如何排查光模块灯不亮 什么命令查看光收发情况 收发多少数值算有问题
2020-11-20提问
  • 1收藏,1708浏览
粉丝:0人 关注:3人
最后该怎么排查
粉丝:11人 关注:1人
参考命令:dis transceiver diagnosis int g1/0/11
例如下图中收光RX为-16
收光范围为-3至-19,因此此收光正常,超出-19则不正常
粉丝:148人 关注:1人
输入查看光口率命令会有一个最低值,和最高值,在这个范围才行
命令如下:
1、display transceiver(收发器,指光模块) interface
<M9010>dis transceiver interface M-GigabitEthernet1/0/0/0 transceiver information: The operation is not supported. ——不支持此项功能 Ten-GigabitEthernet1/0/0/1 transceiver information: The transceiver is absent. ——未放置模块 Ten-GigabitEthernet1/0/0/2 transceiver information:——模块信息 Transceiver Type : 1000_BASE_SX_SFP Connector Type : LC Wavelength(nm) : 850 Transfer Distance(m) : 550(OM2),270(OM1) Digital Diagnostic Monitoring : YES Vendor Name : CISCO Ten-GigabitEthernet1/0/0/4 transceiver information: Transceiver Type : 1000_BASE_SX_SFP Connector Type : LC Wavelength(nm) : 850 Transfer Distance(m) : 500(OM2),300(OM1) Digital Diagnostic Monitoring : YES Vendor Name : FINISAR CORP. Ten-GigabitEthernet1/0/0/5 transceiver information: Transceiver Type : 10G_BASE_SR_SFP Connector Type : LC Wavelength(nm) : 850 Transfer Distance(m) : 80(OM2),20(OM1),300(OM3) Digital Diagnostic Monitoring : YES Vendor Name : H3C
2、display transceiver diagnosis interface
<M9010n>dis transceiver diagnosis interface M-GigabitEthernet1/0/0/0 transceiver diagnostic information: The operation is not supported. Ten-GigabitEthernet1/0/0/1 transceiver diagnostic information: The transceiver is absent. Ten-GigabitEthernet1/0/0/2 transceiver diagnostic information: Current diagnostic parameters: Temp.(?? Voltage(V) Bias(mA) RX power(dBm) TX power(dBm) 22 3.39 3.98 -6.73 -5.65 Alarm thresholds: Temp.(?? Voltage(V) Bias(mA) RX power(dBm) TX power(dBm) High 90 3.63 12.75 3.00 0.00 Low -10 2.97 2.00 -21.02 -13.50 Ten-GigabitEthernet1/0/0/4 transceiver diagnostic information: Reading information from the transceiver failed.
3、display transceiver manuinfo interface
<M9010>display transceiver manuinfo interface M-GigabitEthernet1/0/0/0 transceiver manufacture information: The operation is not supported. Ten-GigabitEthernet1/0/0/1 transceiver manufacture information: The transceiver is absent. Ten-GigabitEthernet1/0/0/2 transceiver manufacture information: The transceiver does not support this function. Ten-GigabitEthernet1/0/0/5 transceiver manufacture information: Manu. Serial Number : 210231A1RPX149001856 Manufacturing Date : 2014-09-10 Vendor Name : H3C
