H3C 5120 多个交换机组成IRF
2020-12-28提问
  • 1收藏,684浏览
原来是 Sw 1 ,Sw 2 ,Sw 3 ,Sw4 组成一个IRF
irf-port 1/1
port group interface Ten-GigabitEthernet1/1/1 mode normal
irf-port 1/2
port group interface Ten-GigabitEthernet1/1/2 mode normal
irf-port 2/1
port group interface Ten-GigabitEthernet2/1/1 mode normal
irf-port 2/2
port group interface Ten-GigabitEthernet2/1/2 mode normal
irf-port 3/1
port group interface Ten-GigabitEthernet3/1/1 mode normal
irf-port 3/2
port group interface Ten-GigabitEthernet3/1/2 mode normal
irf-port 4/1
port group interface Ten-GigabitEthernet4/1/1 mode normal
irf-port 4/2
port group interface Ten-GigabitEthernet4/1/2 mode normal
IRF 连线是 SW 1   Ten-GigabitEthernet1/1/1  SW2  Ten-GigabitEthernet2/1/2
                     SW2   Ten-GigabitEthernet2/1/1  SW3 Ten-GigabitEthernet3/1/2
                     SW3   Ten-GigabitEthernet3/1/1  SW4 Ten-GigabitEthernet4/1/2
                        SW4    Ten-GigabitEthernet4/1/1 SW1  Ten-GigabitEthernet1/1/2
DAC cable构成一个环
现在由于SW1 故障,配置里面SW1 的配置都没有了.(不考虑SW1了,因为故障要下架)
如果继续想让SW2 ,SW3,SW4 构成一个环,只需要把之前的连线动一下就可以了吧。
原来SW4 T 4/1/1 是插到SW1 T 1/1/2(故障),现在插到SW2 T2/1/2 就可以了吧?
                     SW4    Ten-GigabitEthernet4/1/1  SW2  Ten-GigabitEthernet2/1/2
另外当前IRF不会重启,业务也不会影响,disp Irf 还是和原来一样对吧?
<HSINCHU-IRF3-SW1>disp irf
Switch  Role   Priority  CPU-Mac         Description
 *+2   Master  30        c4ca-d946-9c18  -----
     3   Slave   28        c4ca-d9c1-9943  -----
    4   Slave   26        c4ca-d9c1-b3c3  -----
粉丝:5人 关注:1人
这个字乱行了,看不清楚
粉丝:148人 关注:1人
直接连,但是互联口要加入irf2接口port
