H3C 30系列路由
2018-05-10提问
  • 1收藏,1414浏览
现在配置如下,有端口映射、vlan、原来运营商接入是拨号、现在要换运营商网络,改成静态ip接入。求助一个静态ip接入命令(最好能添加多个运营商公网静态ip)(前提不改原来vlan 及172.16网段,端口映射我可以自己弄) ****************************************************************************** * Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved. * * Without the owner's prior written consent, * * no decompiling or reverse-engineering shall be allowed. * ****************************************************************************** login: admin Password: dis cu # version 7.1.042, Release 0007P02 # sysname router # telnet server enable # dialer-group 1 rule ip permit dialer-group 2 rule ip permit # system-working-mode password-recovery enable # vlan 1 # policy-based-route 123 permit node 10 if-match acl 2100 apply output-interface Dialer1 # policy-based-route 2 permit node 2 if-match acl 2100 apply output-interface Dialer2 # controller Cellular0/0 # controller Cellular0/1 # interface Aux0 # interface Dialer1 mtu 1492 ppp pap local-user 2800004567password cipher $c$3$V8GVIhxKxnKx3ltCv7jxTfnYyY eq1MutTpjF dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1024 nat outbound 2000 nat server protocol tcp global current-interface 33890 inside 172.16.10.254 338 9 nat server protocol tcp global current-interface 40000 inside 172.16.10.253 338 9 nat server protocol tcp global current-interface 80 inside 172.16.10.230 80 nat server protocol tcp global current-interface 82 inside 172.16.10.254 82 nat server protocol tcp global current-interface 5366 inside 172.16.10.230 5366 nat server protocol tcp global current-interface 8088 inside 172.16.10.210 8088 nat server protocol tcp global current-interface 18080 inside 172.16.10.220 180 80 nat server protocol tcp global current-interface 18090 inside 172.16.10.220 180 90 nat server protocol tcp global current-interface 22670 inside 172.16.10.254 226 7 nat server protocol udp global current-interface 83 inside 172.16.10.254 80 # interface Dialer2 mtu 1492 ppp pap local-user 4800006788password cipher $c$3$MA+297OBDk73rZRSaknULz5rOp 2rukYks/3g dialer bundle enable dialer-group 2 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1024 nat outbound 2001 nat server protocol tcp global current-interface 82 inside 172.16.10.235 82 # interface Dialer10 # interface NULL0 # interface GigabitEthernet0/0 port link-mode route combo enable copper mtu 1492 tcp mss 1024 nat static enable pppoe-client dial-bundle-number 1 # interface GigabitEthernet0/1 port link-mode route combo enable copper mtu 1492 ip address 172.16.100.1 255.255.255.0 tcp mss 1024 ip policy-based-route 123 # interface GigabitEthernet0/2 port link-mode route mtu 1492 tcp mss 1024 pppoe-client dial-bundle-number 2 # scheduler logfile size 16 # line class aux user-role network-admin # line class tty user-role network-operator # line class vty user-role network-operator # line aux 0 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 Dialer2 ip route-static 0.0.0.0 0 Dialer1 preference 100 ip route-static 172.16.0.0 16 172.16.100.2 # acl number 2000 rule 1 permit source 172.16.10.0 0.0.0.255 # acl number 2001 rule 10 permit # acl number 2100 rule 5 permit source 172.16.10.0 0.0.0.255 # super password role network-admin hash $h$6$SPR7Wp7ewsOjC3EK$NBdYoKF26kr9I7pE22 RdZc188JmA8rqPFrv/DJuuSQ9SZc0t/SvczDlMP1KPSTEo5GGxOqIwheV6ypsrqKi/Cw== # domain system # aaa session-limit ftp 16 aaa session-limit telnet 16 aaa session-limit http 16 aaa session-limit ssh 16 aaa session-limit https 16 domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role rule 1 permit read feature rule 2 permit write feature # user-group system # local-user admin class manage password hash $h$6$dJfNzUL220EE65Xj$3X9OTVkOksA7OLn8haJfpa50z1t0L8/4PrjOIMqfhoo V+Trm4Q0GrLXG5+FZDOAd8IxelcGXxIty/lvnTlWd3w== service-type telnet http authorization-attribute user-profile 32 authorization-attribute user-role network-operator authorization-attribute user-role level-14 authorization-attribute user-role level-15 # return
劳驾工程师指导、并回复加上接入运营商静态ip命令(给出命令、谢谢)
 ip address 公网IP 掩码
 nat outbound
 ip route-static 0.0.0.0 0 公网网关
