华三S5120和H3C-5500V2-28C-EI
2020-11-30提问
  • 1收藏,1371浏览
对齐方式
  • 靠左
  • 居中
  • 靠右
华三S5120和H3C-5500V2-28C-EI两个配置数据可以通用吗?老型号的配置可以直接导入新型号配置吗?
你好
粉丝:119人 关注:1人
1、可以打通
2、配置不可以直接复制,第一接口不一样,第二版本有可能也不一样
<JYJ_HJ>dis cur # version 5.20, Release 2202P06 # sysname JYJ_HJ # irf mac-address persistent timer irf auto-update enable undo irf link-delay # domain default enable system # telnet server enable # undo ip ttl-expires # vlan 1 # vlan 221 description xianweiban # vlan 222 description jiwei # vlan 223 description zuzhibu # vlan 224 description xuanchuanbu # vlan 225 description tongzhanbu # vlan 226 description zhengyanshi # vlan 227 description zhengfawei # vlan 228 description jiguangongwei # vlan 229 description bianwei # vlan 230 description kexie # vlan 231 description tuanwei # vlan 232 description jiyaoju # vlan 331 description zhengfuban # vlan 332 description gongguanwei # vlan 333 description fagaiju # vlan 334 description jingxinju # vlan 335 description tongjiju # vlan 336 description kejiju # vlan 337 description sifaju # vlan 338 description rensheju # vlan 339 description zhaoshangju # vlan 340 description anjianju # vlan 341 description lvyouju # vlan 342 description ZFwangguanzhongxin # vlan 441 description renda # vlan 551 description zhengxie # radius scheme system server-type extended primary authentication 127.0.0.1 1645 primary accounting 127.0.0.1 1646 user-name-format without-domain # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system # local-user admin password cipher \&YO=;K%]MKQ=^Q`MAF4<1!! authorization-attribute level 3 service-type telnet terminal local-user cnxjyj password cipher \&YO=;K%]MKQ=^Q`MAF4<1!! authorization-attribute level 3 service-type telnet terminal # interface NULL0 # interface Vlan-interface1 ip address 192.168.228.2 255.255.255.0 # interface GigabitEthernet1/0/1 description connect_JYJ01 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/2 description connect_JYJ02 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/3 description connect_JYJ03 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/4 description connect_JYJ04 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/5 description connect_JYJ05 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/6 description connect_JYJ06 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/7 description connect_JYJ07 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/8 description connect_JYJ08 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/9 description connect_JYJ09 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/10 description connect_JYJ010 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/11 description connect_JYJ01 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/12 description connect_JYJ02 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/13 description connect_JYJ03 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/14 description connect_JYJ04 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/15 description connect_JYJ05 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/16 description connect_JYJ06 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/17 description connect_JYJ07 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/18 description connect_JYJ08 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/19 description connect_JYJ09 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/20 description connect_JYJ10 port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/21 shutdown # interface GigabitEthernet1/0/22 shutdown # interface GigabitEthernet1/0/23 shutdown # interface GigabitEthernet1/0/24 shutdown # interface GigabitEthernet1/0/25 description connect_JYJ_HX port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/26 description connect_JYJ_HX port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/27 description connect_JYJ_HX port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/28 description connect_JYJ_HX port link-type trunk port trunk permit vlan all # ip route-static 0.0.0.0 0.0.0.0 192.168.228.1 # user-interface aux 0 3 user-interface vty 0 4 authentication-mode scheme # return <JYJ_HJ>dis ver H3C Comware Platform Software Comware Software, Version 5.20, Release 2202P06 Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S5120-28C-EI uptime is 0 week, 0 day, 13 hours, 38 minutes H3C S5120-28C-EI with 1 Processor 128M bytes SDRAM 16384K bytes Flash Memory Hardware Version is REV.B CPLD Version is 007 Bootrom Version is 108 [SubSlot 0] 24GE+4SFP Hardware Version is REV.B <JYJ_HJ>dis dev m slot 1 DEVICE_NAME : S5120-28C-EI DEVICE_SERIAL_NUMBER : 210235A0BLH112000157 MAC_ADDRESS : 3822-D631-2848 MANUFACTURING_DATE : 2011-02-20 VENDOR_NAME : H3C <JYJ_HJ>
zhiliao_eafxn8 发表时间:2020-11-30
这是之前的配置,我要怎么配置现在交换机呢?
你这没啥配置啊,都是接口trunk
叫我靓仔 发表时间:2020-11-30
粉丝:14人 关注:0人
不能简单复制粘贴,因不同型号的设备,一是版本有可能不一样,H3C的系统有V3、V5、V7几个版本;二是设备的功能不一样,不仅硬件参数不一样,软件功能也不一样,高级别设备的很多功能,低级别设备是不支持的,就算是同级别的设备,也有很大的差别。
zhiliao_eafxn8 知了小白
<JYJ_HJ>dis cur
sysname JYJ_HJ
undo irf link-delay
undo ip ttl-expires
vlan 1
vlan 221
vlan 222
description jiwei
vlan 223
description zuzhibu
vlan 224
vlan 225
vlan 226
vlan 227
vlan 228
vlan 229
description bianwei
vlan 230
description kexie
vlan 231
description tuanwei
vlan 232
description jiyaoju
vlan 331
vlan 332
vlan 333
description fagaiju
vlan 334
vlan 335
vlan 336
description kejiju
vlan 337
description sifaju
vlan 338
vlan 339
vlan 340
vlan 341
description lvyouju
vlan 342
vlan 441
description renda
vlan 551
domain system
state active
idle-cut disable
user-group system
local-user admin
local-user cnxjyj
interface NULL0
shutdown
shutdown
shutdown
shutdown
return
<JYJ_HJ>dis ver
128M bytes SDRAM
CPLD Version is 007
<JYJ_HJ>dis dev m
slot 1
VENDOR_NAME : H3C
<JYJ_HJ>
第一,不要把这些全晒出来,因为一晒出来,就知道这是一个县委机房的一个配置,因为‘description’是描述的意思,以后晒配置,把所有description都删除一下。第二,我认为应该可以拷过去用,因为这两个设备的版本差不多,而且5120的功能,5500都支持的。
落啦耳朵 发表时间:2020-12-01
粉丝:124人 关注:6人
由于型号都不一样,因此软件平台和版本也是不一样的。部分命令可能不适配。主要是端口类型和端口号及其他的相关参数。
建议看好端口号后再进行配置。
