index : 0, Private seq : 0. *Nov 19 11:09:08:831 2020 F100-C-G3 IPSEC/7/PACKET: Alloc IPsec cache: Global fs seq : 124, Private index : 0, Private seq : 0. *Nov 19 11:09:09:125 2020 F100-C-G3 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65537. *Nov 19 11:09:09:125 2020 F100-C-G3 IPSEC/7/PACKET: Alloc IPsec cache: Global fs seq : 124, Private index : 0, Private seq : 0. ,这个是我开启debugging以后报的日志,咋天还好好的重启了一下就不行了,。求大佬看看,在线等
粉丝:24人 关注:13人
可以看下,debug ike all中有没有下面这个提示,如果有1)检查两端IPSectransformset是否匹配2)检查两端感兴趣流是否互为镜像。
Failed to get IPSec policy for phase 2 responder. Delete IPSec SA.
Failed to negotiate IPSec SA.
另外如果发现INVALID_ID_INFORMATION
1)查看IPSec安全策略中引用的ACL配置是否正确。
2)查看IPSec 安全策略配置不完整。具体包括:没有配置对端地址、没有配置IPSec提议、IPSec提议配置不完整。
粉丝:12人 关注:4人
重置下IKE sa  重新触发下
