MSR36-10光口如何查看刚插的模块正常?如何配置
2020-12-09提问
  • 1收藏,1410浏览
Xiao 7 零段
MSR36-10路由新插了光模块,没配置过,也不知道模块是否正常。
粉丝:119人 关注:1人
dis inter xxxx
里面有个media-type参数,能识别就是正常 的了
粉丝:2人 关注:1人
查看端口光功率
dis transceiver diagnosis interface
<M9010n>dis transceiver diagnosis interface M-GigabitEthernet1/0/0/0
transceiver diagnostic information: The operation is not supported.
Ten-GigabitEthernet1/0/0/1 transceiver diagnostic information: The transceiver is absent.
 Ten-GigabitEthernet1/0/0/2 transceiver diagnostic information: Current diagnostic parameters: Temp.(?? Voltage(V) Bias(mA) RX power(dBm) TX power(dBm) 22 3.39 3.98 -6.73 -5.65 Alarm thresholds: Temp.
(?? Voltage(V) Bias(mA) RX power(dBm) TX power(dBm) High 90 3.63 12.75 3.00 0.00 Low -10 2.97 2.00 -21.02 -13.50 Ten-GigabitEthernet1/0/0/4 transceiver diagnostic information: Reading information from the transceiver failed.
查看光模块信息
display transceiver(收发器,指光模块) interface
粉丝:17人 关注:5人
dis transceiver  interface  看模块
看光衰
