设置列表
对齐方式
如何删除加粗内容
(0)
[N-JFA4-JR1]undo # irf member 1 priority 1
% Unrecognized command found at '^' position.
[N-JFA4-JR1]undo irf member 1 priority 1
% Too many parameters found at '^' position.
[N-JFA4-JR1]dis th
sysname N-JFA4-JR1
telnet server enable
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
#Current IRF priority configuration
#New IRF priority configuration
irf member 2 priority 1
irf mode normal
lldp global enable
system-working-mode standard
fan prefer-direction slot 1 port-to-power
password-recovery enable
stp global enable
scheduler logfile size 16
[N-JFA4-JR1]
[N-JFA4-JR1]irf
[N-JFA4-JR1]irf-port 2/2
% Wrong parameter found at '^' position.
[N-JFA4-JR1]#New IRF port configuration
[N-JFA4-JR1]undo irf-port 2/2
[N-JFA4-JR1]undo New IRF port configuration
[N-JFA4-JR1]
undo不掉呀.......
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
[N-JFA4-JR1]undo # irf member 1 priority 1 ^ % Unrecognized command found at '^' position. [N-JFA4-JR1]undo irf member 1 priority 1 ^ % Too many parameters found at '^' position. [N-JFA4-JR1]undo irf member 1 priority [N-JFA4-JR1]dis th # sysname N-JFA4-JR1 # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay #Current IRF priority configuration # irf member 1 priority 1 #New IRF priority configuration irf member 2 priority 1 irf mode normal [N-JFA4-JR1] [N-JFA4-JR1]irf [N-JFA4-JR1]irf-port 2/2 ^ % Wrong parameter found at '^' position. [N-JFA4-JR1]#New IRF port configuration [N-JFA4-JR1]undo irf [N-JFA4-JR1]undo irf-port 2/2 ^ % Wrong parameter found at '^' position. [N-JFA4-JR1]undo New IRF port configuration ^ % Unrecognized command found at '^' position. [N-JFA4-JR1] undo不掉呀.....
