ADVPN
2020-11-20提问
  • 1收藏,1949浏览
谁有ADVPN本地认证的案例,麻烦分享下。
现场为advpn组网,总部为一台MSR5660路由器,充当hub和server角色,采用本地认证,分部为MSR810作为spoke
现场关键配置如下:
1.总部配置
# ospf 1
 area 0.0.0.0
 network 192.168.1.1 0.0.0.0
interface GigabitEthernet2/0/1
 port link-mode route
 combo enable copper
 ip address x.x.x.x 255.255.255.252
 nat outbound
 interface Tunnel1 mode advpn udp
 ospf network-type p2mp
 source GigabitEthernet2/0/1
 tunnel protection ipsec profile zongbu1
 vam client hub1 compatible advpn0
radius scheme zongbu1
key authentication simple XXXX
key accounting  simple XXXX
user-name-format without-domain
domain zongbu1
 authentication advpn local
 domain default enable zongbu1
local-user changfa class network
 password simple XXXX
 service-type advpn
ipsec transform-set zongbu1
esp encryption-algorithm des-cbc
 esp authentication-algorithm md5
 ipsec profile zongbu1 isakmp
 ike-profile zongbu1
 ike profile zongbu1
 keychain zongbu1
ike keychain zongbu1 pre-shared-key address 0.0.0.0 0.0.0.0 key simple XXXX
vam client name changfa
 vam client name hub1
 advpn-domain zongbu1
 server primary ip-address x.x.x.x
 pre-shared-key  simple XXXX
user hub1 password  simple XXXX
 client enable
vam server advpn-domain zongbu1 id 1
 authentication-method chap domain zongbu1
 keepalive interval 10 retry 3
 server enable
 hub-group 0
 hub private-address 192.168.1.1 public-address x.x.x.x
 spoke private-address range 192.168.1.0 192.168.1.255
2.分部配置(采用pppoe拨号上网)
# ospf 1
 area 0.0.0.0
 network 192.168.1.2 0.0.0.0
 ip address 192.168.1.2 255.255.255.0
 source Dialer0
 tunnel protection ipsec profile 1
 vam client changfa
ipsec transform-set 1
ipsec profile 1 isakmp
 transform-set 1
 ike-profile 1
 ike profile 1
 keychain 1
 ike keychain 1
key simple XXXX
 user changfa password simple XXXX
 client enable
