irf
2021-01-02提问
  • 1收藏,800浏览
粉丝:0人 关注:12人
模拟器中的irf能不能堆叠啊,为什么我配置没有用啊
粉丝:17人 关注:2人
模拟器可以堆叠,未成功需检查配置及步骤,方法如下:
配置基本IRF
[SWA]
interface Ten-GigabitEthernet 1/0/49
 shutdown
interface Ten-GigabitEthernet 1/0/50
 shutdown
irf member 1 priority 32                           //修改优先级,将SWA做为Master设备
irf-port 1/1                                      //创建逻辑端口
 port group interface Ten-GigabitEthernet 1/0/49
 port group interface Ten-GigabitEthernet 1/0/50
irf-port-configuration  active                       //激活逻辑端口
Save                                            //保存配置
[SWB]
 shutdown
 shutdown
irf member 1 renumber 2                              //Slave设备将member号改为2
irf-port 1/2                                           //创建逻辑端口
Save                                                 //保存配置
reboot                                                //Slave设备重启
配置基于BFD方式的MAD检测
vlan  3
 port  GigabitEthernet  1/0/5 GigabitEthernet  2/0/5   //新增一条BFD检测链路
interface Vlan-interface3
 mad bfd enable
 mad ip address 192.168.3.1 255.255.255.0 member 1    //创建主设备mad地址
 mad ip address 192.168.3.2 255.255.255.0 member 2    //创建备设备mad地址
interface GigabitEthernet1/0/5                    //BFD接口STP功能关闭
undo stp enable
interface GigabitEthernet2/0/5                     //BFD接口STP功能关闭
 undo stp enable
save                                          //一定要先保存在测试
粉丝:124人 关注:6人
HCL模拟器中的S5820和F1060是可以进行IRF堆叠的。
以下是HCL模拟器中的S5820、F1060的IRF配置案例,请参考:
https://zhiliao.h3c.com/theme/details/96463
S5820:
1、1号设备关键配置如下:
[H3C]irf member 1 renumber 1     //将1号设备设定为成员1
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]:y
[H3C]int range Ten-GigabitEthernet 1/0/50 to Ten-GigabitEthernet 1/0/51
[H3C-if-range]shutdown
[H3C-if-range]quit
[H3C]irf-port 1/1  //将物理端口绑定到IRF端口
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/1]quit
[H3C-if-range]undo shutdown
[H3C-if-range]quit
[H3C]irf-port-configuration active  //激活IRF
[H3C]save
2、2号设备关键配置点如下:
[H3C]irf member 1 renumber 2  //将2号设备设定为成员2
[H3C-if-range]quit
[H3C]irf-port 1/2  //将物理端口绑定到IRF端口
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/2]quit
[H3C-if-range]quit
[H3C]save
3、分别将成员1设备、成员2设备重启
4、测试
<H3C>dis irf  //查看IRF的信息,看到成员1和成员2的设备信息都在一起
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master  1         30bd-490a-0104  ---
   2        Standby 1         30bd-525e-0204  ---
 The bridge MAC of the IRF is: 30bd-490a-0100
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
<H3C>
<H3C>dis irf link  //查看成员1、成员2 IRF链路的状态均为UP
Member 1
 IRF Port  Interface                             Status
 1         Ten-GigabitEthernet1/0/50             UP
           Ten-GigabitEthernet1/0/51             UP
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/50             UP
           Ten-GigabitEthernet2/0/51             UP
<H3C>
<H3C>dis irf configuration  //查看IRF的配置信息
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/50     disable
 2        2        disable                       Ten-GigabitEthernet2/0/50
<H3C>
<H3C>dis irf topology  //查看IRF的拓扑信息
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           30bd-490a-0104
 1           UP         2             DIS        ---         30bd-490a-0104
<H3C>
至此S5820交换机的IRF已配置完成!
F1060:
1、1号设备关键配置点如下:
[H3C]irf member 1 renumber 1  //将1号设备配置为IRF成员1
[H3C]int range GigabitEthernet 1/0/2 to GigabitEthernet 1/0/3
[H3C-if-range]quit
[H3C-irf-port1/1]port group interface GigabitEthernet 1/0/2
[H3C-irf-port1/1]port group interface GigabitEthernet 1/0/3
[H3C-if-range]quit
[H3C]save  //保存配置
2、2号设备关键配置点如下:
[H3C]irf member 1 renumber 2  //将2号设备配置为IRF成员2
[H3C-if-range]quit
[H3C]irf-port 1/2  //将物理端口绑定到IRF口
[H3C-irf-port1/2]port group interface GigabitEthernet 1/0/2
[H3C-irf-port1/2]port group interface GigabitEthernet 1/0/3
[H3C-if-range]quit
[H3C]save //保存配置
3、分别重启设备1和设备2
4、测试
<H3C>dis irf   //查看IRF成员信息,发现设备1和设备2的信息都在一起
 *+1        Master  1         30d3-7ef9-0104  ---
   2        Standby 1         30d4-7d89-0204  ---
 The bridge MAC of the IRF is: 30d3-7ef9-0100
 Auto upgrade                : yes
 Domain ID                   : 0
<H3C>
<H3C>dis irf link  //查看IRF链路均为UP
Member 1
 1         GigabitEthernet1/0/2                  UP
           GigabitEthernet1/0/3                  UP
 2         disable                               --
Member 2
 1         disable                               --
 2         GigabitEthernet2/0/2                  UP
           GigabitEthernet2/0/3                  UP
<H3C>
<H3C>dis irf configuration  //查看IRF配置信息
 1        1        GigabitEthernet1/0/2          disable
 2        2        disable                       GigabitEthernet2/0/2
<H3C>
<H3C>dis irf topology  //查看IRF拓扑信息
                              Topology Info
               IRF-Port1                IRF-Port2
 2           DIS        ---           UP         1           30d3-7ef9-0104
 1           UP         2             DIS        ---         30d3-7ef9-0104
<H3C>
至此F1060防火墙的IRF已配置完成!
粉丝:29人 关注:0人
模拟器支持IRF 。
